Engine coolant drain plug - Drive Accord Honda Forums
Old 08-04-2006, 07:19 PM
ThEvil0nE's Avatar
ThEvil0nE ThEvil0nE is offline
3rd Gear
I know for one that some engines have drain plug for coolant, does accord (1999) engines have these anti-freeze drain plug?
Old 08-06-2006, 06:29 AM
SSMV6's Avatar
SSMV6 SSMV6 is offline
39.1 going on 40mpg!
It should. Look for a white plug on the bottom edge of the radiator towards the back of the car.
2013 Accord EX-L Navi 11,178 miles and counting...
<a href=http://www.fuelly.com/driver/SSMV6/accord target=_blank><a href=http://badges.fuelly.com/images/smallsig-us/210024.png target=_blank>http://badges.fuelly.com/images/smallsig-us/210024.png</a></a> . . . . Last tank mpg = 32.2mpg
2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles
1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles
2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles
Old 08-06-2006, 04:20 PM
ThEvil0nE's Avatar
3rd Gear
What you're relating to is the radiator's drain plug. Other than that, what I'm trying to know if the engine itself has it's own coolant drain plug. The reason I'm asking because I want to totally drain all coolant in the system including that of what's still left on the engine (if ever there is still coolant left other than what was drained off the radiator).
Old 08-06-2006, 04:53 PM
James.uk's Avatar
James.uk James.uk is offline
James.uk
AFAIK most modern engines don't have a drain plug, you could always disconnect the lowest water pipe you can find if you are really concerned..
Honda Accord. 2.0iES 4dr automatic. 1996 'N' reg. 87.000. (Burgandy) ave mpg 21. (Best 32) SOLD.
(modified) Citroen ZX 1.9 Diesel Auto 1994 "L" reg. 100K miles, (Dark Blue), ave mpg 44. (Best 55) ECU free.
2002 Wedgewood blue. Rover 75 2.0 CDTi Conniossaur Auto ave mpg 40 (best 52) mpg. :)
Old 08-07-2006, 08:29 AM
SSMV6's Avatar
You meant the engine block drain plug? It may have one, but I wouldn't know about it. Maybe someone else would know. Why do you want to drain all of your coolant? A radiator drain and fill is sufficient for most coolant changes.
Old 08-07-2006, 09:04 AM
BenjiBoy650's Avatar
Try this thread...no definitive answer, but the "speculated" region of the drain plug is also where my auto teacher told me it should be too. Worth a check.
Old 08-08-2006, 06:39 PM
ThEvil0nE's Avatar
3rd Gear
Yes, the engine block... I replaced my original leaking radiator last Saturday with a new aftermarket aluminum radiator (KOYO). Also did a back-flush on the system using water from a garden hose. I know some might not see it as a big deal but I feel the urge and as per instructions of Pro-Blend to get all or most of that water off the system before adding new coolant and use distilled water for tapping. Also, with a new radiator and thermostat... might as well start clean too
As always, I'm using Pro-Blend IceWater which contains no antifreeze during the summer and a mixture of PB-IceWater + EG based antifreeze on winter months.
Originally Posted by BenjiBoy650
Try this thread... no definitive answer, but the "speculated" region of the drain plug is also where my auto teacher told me it should be too. Worth a check.
That would be a nice and worth the check... but where's the thread/link?
Old 08-12-2006, 06:23 PM
James.uk's Avatar
James.uk
Hi Ev-one.. The tap would have to be located on the engine block between the rocker cover and the sump, and where its possible to reach it with your hand to undo it. So if you can't find one it's 99% certain there isn't one..
Title goes here
close
video goes here
