98-00 throttle body cleaning 01-004 - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > Honda Accord Factory Direct
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 03-15-2004, 11:47 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 09-01-2009, 05:12 PM
colo_6645 colo_6645 is offline
do have the throttle body cleaning pdf for a 2005 accord EX...
thankss..
Old 09-02-2009, 07:51 AM
princess's Avatar
ready to go....
Assuming it's an L4, not a V6:
Old 09-03-2009, 07:46 PM
thank you veryy muchhh... ..
Old 09-03-2009, 08:04 PM
Hey princess i have a question... you dont recommend me cleaning my throttle body not having a HDS to reset the ECM/PCM in the idle learn procedure right.??...or is there another way to clean my throttle body without having to remove it completely and without having to reset the ECM/PCM with HDS...??...
thanks a lot for the help...
(i was thinking of cleaning my throttle body but now i dont know.)
Old 09-06-2009, 07:30 AM
princess's Avatar
ready to go....
You CAN do an on the car cleaning. Use ONLY throttle body cleaner (not carb cleaner). Spray & wipe, spray & wipe. Careful to not get too much down to drip in the intake.
Throttle body cleaner has a blend of solvent that will break up the carbon & lubricant for the moving parts.
Old 09-06-2009, 07:50 PM
ohhh ok, perfect...i will do that...thanksss...
Old 12-09-2010, 09:23 PM
Ivanazul Ivanazul is offline
My First Post
Hi Princess, Thanks very much for this info. I am planning to clean the throttle body since the "butterfly" is sticking really bad, especially now that it is colder outside. I think I am going to replace the throttle/accelerator cable as well. The document you posted refers to two additional docs on page 2 that may help me with the cable replacement. Could you be so kind as to post those here? (adjust the cruise control actuator cable... see page 4-55 of the 1998-01 Accord L4 Service Manual. Adjust the throttle cable, see page 11-132). Thanks in advance.
