Trailer Hitch - Drive Accord Honda Forums
Old 08-02-2012, 07:34 AM
bobbyroller bobbyroller is offline
Trailer Hitch
I was planning on buying a jet ski and towing it with my i4 accord. Has anybody else had experiences with towing on a 4 cylinder? Also, what are some good hitches for the accords that are cheap and good quality?
Old 08-03-2012, 01:19 AM
The Pope's Avatar
The Pope The Pope is offline
Just another old guy ....
I had a hitch on a 2006 I4 manual transmission Accord and had no issues pulling a 4'x6' utility trailer. Now I never had the trailer anywhere near it's capacity. Pulling a trailer with one or even two jet skies shouldn't be an issue.
Curt, Draw-Tite & Reese are all good as for hitches. You will need to decide on which "Class" size you want. Not for the amount you want to tow, but for the receiver size (1 1/4" or 2"), as you "may" also want to mount a bike rack or other items to the hitch every once in a while. With that said, I'd recommend the larger one, as there are adaptors to reduce the receiver down from 2" to 1 1/4". This would give you the most options for what you may what to use the hitch for.
The Pope
Things that we go thru that don't kill us, makes us stronger. What we learned from these events are now tools in which we can use to help others.
My youngest son, RIP 10/3/2004 (He was 19 at the time)
My mom, RIP 4/6/2011
Forum Rules: http://www.driveaccord.net/forums/sh...ad.php?t=19181
Old 08-03-2012, 05:10 AM
Hytekazn's Avatar
Hytekazn Hytekazn is offline
4th Gear
Send a message via AIM to Hytekazn
If a 2008 prius can drag a 4x8 utitlity with every cubic inch fully loaded . (washer/dryer, mattress, etc) And drove 800miles straight. An accord can do it...I hope lol
Current Ride
_______________________________
-08' Honda Accord LX i4 sedan.
Mods
-Aftermarket Fogs installed w/ 3000k HIDs
-5000k HIDs installed in headlights
-25/35 tint front/rear
-Sound system - Rockford 300watt amp, Boston acoustics SE60 components, Rockford Fosgate 10inch sub.
^ Happy Camper.
Old 08-03-2012, 05:18 AM
digitalh3lix's Avatar
digitalh3lix digitalh3lix is offline
lookin' clean
Send a message via AIM to digitalh3lix
what are your thoughts on a trailer hitch towing a 16ft aluminum boat/motor/and trailer?
2007 ASM Accord SE Sedan 5SPD
Mods:Skunk 2 knob, Neuspeed SSK, Eibach Pro-kit, Koni yellows, Modulo front lip, Hybrid Tails, HFP Silverstars, General Exclaim 225/50/17, Hawk brakes pads, 17mm RSB, strut tower, 6K HID, Acura Legend brake calipers, Depo headlights,Raxles, Syncromesh,Boston Acoustics
1993 Prelude VTEC 5SPD BLACK - SOLD.
Old 08-03-2012, 06:02 PM
CarlR33's Avatar
CarlR33 CarlR33 is offline
6th Gear
I had a 88 cavalier with a hidden hitch (brand) with no issues towing a jet ski.
03 Accord LX I4 5spd, 216k miles.
Old 08-06-2012, 01:25 AM
The Pope's Avatar
Consult your owners manual. It should have a max tow value listed.
But with that said, I see no problem pulling a 16ft aluminum boat/motor/and trailer, as long as it doesn't weigh over 1500 lbs.
Also, for those who have automatics, don't use overdrive when towing something that's in the mid to upper half (appx. 750# - 1500# plus).
The Pope
Old 08-31-2012, 09:30 PM
2006AS's Avatar
2006AS 2006AS is offline
4th Gear
As far as I know all they make for the Accord are class I hitches so they are all the 1 1/4".
Personally I have a Hidden Hitch branded one, but they are all pretty much comparable. Since a class I hitch can handle 2000 lbs you should have no problem at all with the jet ski. I have towed my motorcycle and it does just fine, especially if it's mostly level ground.
Also don't forget to get a wiring kit for the trailer lights. They make plug-n-play ones for the Accord, which should literally take 10-15 minutes to install.
Tags
trailer, wiring
