#16
Downshifting to assist in slowing down should be limited to extreme situations. Excessive downshifting as a braking technique can lead to premature clutch wear. Isn’t that what brakes are for?
I would much rather replace a set of pads and cut my rotors than replace my clutch. Just my .02...
09 V6 6MT Coupe |
| Sponsored Links | ||
Advertisement | ||
#17
The main purpose for heel toe driving is racing, if you're not trying to shave off tenths on your laptime and driving around close to redline, it is almost useless on the street. It's a very high level technique though, you will not pick it up very easy and it will take practice. I'm not perfect, by any means. Basically think you're coming into a fast turn at 100+ in 4th and you need to drop it down to third, first thing you're gonna do is start applying brakes with your right toes and then go for the clutch with your left foot. As soon as you feel the clutch disengage, you need to blip the throttle with your right heel to get the revs up a little before you move the shifter to third and release the clutch pedal. All of this needs to happen in less than half a second, it's the hardest thing to do smoothly in any car. A lot of real races cars with sequential transmissions or paddle shifters have an auto-blip/clutch that does it for them. If done correctly, you will be doing less wear on the clutch than not blipping. Some cars (and your shoe size/flexibility) make it almost impossible to heel toe, so people will use a variation of that and use the left side of their right foot for brake and the right side of the foot for the gas. I personally would never go into neutral for anytime while down shifting, going into a lower gear, gives your brakes some help with the engine doing some of the braking. You can slow down faster with the engine in gear, if you had to. Tape over your gauges or DO NOT look at them. You don't need to concentrate on them. Also, the slower the gear change, the hard it is to get the correct blip. |
#18
#19
I double clutch before taking corners so I can get out of them quicker and smoother. Why would you want to go into a corner at a high gear? I've tried heel and toe and cannot do it in this car for the life of me so I just single/double clutch depending on the situation.
2006 Accord Coupe V6 6MT w/Navigation Previous:2007 Accord i4 5AT My 7th Gen V6 6 Speed Build http://www.driveaccord.net/forums/sh...344#post967344 |
#20
#21
It is but my downshifts are smoother when I double clutch vs single clutching. I don't even have to look at the tach. It's preference.
#22
Push clutch in Take out of gear Move to neutral let out clutch push in clutch move to next gear trim the throttle as you release the clutch ? right |
#23
Clutch in Move into neutral Clutch out Blip throttle Clutch in Move into lower gear Clutch out All in a quick and smooth manner.
#24
You say in single clutching you watch the revs in order to rev-match. Then you say in double-clutching you blip the throttle. How is it that you don't watch the revs when double-clutching but do need to when single clutching? I always rev-match by blipping the throttle in single-clutching and I don't need to watch the revs to do so.
Mark 08 Accord EX-L V6 sedan (non navi) 2012 Infiniti G37X | 2012 Porsche 911 Turbo S | 97 Jaguar XJ6 | 95 Ford Taurus SHO | 77 MGB | 2012 Cessna 400 Corvalis TTX |
#25
I didn't go into detail about single clutching but if you meant by blipping the throttle in neutral then I was telling the OP to do that while practicing so he has an idea of how pressure to apply onto the gas pedal.
Pretty much once you get it down packed, it becomes second nature and you don't even have to watch the tach. You just know.
#26
What's the purpose of double clutching? I've never done it. Seems like too much hassle.
2006 Accord EX-L Navi 5MT, Graphite Pearl 2006 Accord EX sedan 5AT, Taffeta White - RIP |
#27
nissan gtr and infinity has automatic rev matching in the manual tranny!!
#28
what is the benefit of double clutching in modern vehicles? i understand it is to reduce overall wear on internal transmission components, but wasn't it more for older, less advanced transmissions? i'm asking because i've never had a problem with a transmission and i just use the single clutch downshifting method and rev-match. this includes driving a very old, fragile clutch ('92 accord w/ 177K miles on it...original clutch). if excess wear was going to happen, wouldn't it have mattered by then?
#29
Double clutching isn't necessary. I do better double clutching than single clutching. So it's Just a preference.
#30
a. It "neturalizes" the wear pattern on the clutch disc as the rotational force from accelerating is opposite to decelerating, it's hard to argue with him who is an accredited Professional Engineer with a MSc in nuclear phsyics and a wiz in computer science and electronics. b. He can save the wear on brakes. A little over two years later he finally agreed with me he was wrong when he needed the clutch replaced when it wore much quicker than can be expected for the mileage of the car, and that brake pads/rotors are infinitely easier and less expensive to replace than the clutch, especially on a FWD! FWIW I "learned" about double clutching from reading a high-performance driving paperback book in the early years of my high-school days, I read that book several times over and "practiced" in my head countless times even though we didn't have a manual transmission car at the time, in fact it wasn't until several years later before we got a manual transmission car, my dad was amazed I was able to drive it after less than 10 minutes of practice from never driven a manual transmission car ever prior to that day.
2005 Satin Silver V6 Coupe 6 speed, Venture Shield clear protetive film, TL shift knob, Hidden Hitch, GM Friction Modified Synchromesh transmission fluid 2007 Acura TL-S front/rear sway bars, Clutch slave cylinder restrictor valve delete. Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960 Honda steel rims 225/55-16 Michelin Alpin PA2 __________________ DA Moderator Team DriveAccord.Net Forum Rules & Regs DriveAccord.net Classified Rules |
| Sponsored Links | |
Advertisement | |
