Rear deck -OEM sub grill - Drive Accord Honda Forums
Old 06-24-2012, 08:08 AM
kalel34 kalel34 is offline
4th Gear
Hey folks, just wondering if the grill covering the OEM sub is removeable, like the rear speaker grills are? I don't have the OEM sub, so my deck doesn't have the grill. I'd like to know because I plan to install a sub in the rear deck, but want to keep it looking stock with the OEM grill. Thanks in advance!
Old 06-24-2012, 08:18 AM
idouoooo idouoooo is offline
3rd Gear
No it is not, it is one part with the rear deck cover. it has plastic pins that are melted onto the deck cover from the back side.
Old 06-24-2012, 08:25 AM
Artema's Avatar
Artema Artema is offline
Michael
You do have to remove the entire rear deck, but check one thread on here. Someone put in the larger Acura sub with some modification.
Old 06-24-2012, 08:49 AM
4th Gear
Thanks for the info, guys. I'm planning on having a shop cut a hole in the rear shelf, put an aftermarket grill, then cut a bigger hole in the sheet metal to house an 8" IB sub. I'd mountit with an MDF baffle/ring, then Dynamat the whole deck, maybe put a piece of foam between the plastic shelf and the metal deck.
Old 06-24-2012, 09:13 AM
3rd Gear
i would be very curious to see the rear deck without the sub in there. does honda pre-cut all the decks for the sub?
Old 06-24-2012, 10:01 AM
4th Gear
I can only see from below the deck. There is somewhat of a pre-cut cole in the sheet metal. It looks big enough to house a 6.5" sub. Plus, that same hole has 2 supporting bars that form an "X" across the hole. Looking bottom-up, the plastic shelf has a plastic coupling trim, circle shape, that is about 7-8" wide
Old 06-24-2012, 07:53 PM
3rd Gear
so not wanting to do major modification it would be possible to put in a good sub with a small amp to get much better base in the car
Old 07-06-2012, 05:58 PM
Fountainhead Fountainhead is offline
Hey Guys,
Tonight on another post (I searched the word "sub") I saw a tech bulletin for Canuk Hondas [08 rear shelf rattle 08-074.pdf] that had a picture of the rear deck panel upside down and I could see that the rear deck does have a "sort of" removable grill but there is sort of a tunnel that is made of the rear deck material that presses down around the edge of the sub (or blocks the sub circumference) so that even if the grill were to be removed the rear deck won't allow the sub to come out like the L & R speakers. There is also the fact that the sub opening of the rear deck is rectangular, not round.
See the attached TSB and you'll see what I mean.
1st Honda: Black Accord 2002 EXV6 traded at 102K bought with 6 miles on it. - best car I've ever owned, 0 and I mean 0 repairs.
2nd Honda: San Marino Red Accord Coupe 2012 EXLV6 18" wheels. Bought with 4 miles on it. Loving it.
