04 accord I4 AT valve adjustment result - Drive Accord Honda Forums
Old 08-26-2012, 04:51 AM
doibung doibung is offline
Accorder
Greetings DA,
After trying to get my valves adjustment done by professionals failed, I decided to do it on my own. I called 3 different local dealers in my area to get a quote and it was way up in the sky ($200+ being lowest ). So I asked my well known mechanic to do my valve adjustment and he said I didnt need it unless something was wrong with the car.
It was the first time I did valve adjustment on any car. The whole process went rather smoothly (I was afraid at the beginning). Even bought a valve cover gasket, but ended up re-using the old one since it looked brand new, nice n clean. Before the adjustment, during idle or stops at the lights, the whole car would shake like it was on an earthquake. Turned out that all my exhaust valves was way too tight, coudln't even just slip the feeler gauge in between. The intake valves, however, appeared to be okay so I just adjusted the no.1 and let the rest be. (Not sure if I made it a bit too lose now)
After I was done, I could hear the engine sounded a little wierd. I dont know if it's normal or not. I took it for a test drive in the neighborhood and didn't feel anything out of ordinary, the whole car is so smooth, no more shaking and rumbling, just the engine's sound that scares me. I've upload it onto youtube so if anyone of you guy could give it a try, I'd really appreciate all the feedback.
BTW, the car has 114k miles on it.
To other people who's thinking about doing it, go for it, it isn't that hard at all, just make sure to get the valve cover gasket and the washers just in case the old ones are worn out. If you have any question, go ahead and post it up, I'll try my best to help
Link to youtube
http://www.youtube.com/watch?v=FhwRo...ature=youtu.be
'04 Satin Silver Accord Cpe EX I4 AT
Finished mods: TSX Mani, AEM SRI, OBX Header, custom suede headliner, dimpled and slotted front n rear brake discs.
Awaiting mods: Iphone adapter, maybe 17" wheels & tires
The Wife's: '07 Infiniti Fx35
Gone: '00 Accord Coupe I4 AT
Old 08-26-2012, 07:18 AM
Toshbar's Avatar
Toshbar Toshbar is offline
<= Jeep differential LOL.
Tagged.
The welfare of humanity is always the alibi of tyrants.
Save the Manuals!
1 3 5
2 4 R
Old 08-26-2012, 08:46 AM
mobiless2's Avatar
mobiless2 mobiless2 is offline
mobiless2
Now they sound to loose, did you warm up car to normal temp before adjustment?
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 248K
2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K
Old 08-26-2012, 10:18 AM
Accorder
I only moved it from outside into the garage... and I let it sit for an hour or so before I worked on it. Also, it was at night so I guessed it had enough time to cooled down if it got warmed up. I think I'll have to do it again tonite just to be safe.
what's the tag for, Toshbar?
Old 08-26-2012, 10:33 AM
Chris333's Avatar
Chris333 Chris333 is offline
4th Gear
So do you think this would help the vibrations that happen at stops with the AC on? My car has 71000 miles on it.
BTW I also have an 04 silver coupe EX I4 AT ; )
2004 EX coupe I4 auto.
Old 08-26-2012, 11:23 AM
mobiless2's Avatar
mobiless2
Metal expand & contracts. It's recommended to do a valve adjustment when warm.
Old 08-26-2012, 11:27 AM
rszappa1 rszappa1 is offline
6th Gear
I have 173,000 on my 07 with no valve adjustement. No noise from valve train so I will leave it alone....
Old 08-26-2012, 12:25 PM
Accorder
Chris: well, from what I've learnt so far, valve adjustment does have somthing to do with the shaking during idle (rough idle) and it helps in my case. BTW, kudos to the silver coupe
Mobiless: this car calls for stone cold when doing valve adjustment, so I guess I try it again tonight when it's really cool
Rszappa1: only the intake valves would make noise when it looses, the exhaust valves won't make any noise because it'll become too tight, so even if you dont hear any noise, it's always a good idea to check the clearance. My exhaust valves were way tight, I couldn't even slip the feeler gauge in them.
Old 08-26-2012, 12:49 PM
6th Gear
All valve adj. that I have done in the past... I am 58... You always do them cold.......not warm or hot....
Old 08-26-2012, 12:57 PM
BLCKFLSH's Avatar
BLCKFLSH BLCKFLSH is offline
Make that BluFlsh
No no no.. You should let the engine sit overnight if possible.
92 EX Sedan auto - sold after 12 years
03 EX V6 Sedan auto - present car
Old 08-26-2012, 02:15 PM
Toshbar's Avatar
The tag was so i could subscribe and read the replies.
Save the Manuals!
1 3 5
2 4 R
Old 08-26-2012, 09:20 PM
Aviography's Avatar
Uh, no.
Yes.
Yes.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 08-26-2012, 10:08 PM
namegoeshere's Avatar
. . . . ლ(ಠ益ಠ)ლ . . . .
to doing Accord valve adjustment when engine is
Here's a good DIY
Old 08-27-2012, 02:21 AM
Accorder
I think I'm due to a follow up. This is my second try. This time I let the car stay in the garage from 6pm till 1am before start working on it. Even so, temperature wasn't much different under this Texas heat, the garage feels really warm. First thing I noticed this time is that my AEM SRI sound louder than my engine (Engine's noise's been taking over the SRI sound the whole time). Hopefully I dont have to do this again for another 30k
Here's link to youtube for sound
http://youtu.be/nRHgZgKkxaE
I find feeling the feeler gauge is the most confusing issue in this process. In some angle it feels loose, another angle it feels tight. Please let me know what y'all think .
Old 08-27-2012, 05:09 AM
Mitchell's Avatar
Mitchell Mitchell is offline
5th Gear
That sounds louder/rougher then the first time. When I need to get mine done I think I'll leave it to the professionals.
2008 Hyundai Sonata GLS V6 - Silver
Previously owned, but not forgotten:
2004 Accord LX I4 Sedan - Graphite Pearl
