Does it require to remove the bumper in order to install Hid's.? - Drive Accord Honda Forums
Old 08-06-2012, 02:14 PM
ricky.s.731 ricky.s.731 is offline
I just bought the HiD package for the accord coupe but was wondering if i need to remove the bumper in order to install the Hids. And if not, is there any good videos that shows you how to do it yourself?
Your answer is greatly appreciated.
Thank you
Old 08-06-2012, 03:27 PM
labaos_89's Avatar
labaos_89 labaos_89 is offline
4th Gear
I don't think you need to I'm sure you can do it without removing the bumper but I found it way easier to install once I took off the bumper, also made more room to have a cleaner install.
2011 Accord Coupe EX-L
HFP Skirt Pkg
JDM Badges
6000K HID Headlights
Nokya Yellow DRL
Injen Short Ram Intake
P2R Throttle Body Spacer
Magnaflow Dual Catback Exhaust
Tein SS Coilovers
P2R Downpipe W/Cat Delete
Old 08-06-2012, 04:10 PM
HellaFlush HellaFlush is offline
you can hide the ballast behind your fender liners just zip tie/ double side tape it securely on the frame
Old 08-07-2012, 01:42 AM
Tee_Brennan Tee_Brennan is offline
You do not have to remove the front bumper! I did mine through my wheel wells. Just turn your wheel in, and there are two push pins that you remove and pull the guard back and it's easy acces straight to your headlight. I did mine in 15 minutes!
Old 08-07-2012, 03:40 AM
coupe7 coupe7 is offline
2010 coupe'
2 nd that. Through the wheel wells, secured balast top with self tapping screws for easy access if need be replaced . Hopefully you ordered a plug and play hid kit. Check out you tube, search hid install, there's actually a video of a 7th gen accord similar layout. Good luck.
Hids
Fog light
Mud guards
10 inch sub
Weather Tech
Snow tires
Led interiors
K N drop in filter
Old 08-07-2012, 03:42 AM
gillbill2795's Avatar
gillbill2795 gillbill2795 is offline
3rd Gear
Send a message via Skype™ to gillbill2795
For low beams you do not! I did mine in an hour without removing the wheels or the bumper.
However, I want to do my fogs. I have a v6 sedan, must I remove the bumper to install those? I don't have a problem removing the wheels, just the bumper.
Old 08-07-2012, 05:09 AM
2010 coupe'
Yes the bumper will have to come off for the fog install. If you order extra clips just in case , it is a simple bolt on bolt off process.
Hids
Fog light
Mud guards
10 inch sub
Weather Tech
Snow tires
Led interiors
K N drop in filter
Old 08-07-2012, 06:40 PM
Daythread831 Daythread831 is offline
newbie
no. but it makes installation alot easier
Old 08-07-2012, 07:06 PM
Ef9had Ef9had is offline
2nd Gear
I left everything in the engine bay just had to move the battery over a bit
Sent from my iPhone using AG Free
Old 08-08-2012, 06:39 AM
Danielc409's Avatar
Danielc409 Danielc409 is offline
Sugar coating for you ..
Boy this hasn't been beaten to death ..
2011 Subaru STi - Stage 2 - Plasma Blue Pearl
My member journal / build thread @ IWSTI
2008 Honda Accord Coupe V-6 EX-L AT NBP
No longer owned
Old 08-09-2012, 01:59 PM
XenonDepot's Avatar
XenonDepot XenonDepot is offline
DriveAccord Sponsor
lol
OP: as you have already found you can install a kit without removing the front bumper. Just take your time removing the fender liner and you will be able to access the area you need to access.
Steve
Honda Accord Parts & Accessories - HID KITS - AUTOMOTIVE LED BULBS - FLOOR MATS & LINERS - CAR COVERS - SEAT COVERS
Drive Accord Coupon Codes:
HID Kits: "DA" Save $25 | LED Bulbs: "DALED" Save 15% | Need a Coupon code? Just Ask!
DriveAccord SUPER SALE is on now!! - SAVE $$$
SPECIALIZING IN AUTOMOTIVE LIGHTING SINCE 2001 - SHOP WITH CONFIDENCE!!
Old 08-09-2012, 07:56 PM
calvinnng's Avatar
calvinnng calvinnng is offline
2nd Gear
I just installed my HIDs for the fogs without removing the bumper. you just have to be very careful and navigate inside blindly but take your time. You dont have to remove the bumper but why it is best is because you can mount the ballast in a secure place. Im happy with where i mounted them. I dont know how i would describe the location but zipties are going to be your friend, maybe 3M tape. make sure you test everything first too before putting stuff back. and do not use too much force on those fender clips. they are about $2-3 a piece! you definitely do not want to break them and they will break very very easily. Do everything in the fender well one time. the more you remove the clips, the crappier they get and will seem like the fender doesnt even want to go back anymore. good luck
2012 Accord Coupe EX-L V6 AT Taffeta White
HID 6000k lows 8000k fogs| LED conversion interior exterior | Roof lip spoiler | 3rd LED brake light strip under spoiler | Switchback 120smd LED turn signal | 15% back tint. 50% front tint | Takeda SRI | P2R Throttle Body Spacer | Custom Interior Illumination | LED reverse | Debadged trunk | Switchblade | Painted calipers red
