Dyno - Full bolt on 6spd - Drive Accord Honda Forums
Old 08-09-2012, 09:58 AM
Sonnick's Avatar
Sonnick Sonnick is offline
3rd Gear
Send a message via AIM to Sonnick
guys, I don't post much here but I'm on a few other forums (V6P/AZine/6G Accord/J32a/K20a to name a few lol). I have a modded 2006 Accord 6-6. I've had the car since '08, so it's been about 4 years. Below is a before/after dyno graph of some mods I did. Previous mods were:
CAI/Custom Jpipe & collector/PCDs/3in catback/Ported IM with butterfly delete/UR Pulley
Since then I've added:
3.7 TL intake manifold gasket matched
3.7 TL throttle body maxbored (81mm/72mm)
Polished runners
Here is the graph below comparing before/after. Basically an intake manifold/TB upgrade. Loving the gains
Here is a speedo run I did as well (25~100). It's in mid 80s heat, but still pulls hard.
2006 ASM 6-6 Coupe
270/227 SAE Corrected
Best Pass - 13.46 @106.66
Old 08-09-2012, 10:14 AM
CYANiDE CYANiDE is offline
VTAKKKK
Send a message via AIM to CYANiDE
Where in Long Island are you? I want to hear this in person lol.
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles]
FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI
Old 08-09-2012, 10:26 AM
Sonnick's Avatar
3rd Gear
Hicksville/Plainview area.
2006 ASM 6-6 Coupe
Old 08-11-2012, 05:47 AM
Dan Dan is offline
7th gen enthusiast
Wow awesome.. the car pulls so hard even after 80 mph.
This is something I would love to do to my car. I wonder if the auto tranny could handle it
v6
130,000 miles
goal 350k
Old 08-11-2012, 05:54 AM
07AccordEx-L's Avatar
07AccordEx-L 07AccordEx-L is offline
out of control
^nope auto tranny can only handle up to 250whp and even on 100% stock motor, they still go bad.
The OP is making 270whp as you can see..
Sonnick Are you running a 4" cai? I bet after TL-S cams and a tune you should definitely push around ~290-300 maybe!?
2006 Accord Coupe V6 6MT w/Navigation
Previous:2007 Accord i4 5AT
My 7th Gen V6 6 Speed Build
http://www.driveaccord.net/forums/sh...344#post967344
Old 08-11-2012, 07:33 AM
vossen wheels's Avatar
vossen wheels vossen wheels is offline
www.vossenwheels.com
Very good numbers you got there pulls very good, and also seeing that your already at 99k miles and still running stong.
Old 08-13-2012, 08:53 AM
Sonnick's Avatar
3rd Gear
Thanks guys. I'm really happy about the numbers, but I was more concerned about gains to be honest. I would like to dyno again on a Mustang to see the difference. I'd expect 245/205 or so from a Mustang. I'd rock those numbers instead. Sleeper ftw
Yea the 5ATs do tend to 'go' even on a stock motor. However, there are a few people on Acurazine who have switched the 3rd and 4th gear pressure switches and the trans lasts much longer. Try searching on AZine, a few people have done it.
I still have the AEM V1 CAI which is 3" (76mm) OD. It's probably 71mm or so inside. The TB has been bored to 81mm on the intake side, so I'm going to be upgrading to a 3.5" CAI. That should be ~81mm or so inside, so it should match great. I'm probably not gonna dyno again after to be honest unless they include it in the cost, but I'd guess 275/230 after.
I have no plans for TL-s cams thus far. I just ordered new mounts because mine are toast. I also need to do the timing belt/spark plugs and get new front rotors. I'm doing the motor mounts/timing belt/spark plugs before I head back to the track this fall. To be honest, I probably won't have the intake done by that time, but will try.
2006 ASM 6-6 Coupe
Old 08-13-2012, 09:50 PM
out of control
Any reason why you're not going with a 4" like Jiga and Cubano did? I still think you should get 62a mounts at least. The vibration isn't bad at all. I've had gone through two girlfriends that rode in my car and neither complained about the vibration. Just a thought, I've watched all your 1/4 videos and you definitely don't play around!
Old 08-14-2012, 12:04 PM
Sonnick's Avatar
3rd Gear
Lol @ the girlfriends. My girlfriend HATES riding in my car. My exhaust coupled with broken mounts....omg it's the worst. Even I've been hating it recently. I don't think she would approve of the mounts since she hates everything about my car.
I want to sell/trade my exhaust for a stock one and do a cutout. Love the fact that I could cruise quietly and BWAHHHHHH when I need it.
In regards to the 4" CAI, I'm not gonna relocate my battery which I believe is a must with a 4" CAI. I think the 3.5 would work great considering it would match almost perfectly to the throttle body. But on the other hand, I've seen the K20 gain great power from both 3.5" and 4" intakes, so being a 3.0L V6, I could see the 4" showing bigger gains. Idk yet, we'll see. But I'd rather run a 3.5" CAI and keep my battery up front than relocate it for another 3whp.
2006 ASM 6-6 Coupe
Old 08-14-2012, 12:19 PM
Throwdown's Avatar
Throwdown Throwdown is offline
FORUM SPONSOR
Send a message via AIM to Throwdown
Nice numbers, love these threads.. thanks for posting
Old 08-14-2012, 01:14 PM
spatel133's Avatar
spatel133 spatel133 is offline
5th Gear
what 7thgen trannies only hold 250whp? whatabout 8thgen?
10' coupe 6-6 PMM
~ 5% all around ~ Takeda SRI ~ Custom True Dual Exhaust w/ Shitty magnaflow mufflers :-) ~ P2R Light Weight Stock Pulley~ P2R Intake Runners ~ Megan Ez Coils ~ CT Short Shifter ~ 19' Acura RDX Aspec Rims ~ 18' Rota Torque's ~ 2x Boston G2 Powered by Boston Gt 24 Amp in Custom stealth Box ~
04' VW MK IV 2 Slow
Old 08-14-2012, 01:22 PM
Sonnick's Avatar
3rd Gear
^ The 5AT is a weak trans for both the 7th & 8th Gens. The 6 speed will hold much, much more.
2006 ASM 6-6 Coupe
Old 08-14-2012, 02:04 PM
09cbp6mtsteve's Avatar
09cbp6mtsteve 09cbp6mtsteve is offline
Baba Booey
IMO, the clutch will go LONG before the Tranny will.
Old 08-14-2012, 10:36 PM
out of control
Damn! I used to have an ingalls torque damper on my i4 accord and the vibration was a lot worse than the XLR8 mounts. You could hear the engine bay + crazy vibration. Hopefully you get it fixed. I see you have an NRG damper, which should suffice. It doesn't cause vibration whatsoever.
Relocating the battery will help the weight distribution a little too
Someone told me about the dual throttle bodies that Paul is fabbing up. You should look into those. Once I get the 3.7 Manifold + Bored TB and 4" Cai I will post dyno numbers up. I wanna see how much power my car puts down vs yours and Jiga..
Do you have any plans after that? J36? SC?
Old 08-15-2012, 09:48 AM
Sonnick's Avatar
3rd Gear
100% correct.
Definitely looking forward to your dyno with the 3.7 setup and 4" CAI. The only differences between our setups would be the Jpipe/exhaust/flywheel. You don't have an exhaust yet? Dude! If I were you, I'd do a cutout. Quiet when you want it, loud/powerful when you need it. But that's just me being fed up with my loud exhaust and broken mounts lol.
My only engine plans right now are to get a larger intake and to tune for an increased rev limiter. Oh, and an E-cutout with stock exhaust. I'm considering doing cams in the (couple years) future, but as of now not much more. I'll be happy with a 290whp daily Accord I was surprising people before the 3.7 IM/TB setup. After a tune on the new setup I'm sure I'd be surprising modded 370s. As will you with your setup.
I do want TSX mirrors/coils/front lip/wheels though. We'll see how that goes.
2006 ASM 6-6 Coupe
