Car Overheats Going Uphill - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 08-17-2012, 05:52 PM
CDsDontBurn's Avatar
CDsDontBurn CDsDontBurn is offline
Out of Control
Hey guys,
Like my title says, my car overheats when going uphill and I'm wondering what it could be. I'm hoping you guys could help
When I say "uphill" I don't mean a small hill. I mean when doing a 1 mile (or longer) uphill climb at 5% or steeper climb. Otherwise, my car's temperature gauge doesn't go above the half way mark. It's only been at the half way mark because of the area I live at is so hot with the average temperature for the last month being 110F with highs being 120F or so. I know in winter, the temp gauge didn't budge above 1/4 of the way up. But still, regardless of the environment, it still shouldn't go up all the way up just below the "H" line when going on an uphill climb.
For background reference on coolant system maintenance done:
  • the radiator and lower/upper hoses were replaced around 200k miles
  • Water Pump / Timing belt were replaced around 215k mark
I have noticed that since the water pump / timing belt jobs were done, the reservoir tank was empty so I filled it. This happened twice. I checked the radiator coolant level and it was full to the cap, so I'm presuming there aren't any leaks in the coolant system. I'm thinking there might be a small leak in the reservoir tank, but this shouldn't make it so that my car overheats, right?
What do you guys think?
2000 2dr. v6 Accord | Limo Tint | Black housing Crystal Headlights | Greddy MX Exhaust | Magnaflow Hi-Flow CAT | R1 Concept slotted/ventilated rotors - Front | Eibach Pro Springs | KYB-GR2 Shocks | Eibach Sway Bars | DC Strut Bar | 6000k HIDs | Pioneer DEH-P6000UB | Pioneer mid speakers | Matt Tweeters | Kenwood 4ch. 800w Amp | 2x 10" Sony Xplod 800w subs | Sony 1200w Class D Amp
Old 08-17-2012, 06:49 PM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
If the reservoir keeps going empty, you are losing coolant somewhere. I doubt it is due to a leaky reservoir. The radiator should stay full as long as it can pull coolant from the reservoir whenever the system cools down. Could be your new water pump is leaking or hose connection. Keep looking around the engine when its hot and when its cold.
As for the overheating problem, are both your cooling fans running when it gets hot? Have you ever changed the thermostat? It might not be opening all the way if its old.
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 08-17-2012, 08:55 PM
Out of Control
I know the car isn't leaking coolant from the water pump. The whole reason why the timing belt was changed was because i was leaking coolant from the water pump area to begin with. When my dad replaced the timing belt simply because it was already there to do.
It's been about two weeks since I last checked the reservoir, so I don't know if it's still full or not. I'll check tomorrow again for sure.
I haven't ever changed the thermostat on my car, and I was actually thinking that the thermostat could be the problem. How difficult is it to change out? I know where it's at, but since I've never changed a thermostat that is side mounted. I've only changed thermostats that are top mounted like on most Ford engines.
Old 08-17-2012, 09:11 PM
cjy3 cjy3 is offline
3rd Gear
Do a pressure test on your cooling system, this will help you find the leak. If you are driving at higher elevations and your AC is on your car can overheat. Turn your heater blower to full on and this will help your car cool down. If you keep driving around like this it is going to cost you.
Old 08-17-2012, 10:57 PM
MusicMan374 MusicMan374 is offline
4th Gear
Send a message via Skype™ to MusicMan374
Thermostat sounds likely because your car should be heating up to above 1/4 of the gauge. It should always run around the same temperature, half or just below half, regardless of weather. It might vary a bit but not that extremely.
Anyone who runs the heater when it's over 100 out is insane dude. I'd rather pull over and wait for a cool down than run the heat at those temps.
Old 08-17-2012, 11:13 PM
3rd Gear
If the car keeps overheating,and it keeps being driven that is the insane part DUDE. Roll the windows down.
Old 08-18-2012, 12:10 AM
Out of Control
Where can a pressure test get done for a reasonable price?
I live in the low desert. Elevation is 700ft above sea level. Whenever I visit family, I have to leave the desert and go over a very long but gradual increase in elevation. The last two miles of the increase though is roughly a 5% climb out of the desert. These last two miles is where my car is really hurting and the temp climbs up from half to just below the "H" mark.
Right, I said in my last post that I think it might be the thermostat as well. I also asked how it gets changed out since it's side mounted and not top mounted. Will I have to drain the coolant entirely, or will just whatever amount is in the hose necessary to drain?
During winter on the REALLY cold days, it will go up to 1/4 of the way up. Right now in the summer, it's usually right at or just a line or two above the half way mark unless doing one of these uphill drives.
Old 08-18-2012, 01:10 PM
DJR DJR is offline
3rd Gear
It could be that your water pump is failing. Try putting it in a lower gear on level ground, and see if the same problem comes about after running it at higher rpms for a few minutes.
There could also be air in the cooling system. Try bleeding the air out of the system. When gradually increasing elevation, air pressure changes, and could cause issues if there is air in the system.
Old 08-19-2012, 04:33 AM
dorkiedoode dorkiedoode is offline
Zzzz
When your going uphill are you using AC? Try turning it off and going uphill. I have a corolla that overheats on steep hills when the ac is on.
2010 EX-L V6 NAVI SEDAN
1999 EX V6 COUPE
2006 Si
Viper 5901 DIY
3rd Brake Light LED Conversion
I unlock iPhones! 3G 3GS 4 4S 5
Old 08-19-2012, 11:02 AM
Out of Control
I'll have to try the lower gear thing later today.
With air in the cooling system, couldn't i just leave the radiator cap off, drive my car around for a little bit and when the pocket of air reaches the open area of the radiator the pocket of air will just stay there?
It never used to do this though. Last year I did plenty of mountain driving with the AC turned on and my car never overheated.
Old 09-06-2012, 01:28 PM
Out of Control
So I'm finally going to tackle this issue, but I have a question about thermostat replacement. Does it NEED to be directly from Honda, or can any of the ones in the link below work just fine?
http://www.napaonline.com/Catalog/Re...0032%2b2032004
Old 09-06-2012, 02:04 PM
09cbp6mtsteve's Avatar
09cbp6mtsteve 09cbp6mtsteve is offline
Baba Booey
90% of napa parts are very good quality I wouldnt worry about going OEM, just dont get the cheapest one either. I might of missed it, or I am just a 6th gen noob, but is there a fan that kicks on with the temp, and or AC engagement?
Old 09-06-2012, 03:07 PM
Out of Control
The coolant fan spins without issue and so does the AC fan when that is turned on.
Old 09-06-2012, 09:10 PM
Zzzz
When the car is at op temp touch the radiator hose. If they are both hot then i highly doubt its the thermostat.
leaks in the reservoir will/can cause overheating issues.
1999 EX V6 COUPE
2006 Si
Viper 5901 DIY
Old 09-06-2012, 11:26 PM
Out of Control
I've filled the reservoir tank slightly above the "max" line about a month ago and it hasn't gone down since then. I removed the radiator cap and like always, the fluid was right there in my face. So I can say that there aren't any leaks in the coolant system.
I ended up purchasing the thermostat from the my local dealer anyways because I needed to buy something else for my car that i couldn't find at any auto parts store. So, I'll replace that and see what happens afterwards. Hopefully the issue goes away.
