Knocking/ ticking sound when first started in morning - Drive Accord Honda Forums
Old 08-28-2012, 09:49 AM
Thinker's Avatar
Thinker Thinker is offline
If I missed it I apologize but I did search on here and on v6p for hours and found nothing about this... with that in mind here goes...
every morning when I start my '05 v6 ex I get a low ticking/ knocking sound. I recently bought my Americcord from a dealer and had them check it out twice before I bought it. They say they found nothing wrong and could not duplicate the sound. It happens every morning! My dad thinks I should just put a heavier weight oil in during the summer. but both of us agree that the car should not be doing this especially seeing as how there is only 66k on it!
My question is this... should I be concerned? should I just put heavier weight (50w) oil in? did I just get hosed?
I have about a thousand miles till the warranty is up!
Old 08-28-2012, 10:01 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
Take it back, leave it overnight, then be there when they start it so you can point out what you hear.
- It is just a car -
2005 Accord Sedan EX-L AT
2009 Accord Coupe 6/6 Black
Old 08-28-2012, 10:08 AM
M6Coupe M6Coupe is offline
My 04 V6 does the same thing. Every morning it makes a ticking sound until it warms up. I only have 78k miles on mine.
I haven't been able to figure it out yet.
I am running 5w20 Mobil 1.
Old 08-28-2012, 10:19 AM
Thinker's Avatar
I'd love to be able to do that however I have to leave for work way before they open every morning.... maybe saturday morning....
Old 08-28-2012, 10:21 AM
Thinker's Avatar
IDK maybe I should just try an heavier weight and see what happens... should probably do that before the warranty goes....
Old 08-28-2012, 12:46 PM
hondaemt hondaemt is offline
03 Honda Accord EX-L V6
My 03 V6 EX has ticked every morning when started when I first bought it 3 years ago. No worries I think its just the rocker arms ticking until the oil is warm. It doesnt flow as well when cold. If the tick goes away after being warmed up its not a rod so I wouldnt worry. I also would not put any oil thicker than 5w-30 in it. I use 5w-20 mobil one as well. Putting oil in thats too thick is definately not good for the motor.
Old 08-28-2012, 04:31 PM
BLCKFLSH's Avatar
BLCKFLSH BLCKFLSH is offline
Make that BluFlsh
Do any of them sound like this?
Click on the pic.
92 EX Sedan auto - sold after 12 years
03 EX V6 Sedan auto - present car
Old 08-29-2012, 03:19 AM
Thinker's Avatar
No it's more high pitched than that
Old 08-29-2012, 07:21 AM
nehonda's Avatar
nehonda nehonda is online now
6th Gear
Check you spark plugs to see if any are loose. Some V6 engines have had issues with plugs getting loose and blowing out. They can make a ticking sound just before letting go. Probably not the problem if it has been ticking for "years".
2000 Accord SE I4 F23A1 Auto @159k miles - My Daily Driver
1998 Accord LX I4 F23A1 5 speed - sons car
1986 Accord LX Auto Totaled @125k miles
1983 Accord LX 5 spd My Second Accord
1978 Accord LX 5 spd My First Accord
Old 08-29-2012, 07:32 AM
Thinker's Avatar
well I think its like he said just the rocker arms because it goes away once warmed up... this morning it didnt even do it... weird.. all i could hear was a heat sheild rattle
Old 08-29-2012, 07:42 AM
SatinSilver's Avatar
Moderator
Is this the same dealer that sold you the car that also checked it out for you? Which dealer since I'm familiar with the Columbus area?
05 Toyota Matrix XR: Silver, 55k
99 Accord Coupe: 2.3, 166k, original owner.(sold)
94 Civic Coupe: manual (sold with 45k)
83 Cutlass Supreme Coupe: Traded in with 67k.
Old 08-29-2012, 08:39 AM
frenzal's Avatar
frenzal frenzal is offline
4th Gear
My 05 6-6 does a ticking sound when I start it and it is cold. After 2-3 minutes of driving, the ticking goes away.
It does it since I changed the t-belt, tensionner, spark plugs more then a year ago.
No other problems or issues since...
Car: Honda Accord coupe 2005 V6 6-speed saphire blue
Old 08-29-2012, 08:46 AM
Thinker's Avatar
yes its the same dealer... its a rather well known honda dealer that starts and R and i believe if you were to look at one of my first posts, the only pic I have posted you will probably be able to figure it out....
And once approved.. in my only album
Old 08-29-2012, 08:58 AM
yi3o8 yi3o8 is offline
4th Gear
I'm not much of a mechanic, but it may be noisy lifters. If it's loose piston rings, you may be burning oil slowly. +1 on nothing thicker than 5w-30, don't use additives.
If it's under warranty, might be worth the effort to ask other places and get what they say in writing.
2005 V6 EX Coupe - Nighthawk black
Moderator
Drop it off the night before. That way it can sit overnight and they can check it out COLD during start up. Arrange for loaner thru dealer or get a ride to work. Usually, on saturdays theres only one or none of the techs working. Just the lube express guys doing the quicky oil changes.
