HELP: Annoying whistling sound on rear brakes when stopping - Drive Accord Honda Forums
Old 09-02-2012, 08:46 PM
xesinet's Avatar
xesinet xesinet is offline
X-Gear
Question HELP: Annoying whistling sound on rear brakes when stopping
this has always been a recurring issue almost every year!
I just replaced the rear drums to Brembos (early this year) with OEM shoes (a year ago)
Lately, this whistling sound when stopping came back again.
I used pressurized water yesterday to remove the dirt from the brakes but to no avail.
I suspect my rear shoes are thin & needs to be replaced, since this has been an annoying & recurring issue for 8 years now.
I have had the dealer & different shops inspect this issue but there seems to be no fix...do I need to replace the shoes yearly?
any suggestions or solutions?!!!
2004 Honda Accord LX 4dr/4cyl. Automatic
Satin Silver Metallic
Broadway 300mm Rear View Flat Mirror
Redline Titanium Foot Pedals
Brembo rear brake drums (rusted)
OEM Fenderwell Trim & Splash Guards
Bridgestone Potenza RE960A/S Pole Position tires
Interstate MT51r battery
1" blind spot mirrors
102300k+ miles
Old 09-04-2012, 10:42 AM
accordtech22 accordtech22 is offline
its not normal to change shoe and drum yearly....first check if everything seem in his place no bind adjusment or fixation.check inside the drum for blue color that incate overheating if the case watch for a trouble in hydrolic system or the emergency brake cable jammed maybe if not, jobber part can make noise and lot of dust....rear drum cleanup should be done yearly (removing all dust lubricating moving part with copper antiseize) be sure to you don't have lot of rust on the drum and backplate it can be the cause to, if yes clean everything.for the adjustment tire should rotate for about 1 or 2 rotion by hand force.
Old 09-04-2012, 10:51 AM
I forgot maybe try other shoe than honda one because I know honda had several problem with brake pads back in time
Old 09-04-2012, 11:43 AM
Drew03Accord Drew03Accord is offline
6th Gear
I assume you mean that the brakes are squealing? Years ago, I had an issue with the rear brakes scraping and grinding. I removed the hubs expecting to find them worn down to bare metal but instead, there was plenty of meat left on them. I sprayed everthing down with brake cleaner and wiped out the hub. Worked for a while then about a year later, the same issue again. This time, I replaced the shoes and it's been alright ever since, though I still get a low level scraping at low speed at times.
And it's not just Honda, I just did the same thing (clean out brake dust) on my GF's Corolla. All sorts of horrible noises were emanating from the drums and once again, I thought they were grinding. I believe that after a while, the brake shoes become glazed and in conjunction with the brake dust floating around in the hub, produce the sounds you hear.
2003 LX Sedan, i4 + Automatic. 150K and counting.
Old 09-13-2012, 10:47 PM
xesinet's Avatar
X-Gear
the shop that replaced it told me to take it to Honda...he can remove & sand it for $65 - but for how long?
meanwhile- I have to deal with the mental torture
102300k+ miles
