Please help me with wiring! - Drive Accord Honda Forums
Old 08-21-2012, 07:54 AM
ediot's Avatar
ediot ediot is offline
So I've purchased these from TRS
http://www.theretrofitsource.com/pro...ducts_id=14906
I was wondering if anybody can help me with some wiring.
Hoping to put these halos in soon but I'm just scared of the wiring business since this will be my first attempt.
I would ideally want to have it as part of my drl and night time driving lights.
Which wires will I need to tap into? and Is it safe to tap into DRL? would it throw off the voltage and result in damage?
I'm a complete noob at this.
All help is much appreciated.
Thank you in advance!
2008 NHBP Honda Accord Coupe Ex-L V6 w/ Navi
HFP body kit/ Tints 20% Front 15% Rear/ 5000K HID low beams/ Amber fog lights/ '09 TSX Switchblade/ LED Blue interior/ LED Hyper White Plates/ 19x8.5 5Zigen ZR+520/ Falken FK452 235/40/19
/ KP beeper/ Plasti-dipped Front Grille & Badges
Give me a gun and call me Superman,
Give me two and call me GOD
Old 08-21-2012, 11:30 AM
MrGrizzlySteven's Avatar
MrGrizzlySteven MrGrizzlySteven is offline
you can tap into the drl wire or you can run it from your fuse for drl. i like going with the fuse box because if something goes wrong all you have to do it check the fuse or ground. you dont have to worry about messing up the wires to your headlights. i use add a fuse, you can pick them up at your local autozone... link below
http://www.autozone.com/autozone/acc...ier=32416_0_0_
2008 accord coupe i4 AT nighthawk black pearl
plastidip stock wheels,tinted reverse lights,magnaflow muffler 14818
Old 08-22-2012, 06:50 AM
ediot's Avatar
If I do this, would I only activate my halos when the DRL is running?
If i turn on to get my night lights will the halos turn off?
Old 08-22-2012, 08:52 AM
yes only when your drl are on will the halos be on. if you want them on while driving around at night time then you should tap into your parking lights or parking light fuse
Old 08-22-2012, 05:20 PM
Old 08-23-2012, 05:14 PM
ediot's Avatar
Hmm so what if I wanted to have them on both during drl and at night?
how would i go about doing that?
Old 08-23-2012, 08:24 PM
redcoupe09 redcoupe09 is offline
best bet would be to wire to a switch and flip them on whenever u want them on
Old 08-24-2012, 03:53 AM
mystikal777's Avatar
mystikal777 mystikal777 is offline
3rd Gear
What I've seen some people do is, wire it to the parking lights and during the day, turn the stick 1 click to turn on the parking lights. I've considered doing this, but I realized that turning the parking lights on during the day dims the lights on all your radio/temp settings.
2011 CBP Accord Sedan EX V6
Morimoto Mini H1
Megan EZ Streets
J-Power Camber
TSX 17mm Rear Sway Bar
Old 08-24-2012, 04:31 AM
Nitsucloak's Avatar
Nitsucloak Nitsucloak is offline
You can adjust the overall brightness of radio/temp screen....
I have 4 rings installed hooked up to the parking lights. I removed the DRL fuse and the rings only go on when I switch the light settings one turn. Then another for the auto on/off feature which will turn on the lows for me at night.
