A/C still blows cold air when off - Drive Accord Honda Forums
Old 07-18-2012, 03:53 PM
primetime's Avatar
primetime primetime is offline
3rd Gear
I press the off button after it gets cold, and the display gives the appearance that the system has been turned off, but cold air still comes through the vents. Is this normal, or is there something wrong?
2009 EX-L v6
Old 07-18-2012, 04:47 PM
kvndoom's Avatar
kvndoom kvndoom is offline
Should've kept the Honda
You got it on recirc or fresh air?
Honda of America: "Sorry folks, we don't waste our paint on manual-shift cars."
5/31/11 - 10/1/12: 2011 White EX-L 6/6 coupe w/nav http://www.youtube.com/watch?v=Hn-enjcgV1o
Current: 2011 Nissan Juke SL 6MT, 2005 Ford Focus ST 5MT
I shift with PEDALS, not PADDLES.
Old 07-18-2012, 07:23 PM
h2pvnus h2pvnus is offline
5th Gear
Did you tilt the moonroof. The cold air still blow in from the air vent if your sunroof is tilted.
Old 07-19-2012, 07:26 AM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
The moonroof has nothing to do with the air blowing. kvndoom has it correct. If you have the vents set to fresh air (light off), they will still allow air to flow.
When the sunroof is open or tilted, it is causing more air to be pulled through the cabin so the vents pulls more air in. Same thing happens with a window opened.
2007 EX-L 4DR
Old 07-19-2012, 07:45 AM
ottoaccord ottoaccord is offline
I would change the A/C relay, it's a pretty cheap ($10) part. In looking back to a problem I had with my A/C recently it was doing the same thing. The next series of events was my battery being drained by something when the car was off and when my car was running the A/C pressure release valve popping off.
I'm by no means an expert, just my $.02.
Old 07-19-2012, 10:44 AM
Danielc409's Avatar
Danielc409 Danielc409 is offline
Sugar coating for you ..
Do you notice the a/c kick off when you turn it off? Turn the radio off, run the a/c, then turn it off and see if you notice it.
2011 Subaru STi - Stage 2 - Plasma Blue Pearl
My member journal / build thread @ IWSTI
2008 Honda Accord Coupe V-6 EX-L AT NBP
No longer owned
Old 07-19-2012, 11:08 AM
mkrtchianmike's Avatar
mkrtchianmike mkrtchianmike is offline
Chirpin 2nd
Put the temperature in the middle so it wont blow cold air
Old 07-19-2012, 11:17 AM
Yukfoo's Avatar
Yukfoo Yukfoo is offline
5th Gear
If it's cold/cool outside, it will blow cold/cool air even when turned off.
2010 Accord Coupe EX-L, I4 Auto
ASM w/ Black Interior
Oddessy Grille
Fumoto Drain Valve
Weathertech Digital Floor Mats
CHH Homelink
CHH/Honda USB Audio Interface
KP Technologies Window Roll-up Module
OEM Fogs
Farenheit Navi w/ Reversing Camera
Weapon R I-Throttle Controller
32% Tint
$25,995 OTR
Old 07-19-2012, 03:06 PM
blacklabel1783 blacklabel1783 is offline
when you cut the a/c off, press the recirculate button.
Old 07-20-2012, 06:46 AM
MikeyC's Avatar
MikeyC MikeyC is offline
Driver
Think if it's on a defrost setting it will blow cold even if ac shows off, though then it shouldn't blow out the vents, useless post by me :/
2011 Accord Coupe EX, Taffeta White, I4 Auto
Old 07-20-2012, 07:04 AM
Amperex Amperex is offline
2nd Gear
To turn the AC off, press the AC button until you see AC off in the display. Pressing on/off will not turn the AC off. If you don't see AC off in the display, your AC compressor is On.
Old 07-20-2012, 11:05 AM
Doolie77's Avatar
Doolie77 Doolie77 is offline
'09 Coupe EX-L V6 MT ABS
Yea, I use the A/C button on the right side to turn off A/C. Pressing the Auto button so the light is off just means its in manual. After that, It may blow cold for a minute or two until the coils warm up to the outside air temp.
'09 Accord Coupe V6 MT
'05 Element
'05 Civic LX
'06 Civic Si Coupe - Sold :( to buy the Accord :)
'07 Pilot - Sold
