Shifting has greatly improved since switching to new Honda synthetic transfluid - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Fluid Dynamics
Old 08-02-2012, 01:23 PM
Dan's Avatar
Dan Dan is offline
5th Gear
My shifting has improved greatly since switching to Honda DW1
And yes it's been about 2k miles and it's still good.
I did one drain and fill, and also put in 5 ounces of lubeguard red trans additive. It has shifted the best it ever has. The car has 115k miles on it
I urge others to try the new honda trans fluid and lubeguard red
'01 Emerald v6 Sedan. (sold)
'06 Sapphire v6 Coupe.
Old 08-02-2012, 04:51 PM
nodrog321's Avatar
nodrog321 nodrog321 is offline
6th Gear
Send a message via AIM to nodrog321
tried doing a drain and fill last week. the drain bolt wouldnt budge. which way am i supposed to turn it? toward the front or rear of the car?
2007 Honda "Nikita" Accord I-4 LX Sedan
Graphite Pearl
-Blackhoused MH1 Retrofit projectors with DDM 4500k HIDs
-Soundgate aux integration
-Diode Dynamics stage 2 kit (license plate, front door lights)
-Aftermarket Inspire Fogs with 4300k HIDs
-TL Type S rims!
-OEM Decklid Spoiler
-Nokya Hyper Yellow DRL
-JL Audio TR690 rear speakers
-Polk DB 6501 front speakers
-K&N Short Ram Intake
-Acura TL RSB
Cardomain
Old 08-03-2012, 12:47 AM
Dan's Avatar
Dan Dan is offline
5th Gear
The drain bolt is lefty loosey, righty tighty.
Just imagine it's a soda bottle and you want to take the cap off
Old 08-03-2012, 06:11 AM
SatinSilver's Avatar
Moderator
Is this the first time you changed it? I'm sure the lubeguard made a big difference. I need to get some of that stuff. Where did you buy the LG?
05 Toyota Matrix XR: Silver, 55k
99 Accord Coupe: 2.3, 166k, original owner.(sold)
94 Civic Coupe: manual (sold with 45k)
83 Cutlass Supreme Coupe: Traded in with 67k.
Old 08-03-2012, 08:35 AM
Dan's Avatar
Dan Dan is offline
5th Gear
Hey satin. it's the second time i changed it. the first time i used atfz1 and it was better,but went back to it's old ways. That said, the first z1 did help.
But this Dw1 change with added lubeguard red has helped alot, and the effects are lasting.
I bought the LG red from NAPA auto parts. You should try it and report back please!!
Old 09-14-2012, 11:18 AM
2006accord4 2006accord4 is offline
2006 I4 MT
Lay down and use your foot to push on the ratchet or breaker bar. That bolt is coming off.
When I'm doing ATF fluids on Hondas for family or friends that have never been changed, I always use my foot to push.
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 57k miles
Old 09-17-2012, 08:10 AM
SlickNshinY SlickNshinY is offline
sounds like an awesome combo. Ill be doing my first 3x3 with the ATF fluid soon. Do you have a part number on that lubeguard? Im on NAPAs site and I have a couple to choose from. Thanks
Old 09-17-2012, 09:19 AM
njhustler njhustler is offline
I've loosened many a bolt using my legs. Nodrgog321 you should be pushing toward the rear of the car , granted the bolthead is facing driver side like on my car 04 4dr v6 5at.
Old 09-19-2012, 04:56 AM
Dan's Avatar
Dan Dan is offline
5th Gear
does this help? i put in about 6 ounces
Amazon Amazon
Old 10-16-2012, 01:17 PM
Phlip96's Avatar
Phlip96 Phlip96 is online now
4th Gear
What is the difference between the red and black label? I ordered this one.. should i have ordered the red? If that is what you guys have used, I'll stick to it.
Amazon Amazon
Do or Do Not - There is no Try
Old 10-21-2012, 05:42 PM
Dan's Avatar
Dan Dan is offline
5th Gear
I spoke to Philip96 via PM.
I now recommend throwing the whole bottle of lube guard red in there. I have had no problems, and if anything its better. so that's 3 quarts of DW1+1 bottle of lube guard red for an automatic transmission
