Oil Dipstick - Am I a complete idiot? How to read
How do I get a proper reading with the dipstick? Sometimes when i check my oil, the dipstick works, other times, I just get splashes of oil all up and down the dipstick. I noticed with my latest oil change I wasn't really able to read my dipstick, as oil would just be all over the place no matter how many times i dipped and looked at it.
Turns out about 3000 miles in I took it to the mechanic to get a state inspection he let me know I was short about half a quart. With my dad's 96 camry I noticed the bottom of the dipstick kind of has a texture to it so the oil seems to stick to it and am able to read it consistently. with the accord it's just a smooth surface and oil just seems to get anywhere on it and can't read it properly. Am I doing it wrong?
2007 Accord Coupe EX-L auto I4 Nighthawk Black Pearl w/ HFP body kit Mini H1 HID's oem foglights 99000 miles 35% Tints Kenwood KDC-X993 head unit w/ Alpine PDX 4.150 Amp and Focal Access 165 A1 component fronts, 690CA1 rears Other Cars that i maintain 2007 Lexus RX350 70000 miles |
| Sponsored Links | ||
Advertisement | ||
Are u wiping the dipstick off b4 u check it? Make sure the car is on a flat surface take the dipstick out wipe it clean stick it back in then pull it out and u should have a clear reading
Sounds like you have either too much or to little. If it is past the textured part there is too much if its under there is too little. Post a pic
omg!! sell ur car!! get a bicycle!!
How much oil are you putting in the car during oil changes?
I start off with 4 quarts. Check the level. Add a little. Check. Add a little. Check. Add a little. Until the reading is where I like it. Capacity for 4cyl = 4.2Liters/4.4 Quart
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 57k miles |
Hey, with gas in CA being $5.24/Gal right now, that might not be out of the question OP! lol
Ben '07 EX-L V6 Coupe w/ Navi Graphite Pearl / Black Leather TL Bi-Xenon Retro | TSX LED Mirrors | Spec-D Fog Lamps | 30% Tint | Alpine Sub System | BlitzSafe AUX | USA Spec BlueTooth OEM HFP Kit | OEM Visors | Trunk Spoiler | CCD Back-up Cam | Tein Coilovers | Ingalls Camber Kit | H&R TRAK+ Winter: Honda 18" 10-Spokes / Continental DWS Summer: Hyundai 19" Dual 5-Spokes / Hankook V12 Evo |
Sent from my iPhone using AG Free
*2009 Honda Accord Ex - Sedan *Taffeta White *8000k HID *PUTCO LED lightning *Infinity Kappa 692.9i Speakers/4 Channel Amp *Audio Control LC7i *JL Audio W6 on the way soon....... More mods to come when life gets back on track.... |
Haven't seen it for $5.24 in the bay area yet. It is around $4.69.
turn the car off. let it sit for a few seconds. pull dipstick, clean it and put back in to check the oil level. Once you pull it back out it should be between the two dots.
07 Sedan 94 N/A H22, ported head, s2p1 cams, s2vt, flat valves, blacktrax intake mani, euro R tb ported 70-65mm taper, hyptech rep header, Enkei Evo 5, Ground control, tokico struts. |
A few seconds is not enough for the oil to drain back into the pan. The best time to check oil is with a cold engine as the oil is also fully drained from the dipstick stalk. If the car has just been shut off, you need a few minutes... about the amount of time it takes to pump a tank of gas.
2003 LX Sedan, i4 + Automatic. 150K and counting. |
You need to wait a few minutes, and let the oil drain out of the dipstick tube. Give it at least 3 minutes, and you should be able to read it clearly.
92 EX Sedan auto - sold after 12 years 03 EX V6 Sedan auto - present car |
If you wait a few seconds and you are between the min and max then you are fine. No need to wait a few minutes. If it looks low then you are probably low a little. Very little oil gets in the tube. Hell the whole thing could only hold a few ounces, which is not nearly enough to throw off the level. Also most of the oil stays in the oil pan. Very little oil is pumped through the motor. If you just wait a few seconds to check the level and it looks to be at the min line then you are low on oil...if you fall at the middle to top...you are fine.
It needs to sit for several minutes if you want an accurate reading.
| Sponsored Links | |
Advertisement | |
| Tags |
| oil dipstick dumbass |
