Parts to Replace with Struts?
Hey Driveaccord!
It's been a long time since I've been active on here but I'm kinda back. I joined the Air Force and I'm finally getting back around to customizing my baby. ![]() I picked up a Tokico HTS kit and I have some Tein S.techs on the way. Since I'm planning on doing this job myself and would like to buy everything before hand, I need to know what all parts should be replaced when changing out struts. (I.e. any rubber parts, bolts that could strip easily, etc???) Also, what type of grease do I use on bushings? Thanks for the help! Josh
Her name is Nikki and she runs like a banshee: 07 4dr Ex-L V6 6mt - Bronze Gm Syncromesh Fm, TL-S sway bars, Ingalls torque damper, Stage 1 exhaust mod, Intake resonator delete, short shifter, RV-6 V3 j-pipe, RV-6 V3 PCD's, P&P intake runners, semi-ported/polished intake plenum with custom throttle body spacer, TL-S trans mount, 06 TL 5 spoke rims |
| Sponsored Links | ||
Advertisement | ||
Just installed my HTS, just check the top hats. Mine were in great shape so I reused them. Make sure you have at least one rear camber arm. Any lower than 1.5" in front and you will need front adjustable ball joint.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 248K 2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K |
If you replace the mount kits (rubber mounts) get quality stuff. I replaced mine with NAPA and midas brand (that replaced the failing NAPA one) with not the best luck.
03 Accord LX I4 5spd, 216k miles. with 19 HFP Wheels and Eibach pro spring kit (second set as the first set of rear springs rusted apart). Previous car: 98 Civic EX 5sp. with 155K, RIP |
How do you like them?. Mine are on the way and I was a little curious. Also did you adjust the settings and if you did what did you set them to?.
Very surprised, car feels like factory just slightly tighter. Have not adjusted shocks yet. Will be increasing firmness today. One click at a time till I find my sweet spot.
So I checked the top hats and they seemed slighly pliable. Not really sure what to look for lol.
If I buy new top hats, what brands are recommended? Also, the stock shocks have the rubber covers to prevent debris on the rod. What is recommended to replace these? I'm not really wanting have to replace these things multiple times.
If you want to upgrade the top hat rubber bushings, you have the option of using the TL-S bushings. They're more expensive but are stiffer.
http://www.heeltoeauto.com/honda-gen...pe-s-spec.html http://www.tsxclub.com/forums/1st-ge...-top-hats.html I just bought the HTS and H-Techs, and plan to order the TL-S bushings. Hope this helps. |
I didn't buy any new parts when I installed my hts's and s-techs. My car had 120k and everything looked good. Front camber was within specs but the rear needs camber arms. I have the struts set at 2.75 turns from the stiffest setting. Rides like oem!
Filling a need-2006 Accord EX manual 5spd sedan |
I didn't even know the TL-S used different bushings. I will look into those. Thanks.
A couple of questions to go along with this thread.
03 EXL I4 I am not planning on any custom springs or struts. I am told my compliance bushings are cracking. What are those and where are they located? Second, I need to do front struts as well. Can I do this myself? I'm able to do my own brakes etc. so I'm fairly comfortable mechanically. Is this difficult? Is there a tutorial somewhere on the site or should I just buy a manual to help guide me? What else should I replace when I'm taking everything apart? Also any suggestions on aftermarket standard struts? I seem to like KYB, no particular reason though. I question Monroe. If their struts are only supposed to last 50k as they recommend, that doesn't inspire much confidence. Thanks for any help!!
Mine - 2003 Accord EX-L 5M Sedan - Satin Silver '03 TL-S 17" Wheels, TL 17mm Sway Bar, TSX Intake, 65mm Throttle Body, Cold Air Intake Wife - 2010 TSX - Premium White Pearl Extra/Dogs - 2000 Sienna Daughter - 2006 Corolla Once upon a time: '83 Civic 1500S, '85 Accord, '87 Integra, '90 Mazda B2600i, '94 Accord |
Which will lead you to this ultimate compliance thread on acurazine http://tl.acurazine.com/forums/showthread.php?t=707888 Quote:
http://www.driveaccord.net/forums/sh...ad.php?t=45260 Quote:
here are a few http://www.driveaccord.net/forums/sh...ghlight=struts http://www.driveaccord.net/forums/sh...ghlight=struts http://www.driveaccord.net/forums/sh...ghlight=struts
Thx for the quick response and great info!
Compliance bushings are known to tear. Unless they are bad, I wouldn't even worry about them. Make sure you do it the right way (pushing in a new bushing) instead of replacing the whole control arm.
| Sponsored Links | |
Advertisement | |
