Steering wheel pop - Drive Accord Honda Forums
Old 08-06-2012, 05:50 AM
Metal Metalic's Avatar
Metal Metalic Metal Metalic is offline
6th Gear
Steering wheel pop
OK, this is prolly not the same as what others described.
For the first time... I noticed a pop with the steering wheel while I was in a sweeping turn and braking at a stop.
Once I accelerated and straightened out, I noticed lighter pop and the issue has not returned since.
I did not use my turn signals as there was no traffic around for miles. Like you're going to say why in the did you stop? HA!!!
I am keeping note to keep an ear out for the next time. Seems like others get the pop not as random.
Wonder if the pop started out random and became frequent for them?
2009 EX-L Coupe - V6 VCM - PMM
0w-20 cap
3.7L TL-SHAWD IM - Functional
65w H9 Lo & Fog / 80w HB3 Hi
Cargo hooks & net
Crosstour knob
Duralast Gold 24F-DLG
I4 hood rod
MDX spacer & Runners - Ported
Moded OEM CAI
Mobil 1 0w-20 & M1-110
NAPA #18514
Odyssey garnish - Flush fitted
Painted splash guards
PXAMG & HDRT
Rear: Belt, head rests & ANC delete
Service Grade Electricals
Test Pipe
Window UP mod
Valvoline Type VI
Next:
Acura TL-SHAWD Heads
HFP suspension
Old 08-06-2012, 02:36 PM
AccordinLyVietz's Avatar
AccordinLyVietz AccordinLyVietz is offline
09 CBP Sedan V6 Navi
there's a TSB for 8th gens in that year. i went to my local dealer and asked if they were able to fix it even though i was out my warranty. the service manager was kind enough to do a good will repair. i believe it has something to do with a loose ball bearing.
here's the link and print it out to show your dealer if the car is still under warranty. my fix came out to be around $545 including labor, all paid by the generous people at honda corp.
http://mordor.rutgers.edu/accord/tsb...p%2009-078.pdf
2009 EX-L V6 Sedan Navi CBP/Black Leather
2001 EX V6 Sedan Nighthawk Black
1995 EX i4 Sedan Grenada Black Pearl
5000K HID - 2011 Deck Lid Spoiler - Moonroof Visor - 35% nano ceramic tint - 19" HFP - HFP Suspension - Alpine 12" Type R - Crosstour leather shifter - Full Crosstour Woodgrain - Weather Tech DigiFit
Old 08-06-2012, 04:52 PM
jeebus31's Avatar
jeebus31 jeebus31 is offline
Original Honda M6 Owner
metal metallic, this is how my steering column issue began. first very rare and then after a couple weeks, basically every time i turned. there is a TSB and the dealers know about this issue, the problem will be recreating it at the dealer. my car did it all the way on the ride to the dealer and of course when the service guy is in the passenger seat nothing happened... until i swore like a sailor at my car and it started popping again haha.
2009 EX-L V6 w/ Navi CBP 5AT - Body Side Molding - exLEDUSA Interior 5k LEDs - Brakemotiv Drilled/Slotted Rotors - 35% Tint - 6k HID Headlights - Debadged
Old 08-07-2012, 03:39 AM
6th Gear
Thanks! :o)
I know that feeling... got it a lot when I did field service work. They would swear the issue was there before I walked in. HA!!!
I looked up my VIN and found that my coupe does fit in with the TSB.
I did not realize I had an early model 09' V6.
I got about a year and a half to go on warranty, so I will take it in when I have other things that may come up before then.
0w-20 cap
Cargo hooks & net
Crosstour knob
I4 hood rod
Moded OEM CAI
NAPA #18514
PXAMG & HDRT
Test Pipe
Window UP mod
Valvoline Type VI
Next:
HFP suspension
