Magnet tool - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Off Topic > The Pit
Old 10-04-2012, 02:12 PM
GoLowDrew's Avatar
GoLowDrew GoLowDrew is offline
Low Gear
Magnet tool
I'm going to get one of those magnet tools that, for example, if you drop a bolt, it will pick it up.
One of them advertise saying it can pick up 2lbs. I know a bolt is not 2lbs.
But from your experience (working around cars), is that good enough?
I like to buy once, one tool. And not come across a job that will make me buy another one later.
Recommendations or advice?
2010 Accord EX-L V6 Sedan.
2009 Odyssey EX-L RES
Old 10-04-2012, 02:26 PM
Aviography's Avatar
More than good enough, I had two, one with a flexible neck and the other collapses into a pen, but somehow I lost the collapsable one, I have used both and they can be life-savers!!
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 10-05-2012, 01:30 AM
The Pope's Avatar
The Pope The Pope is offline
Just another old guy ....
Now something else to think about ..... the stronger the magnet, the more it will want to attach itself to other steel parts as you are fishing out something.
Just saying ...... stronger is not alway better.
The Pope
Things that we go thru that don't kill us, makes us stronger. What we learned from these events are now tools in which we can use to help others.
My youngest son, RIP 10/3/2004 (He was 19 at the time)
My mom, RIP 4/6/2011
Forum Rules: http://www.driveaccord.net/forums/sh...ad.php?t=19181
Old 10-05-2012, 03:51 AM
ikethegreat's Avatar
ikethegreat ikethegreat is offline
Carpe Diem
^^ Exactly. 2lbs should be just about right.
Old 10-05-2012, 07:30 AM
GoLowDrew's Avatar
Low Gear
Thanks to all.
Old 10-05-2012, 10:35 AM
frenzal's Avatar
frenzal frenzal is offline
4th Gear
I should really buy one of these, could be useful!
Car: Honda Accord coupe 2005 V6 6-speed saphire blue
