08 V6 removal - Drive Accord Honda Forums
Old 08-13-2012, 12:48 PM
SubaruTech84 SubaruTech84 is offline
08 V6 removal
Hey everyone. I am new to the Honda world. I am a Subaru Master Tech. I am looking at buying an 08 Accord Coupe AT with a 3.5L. It has a blown engine. I am doing some research before going ahead and doing it. ALLDATA procedure shows to drop the engine/trans as an assembly out the bottom of the car. I don't want to go through all that trouble if I don't have to. So is there anyone out there that has pulled the motor out the top of the car??? Any help is appreciated!
Old 08-13-2012, 12:53 PM
CtheW0rld's Avatar
CtheW0rld CtheW0rld is offline
1st time honda owner
i have no idea, but welcome to the forum.
2011 Accord Coupe EXL V6 - PMM/Black Leather/Auto & 2000 toyota MR2 Spyder
Old 08-13-2012, 08:04 PM
fastball fastball is offline
Honda Nation
It is probably, actually EASIER to drop the engine out of the bottom since it's assembled in sub sections and put through the bottom.
You probably could take it out through the top but I imagine it being much more difficult to do. If you look under the car it's rather easy to see how the front end sub frame with the entire front suspension, engine, and drivetrain is all together and would be easily removed as one sub assembly.
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver
Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten
Old 08-13-2012, 09:12 PM
Rattmann Rattmann is offline
5th Gear
yes you can but it is harder.. not enough spacing to work around.
The transmission and engine cannot be easily taken apart like in Subaru and not having to open suspension and CVs.
I had a new engine in my 08 accord from honda, and only proper way to do it correctly is the bottom side.
Old 08-14-2012, 04:47 AM
TopSniper69 TopSniper69 is offline
4th Gear
Your saying you don't wanna go out the bottom why? I guess you have a cherry picker and just wanna use that instead of muscling the motor out the bottom? When doing Hondas I put a piece of ply wood under the engine and attach straps to the ply wood. Use the cherry picker to hold the engine while removing all the mounts, slowly lower the engine onto the plywood. Now detach the cherry picker and attach it to the car itself via the engine mounts. Now lift the car with the cherry picker and slide the engine out from under the car via the straps attached to the ply wood. Last lower the car, done deal. Obviously there's alot in between all that but if you've swapped engines before then you already know this. Good luck.
Old 08-14-2012, 07:50 AM
My problem is that the car is for sale almost 2 hours away. I have never looked under the hood of a 08+ Accord 3.5L. I've pulled plenty of drivetrains from the bottom. I worked for Nissan and that is the same way we did them all there. I didn't want to go out the bottom because without a lift it is much more difficult to drop stuff out the bottom usually.
So does this car have a full front cradle for a subframe? Or does it have just a small subrame running front to rear from the core support to the unibody? Do you drop the subframe out before lowering the engine to the ground?
Old 08-15-2012, 08:29 AM
hondaracer4vtec hondaracer4vtec is offline
Hondaracer4vtec
Send a message via AIM to hondaracer4vtec
hey, yes you drop the sub frame before removing the engine out. from the bottom is alot better. you can also remove the front out (about two ish hours of labor since your experienced) remove the bottom frames and wheel it out from there.
2008 Accord NBP 6-6 (mine)
2008 Accord TW V6 Sedan (family's)
2003 E500 Silver on Black (lil big bro)
2004 Mercedes CLK500 (sold) (mine)
2000 Accord Coupe ex 2.3L (lil brother's)
1998 Accord Sedan ex-l v6 (dad's)
Old 08-15-2012, 09:12 AM
Edaccord08 Edaccord08 is offline
Out of Control
It has a full subframe (boxed which holds engine, transmission, axle support and steering rack ).
the mounts (4+1) are located like this (front/back on the subframe, pass/driver frame and one small on driver subframe for trans . So 3 on sub and 2 on unibody frame-rail .
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Old 08-15-2012, 11:22 AM
spatel133's Avatar
spatel133 spatel133 is offline
5th Gear
like everyone has already said before, the best way tio drop it is from the lower section. fallowing alldata on this one is the best way to go.
10' coupe 6-6 PMM
~ 5% all around ~ Takeda SRI ~ Custom True Dual Exhaust w/ Shitty magnaflow mufflers :-) ~ P2R Light Weight Stock Pulley~ P2R Intake Runners ~ Megan Ez Coils ~ CT Short Shifter ~ 19' Acura RDX Aspec Rims ~ 18' Rota Torque's ~ 2x Boston G2 Powered by Boston Gt 24 Amp in Custom stealth Box ~
04' VW MK IV 2 Slow
