I changed my front brake pads a few weeks ago and had no problem.
My rear passenger brake has been making a grinding metal noise for a while and was now continuous. Weather I brake or not. I changed out the brake pads, rotors and found a sticking passenger side caliper and sliders so I replaced them and lubed them. While changing out the caliper I did lose some fluid from the brake line and I DID NOT bleed the brakes. I finally finished just now and my brake pedal floors when I brake, but it still stops. My BRAKE LIGHT and my ABS LIGHT both come on now. None of them were ever on before. Do I need to go back and bleed them, if so how? And that same passenger side rear brake makes a small grinding noise still. Is it likely the brake line that needs to be replaced. Fell free to text me 786-374-9377
97 Accord Sedan LX 94 Accord Sedan LX 5spd 02 Accord Sedan SE 4cyl 03 Accord EX 6cyl V-tech (Current Car) |
| Sponsored Links | ||
Advertisement | ||
Did you disconnect the brake line by loosening the banjo bolt from the old caliper and installed a new caliper?
Your have to bleed the brake system when you do that. |
Yes i did. And I didn't bleed the brakes.
Why did you have to change out the caliper? Did you have a stuck piston?
When you disconnect the line you let air in so you need to bleed the brakes. I'm guessing you didn't do it quick enough and a lot of air got in. |
The piston was stuck and destroyed one of my pads completely and the rotor.
It is pooring hard down here in Miami, but when it clears up I will bleed both sides. I should of known better. Thanks a ton. i will keep you posted.
You need to bleed all 4 corners. when you took the caliper loose, fluid drained downhill from the reservoir and it may not have any left in it.
The welfare of humanity is always the alibi of tyrants. Save the Manuals!
1 3 5 ├┼┤ 2 4 R |
Any time you have to disconnect a brake fluid line, you must bleed the system.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 251K 2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K |
When you're bleeding the brakes you should bleed the wheel furthest away from the master cylinder first. If you're bleeding all four the order should be the right rear, then left rear, then right front, and lastly the left front.
Yes
Arent you suppose to bleed the left front first?
http://www.driveaccord.net/forums/sh...ad.php?t=62080
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 57k miles |
Yes. Yes you are. StanB, its probably the same for yours. I'd suggest checking on that.
The name is Z 2005 Satin Silver Metallic LX sedan k24 5MT HT spec V2 F2 Type 1 coils l Wicked Tuning rear camber arms l TL-S 20mm RSB l EVO X GSR 18 x 8.5 +38 wheels wrapped in Falken 912 sized 225/40/18 for her pleasure l OEM V6 coupe exhaust minus resonators l Custom "Icebox" intake l Custom polished shifter extension l Custom E46 bixenon retro in black housings l OEM rep front lip l ebay fogs l there's more I'm forgetting Daily beaten/ driven |
OP,
It is quite scary that you would perform this work not realizing or understanding the requirement to bleed the system afterwards, you are very fortunate that you did not cause a seriours accident with the defective brake system, DO NOT drive the car until you have properly bleed the brake system completely, BTW that doesn't mean to let all the brake fluid out!!!!
2005 Satin Silver V6 Coupe 6 speed, Venture Shield clear protetive film, TL shift knob, Hidden Hitch, GM Friction Modified Synchromesh transmission fluid 2007 Acura TL-S front/rear sway bars, Clutch slave cylinder restrictor valve delete. Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960 Honda steel rims 225/55-16 Michelin Alpin PA2 __________________ DA Moderator Team DriveAccord.Net Forum Rules & Regs DriveAccord.net Classified Rules |
Damn, yes it's the same for mine. I didn't know the sequence changed.
Yup, I absolutely have to go back and bleed them. Thanks again everyone for all the helpful info.
I would suggest having someone do this. If you disconnected your brake line and didn't know you HAD to bleed the system because you introduced air into it the very second you disconnected it, no offense but you should not even be attempting to bleed the system.
It's a two man job, and it must be done right or you will have serious problems. Not knowing you had to bleed it, and then assuming you only needed to bleed two brakes at first, leads me to say you should most certainly take your car to a Honda dealer. Don't take it to just any garage, most regular service garages would assume you bleed these like most cars, farthest away to closest to the master cylinder, when on our Accords it's the exact opposite..... also, I would not trust any DOT3 fluid other than genuine Honda DOT3 fluid. Even if garages tell you it's fine, you don't want to take the chance of non-Honda fluids.
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten |
| Sponsored Links | |
Advertisement | |
