Tail light Question - Drive Accord Honda Forums
Old 10-05-2012, 01:31 AM
JBeRRy JBeRRy is offline
Tail light Question
I have an 04 accord ex 4 dr 4cyl auto and the right brake light doesnt lite up when i press the brake. But when I hit lock or unlock on my key fob it does lite up. Is this a simple bulb or is there a wiring issue. It looks like theres only 2 bulbs in the tail light the reverse light and the brake light but im not sure so i thought i would ask you guys. any info is great thanks
Old 10-05-2012, 02:15 AM
Mitchell's Avatar
Mitchell Mitchell is offline
5th Gear
Chances are its the bulb that needs to be changed.
2008 Hyundai Sonata GLS V6 - Silver
Previously owned, but not forgotten:
2004 Accord LX I4 Sedan - Graphite Pearl
Old 10-05-2012, 03:49 AM
bc626's Avatar
bc626 bc626 is offline
6th Gear
+1
Shouldn't you have a turn signal bulb as well? Good luck with it!
Old 10-05-2012, 10:13 AM
thanks im going to change it and find out i just wanted to ask because when i hit the lock or unlock on my keyfob from the outside it looks like the same bulb as the brake light that blinks. anyway thanks again i am going to change it asap
Old 10-05-2012, 10:26 AM
frenzal's Avatar
frenzal frenzal is offline
4th Gear
Probably a two filaments bulb.
One of the filament is probably dead.
Be sure to buy the right bulb and you should be OK!
Car: Honda Accord coupe 2005 V6 6-speed saphire blue
Old 10-05-2012, 03:04 PM
Phlip96's Avatar
Phlip96 Phlip96 is online now
4th Gear
^ What he said!
It i in fact a dual filament bulb, one lamp when your lightsare on and thesecond filament makes it real bright to signal you are stopping.
Do or Do Not - There is no Try
Old 10-07-2012, 10:04 AM
vasekvi's Avatar
vasekvi vasekvi is offline
5th Gear
Send a message via AIM to vasekvi Send a message via Yahoo to vasekvi
replace bulb as others say. brake light filament is out, but parking light filament is still ok.
My 2003 SSM Sedan Build Thread
http://www.driveaccord.net/forums/sh...ad.php?t=39065
