ISimple ISHD571 install - now car won't start - Drive Accord Honda Forums
Old 06-27-2012, 04:57 PM
Redhawk1 Redhawk1 is offline
I read and read and read this forum looking for the perfect device. Hillstones seemed like he knew what he was talking about, I liked how the Isimple product sounded for my 2007 EX-L.
Now here I am doing what seemed to be a pretty simple install and my car wont' start. Wont' turn over, won't turn the radio on, won't even give a hint of working. I turn the key and it the dash lights up and flickers and clicks a bunch of times. It sounds as if the electric grid has gone crazy.
Isimple informed me that they've never heard of this and that it shouldn't affect the starting process.
Pre-sinstall my car worked fine, post attempted install it won't start and is now going to get a tow to the shop (after a failed jump attempt did nothing).
Any ideas?
Old 06-27-2012, 05:06 PM
t-rd t-rd is offline
5th Gear
Did you disconnect the negative terminal of the battery before you started the install?
Old 06-27-2012, 05:20 PM
Damien22's Avatar
Damien22 Damien22 is offline
4th Gear
Dead battery, i would check voltage just to be sure, that way you don't have to tow it for nothing
Old 06-27-2012, 05:56 PM
Coley909's Avatar
Coley909 Coley909 is offline
5th Gear
+1 on the battery give her a jump and try again.
07 Accord SE i4
kenwood 6.5 front
Sound ordinance 6x9 rear deck
Blitzsafe AUX input
18 inch wheels 245x45x18
Tint 20% rear 35% front
Parrot MKI9200
Old 06-27-2012, 06:11 PM
mobiless2's Avatar
mobiless2 mobiless2 is offline
mobiless2
Dead battery, time to upgrade to larger V6 battery.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 248K
2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K
Old 06-27-2012, 07:59 PM
07AccordEx-L's Avatar
07AccordEx-L 07AccordEx-L is offline
out of control
What everyone said
2006 Accord Coupe V6 6MT w/Navigation
Previous:2007 Accord i4 5AT
My 7th Gen V6 6 Speed Build
http://www.driveaccord.net/forums/sh...344#post967344
Old 06-28-2012, 04:45 AM
I should have mentioned that I did get a buddy to come over and give me a jump, wouldn't even turn over though. I checked every fuse as well, nothing. I also disconnected the negative battery connection, was prompted to enter the anti-theft code, that worked fine, but still wouldn't start. Now I can't even get the radio to power on when I put the key in and have to watch all the lights on the dash flicker and make this rapid clicking noise. I guess it could be the battery but that doesn't explain why a jump had no effect...
Old 06-28-2012, 05:11 AM
Coley909's Avatar
5th Gear
How long was your buddy connected to your battery if it is that dead it is going to need some time to charge before you try and start it. Have your buddy hooked up for a couple minutes and then try it. Make sure red is on the + and black is on the -
then go ahead and give it a go. Something should work radio anything something has to work no way you could have blown every single fuse.
07 Accord SE i4
kenwood 6.5 front
Blitzsafe AUX input
Parrot MKI9200
Old 06-28-2012, 08:51 AM
5th Gear
Did you disconnect the battery after the fact or did you do it BEFORE the install? You need to disconnect the battery during any install that involves electrical or tapping into "hot" wires. You definitely fried something, it might be a relay.
Old 06-28-2012, 12:38 PM
A ton of people did the install without disconnecting the battery. Obviously this might have been the problem (as I did not), but does disconnecting the "xm" plug and connecting the Isimple count as "tapping" into wires? In addition when I was done with the install the radio was working perfectly with the device. I didn't even notice until I put everything back together and then tried to start the car.
Old 06-28-2012, 12:47 PM
Damien22's Avatar
4th Gear
no the isimple is straight plug and play
Old 06-28-2012, 04:39 PM
crackerteg's Avatar
crackerteg crackerteg is offline
Call me Z
Not necessarily true. Its RECOMMENDED to do it (especially for those without the experience) but not absolutely needed. Yes, you run the risk of frying something but there are measures that can be taken. Is it recommended to do what I'm saying? No. I'm not recommending it or condoning it but that's just how I work.
The name is Z. Not Cracker. Not CrackerTeg. *$#@!&% Z. Is that too hard to comprehend?
Old 06-28-2012, 05:02 PM
5th Gear
You never know.
Have you checked the voltage at the battery and see if the battery is good? If the voltage at the battery is too low then this would happen also.
Old 06-28-2012, 05:09 PM
Damien22's Avatar
4th Gear
You never know.
samething i mentioned earlier
Old 06-29-2012, 08:24 AM
Keystone Keystone is offline
Sometimes when batteries fail, the internal plates crack and fall into one another causing in internal short. If that happens, the battery will not take a charge and will actually cause such a drain that a jump won't work either.
Check the voltage with the headlights on to put a small load on the battery. No load voltage can be high enough to make the battery appear good.
