Amp Mount - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Audio & Electronics
Old 09-09-2012, 08:56 PM
mesamies mesamies is offline
Amp Mount
I am new to running wires and adding an amp. I have been reading a lot of posts in this forum lately and hope I can get everything installed; I have 2 questions. Please help me since I'll be doing this very soon with 8 gauge power cable.
I have Boston Acoustic S95 in the rear, Boston SE 65 in the front and Pioneer T-15 (tweeter). I will be running a Boston Acoustic GTA-704 to power the speakers through speaker level imputs. I'm hoping not to run a sub. Do you know if I can hook all those speakers up to this one amp or should I just not hook up the tweeter (there is no cross over).
Also, I want to mount my amp to the driver side trunk (where it will be out of the way. Do you know if it's something I could do or should I just mount it to the back seat? I don't want to take my passenger seat out. Thanks in advance.
Old 09-10-2012, 12:25 AM
beekayhoax beekayhoax is offline
2nd Gear
.....it depends on how heavy your amp is, if you could support it with some heavy duty velcro, but it will become a pain in the ass when you have to change the taillight bulb.....i mounted mine on the driver side trunk, but laying down, ill try to take pics soon, I ran 0 gauge to the back thru the firewall (theres numerous holes) then split to a 4 gauge...for my two amps.
I suggest you use at least 4 gauge.... What amp are you using?
You should just try finding a cross over for the units.
I have my other mono amp for my sub, screwed into the driver side backseat on the back in the trunk (obviously :| lol)
2009 Accord V6 CBP w/ Navi - AT
WeatherTech Digital Floor Liners & Visors - Switchback LED's - EagleEye Black Tails - Viper
ContourCam - Crosstour Shifter Knob - CREE 9W Reverse LED's - Switchback Turns w/ stock Sedan Yellow Reflector Caps
Mugen Rad&Engine Oil Caps - 'Mug Style' Grill - GutterGuard Lower Grill
Optima RedTop ~ 0 Gauge - Kenwood Class D Mono Amp - Kicker L5 10"
JL Audio JX360.4 - Polk DB6501 Components (Rear Deck/Front Doors) - JL Audio Cleansweep
TSX Rear Sway Bar
HFP 19's
Old 09-10-2012, 05:18 AM
PaulD PaulD is offline
5th Gear
Send a message via Yahoo to PaulD
that's where I mounted my 2 amps and processor, a good choice for location
Originally Posted by hillstones View Post
Whenever I see a "thumpin" car, the male driver is always alone because no one wants to ride in his car.
Old 09-10-2012, 06:01 AM
MacLeod's Avatar
MacLeod MacLeod is offline
Car Audio Junkie
Velcro?!?!
No, no and no! Why? Two words "car-fire". Velcro can come unstuck especially in hot weather and if the amp falls and lands just right, it can short out causing sparks which don't usually mix with trunk liner.
That spot is just fine for mounting an amp but do it right. At least use a piece of 1/4" MDF and put it on the back side of the trunk liner and screw the amp into that. That would support the amp better and make sure it wouldn't fall. Ideally you would bolt it to the sheet metal itself if you can. You don't want your amps bouncing around any more than they have to.
8 gauge wire is good up to about 50 amps. Look at the fuses on your amp and if they add up to 50 or less, you're fine. If there more than 50, you'll want 4 gauge.
2012 Accord EX Sedan • 190 HP 2.4 I4 • 5 speed auto
Old 09-10-2012, 08:41 AM
Thanks for the replies. I'll try to find a cross over to connect the tweeters and 6.5s. As for the amp, I'll seeing that it has two 25 amp fuses, so I think I can run 8 gauge cable. I really like the idea of mounting the amp (Boston Acoustic GTA-704) on the driver side of the trunk. I'll only be running this one amp. I'm not interested in running a sub at this time. Again, Thanks for your replies.
Old 09-10-2012, 02:21 PM
DrivenDaily DrivenDaily is offline
94 Accord EX
If you want to mount it vertically on the driver side of the trunk, you could build a perch for it. Take some mdf or plywood and make an L shaped mount and secure that to the bottom of the trunk. I think it would be hard to secure it right to the side, because the liner isn't strong enough and theres quite a gap behind that to sheet metal in some places.
Old 09-11-2012, 03:48 AM
5th Gear
I have pics on here somewhere where I show how to make an amp rack/board for the same area in a 6th gen.
Old 09-11-2012, 04:22 AM
keep_hope_alive's Avatar
keep_hope_alive keep_hope_alive is offline
Acoustics Engineer
here is how i did mine in the driver's side
http://www.caraudio.com/forums/car-a...-its-long.html
removed the trunk liner, and made a mount with wood (painted)
stuffed the cavity with foam to cut down on resonance
mounted two xtant 403a amps to a board that was sized for the amps.
then made panels to flush the amps
end result (this was back in 2007)
another later version everything except the amps is different here (this is current)
2001 Honda Accord EXV6 J30A1 4AT (160kmi.)
Click for my BUILD LOG (150,000+ views)
Electrical basics and Car Audio (click links below):CA
Interactive Frequency Chart -- Ohm's Law --- Wiring Harness Color Codes--- Wire Sizing Chart --- Fuses!!!
Old 09-11-2012, 04:25 AM
Acoustics Engineer
i have since done a similar mount to the passenger side
Old 09-11-2012, 04:29 AM
Acoustics Engineer
whenever i make an amp mount, i use t-nuts for amplifier/processor mounting. typically 10-24 thread/pitch. i will use cardboard for mock-up, to ensure things fit where i want them.
i always screw or bolt the board in place for rigidity. nothing moves or could move. sometimes you have to make several pieces to achieve the mount you need. metal L-brackets can come in handy for mounting.
