Synthetic for a V6? ATF Change? - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Fluid Dynamics
Old 09-26-2012, 03:04 PM
Conrado Conrado is offline
Smile Synthetic for a V6? ATF Change?
I have heard that conventional is the only way to go on a V6 Accord. True or False? Also when should you change out the transmission fluid. I have only had the car for about a month. So I was curious. The car is a 2007 by the way.
Thanks
Old 09-26-2012, 03:13 PM
G26's Avatar
G26 G26 is offline
3rd Gear
Trans should be done every 30k miles I think. Synthetic oil is fine to use and won't break down as fast as conventional oil.
Sent from my iPhone using AG Free
Previous - 2011 Mazdaspeed 3 - fully bolted/tuned 300whp 320wtrq
Current - 2010 Accord EX-L V6 Coupe - K&N SRI / 4300k Volt HIDs
Old 09-26-2012, 03:19 PM
I hear something about changing the ATF Filter also. It is not listed in the maintenance book tho. Any thoughts?
Old 09-26-2012, 03:34 PM
09cbp6mtsteve's Avatar
09cbp6mtsteve 09cbp6mtsteve is offline
Baba Booey
V6 AT filter is not serviceable like the I4 unfortunately. I have done more ATF flushes/ drain and fills with Amsoil full syn without any problems for 4+ years now. Not 1 complaint. Do'nt stress or worry about it brotha. They also make a flush you might wanna think about using too if you are going to pull the lines off and flush the whole system. Let me know if ya want anymore info.
Old 09-26-2012, 03:40 PM
Cool Thanks Fellas.
Old 09-26-2012, 05:13 PM
ypsibird's Avatar
ypsibird ypsibird is offline
6th Gear
If you're interested in changing your trans filter here's a good thread about it. The filter is serviceable on a 7th gen V6.
http://www.driveaccord.net/forums/sh...ad.php?t=13804
2006 Accord Coupe silver 6 speed
