B1234 Minder 100k calculated costs - Drive Accord Honda Forums
Old 08-20-2012, 05:30 AM
birdsofprey02 birdsofprey02 is offline
2nd Gear
Just got the Maintenance Minder B1234 which is a big one.
2008 Accord V6, AT, EX-L with Nav, 4dr, 105k miles
I'm guessing with the 4, I get new spark plugs and a new timing belt? I think my dealership changes out the water pump as well. Does engine coolant get replaced during this or just what is lost during the service?
Two dealerships I usually go to in MD
Laurel Honda - $1900
Bel Air Honda - $1000
The Bel Air estimate was just the girl on the phone adding everything up in her head. The Laurel Honda lady mentioned that the 4 (plugs and timing belt) was a $1500 service alone.
Did the Bel Air adviser miscalculate over the phone or is the Laurel quote just way overpriced?
Also, I know that one of the "features" of my car is that it needs no scheduled tune up until 100k miles. Is this B1234 considered my first "tune up?" other than the regular fluid changes (brake, oil, at)
Any thoughts appreciated..!
Mike
2008 Honda Accord V6 AT W/Nav
Old 08-20-2012, 06:03 AM
falashan's Avatar
falashan falashan is offline
I am pretty sure you also need to have the valves adjusted for an additional $500.
I was quoted +/- $2,000 for everything here in New England.
Since I also needed tires for about $1,000 I traded in the 2009 for a 2012.
I couldn't justify spending what amounted to 6 months car payments on a vehicle with 100K miles.
2012 V6 6MT Coupe San Marino Red on Ivory
Back up camera
TSX 17mm RSB
Old 08-20-2012, 06:18 AM
olemissfan76 olemissfan76 is offline
08 Coupe owner
I have the 4 cylinder and there is no way in hell I am spending $1900 on my engine for 100k maintenance.
Ill trade it in for a Nissan in a NY minute before Ill do that considering the problems I have had already with my car.
Old 08-20-2012, 06:58 AM
Gearhead82's Avatar
Gearhead82 Gearhead82 is online now
3rd Gear
You don't have a timing belt so I'm sure your 100k maintenance will be much less expensive.
_____________________
2012 6-6 Nav
Old 08-20-2012, 07:40 AM
Pete240z Pete240z is offline
4th Gear
Wow!
2011 Accord Sedan LX 5-spd Alabaster Silver
Acura rear sway bar 17mm upgrade
Aftermarket window visors
Old 08-20-2012, 08:17 AM
Hytekazn's Avatar
Hytekazn Hytekazn is offline
4th Gear
Send a message via AIM to Hytekazn
This is probably the only Bragging Rights any 4 cylinder own has is Not having to touch the timeing belt because we rocking a chain. But that water-pump.
Current Ride
_______________________________
-08' Honda Accord LX i4 sedan.
Mods
-Aftermarket Fogs installed w/ 3000k HIDs
-5000k HIDs installed in headlights
-25/35 tint front/rear
-Sound system - Rockford 300watt amp, Boston acoustics SE60 components, Rockford Fosgate 10inch sub.
^ Happy Camper.
Old 08-20-2012, 08:21 AM
08 Coupe owner
As I understand it, 4 cylinders don't have maintenance till 120k. But at that time yea, chain, water pump,
Old 08-20-2012, 09:19 AM
SatinSilver's Avatar
Moderator
The chain doesn't need or call for replacement at 120k or any other interval. Unless it's defective or causing issues would be the only reason for replacement. The water pump in the 4cyl is only replaced if its leaking. The serpentine belt is normally replaced at the 120k mark.
05 Toyota Matrix XR: Silver, 55k
99 Accord Coupe: 2.3, 166k, original owner.(sold)
94 Civic Coupe: manual (sold with 45k)
83 Cutlass Supreme Coupe: Traded in with 67k.
Old 08-20-2012, 11:28 AM
BlitzMob BlitzMob is offline
4th Gear
Send a message via AIM to BlitzMob
Ouch, a grand for tires? Tire Rack
2010 Accord Coupe, EX-L V6 MT
