Accidentally turn ignition when engine is running - Drive Accord Honda Forums
Old 10-12-2012, 04:01 PM
tenpercent tenpercent is offline
Hi folks,
I have a 8th gen 2009 Honda Accord V6. I have had a couple of incidences that I forgot the engine was running because it was quite quiet when the engine was at idle and the turned the ignition key. As soon as I heard the cranking noise and knew the engine was actually running, I immediately released the key. I would like to ask you folks to see whether I have caused any damages to the starter motor and/or engine/transmission due to my stupid mistake.
Thanks,
Own 2 accords
Old 10-12-2012, 04:05 PM
drowned12's Avatar
drowned12 drowned12 is offline
5th Gear
I can't imagine on a modern car that it's possible to do engine damage by making such a common mistake....ratchet gear to prevent the starter engaging the crankshaft?
2012 Accord LX AT Sdn Taffeta White - "The Sleeper Speeder" - Stock Appearance - DYNO RESULTS && 127 MPH TOP SPEED RUN
Takeda SRI
Ported Intake Runner
RV6 PCD
Underdrive Pulley Set
UR Full Chassis Kit + 22mm Sway Bar (7 pieces)
Akebono Performance Pads
Group 24F (V6) Battery Upgrade
Fuel Pump Kill Switch
RX65 Radar Detector || Blinder HP-905 Laser Jammer || Nexus 7 tablet + Scantool MX|| Dash Cam || License Plate Flipper || LED Brake Lights || Weathertech mats
Old 10-12-2012, 04:16 PM
Pete240z Pete240z is offline
4th Gear
Once or twice might not hurt. Worst case new starter and/or flywheel.
Just like at a restaurant when they drop a platter of plates - gets everyone to yell and scream WHOA! LOL.
2011 Accord Sedan LX 5-spd Alabaster Silver
Acura rear sway bar 17mm upgrade
Aftermarket window visors
Old 10-12-2012, 04:24 PM
Aviography's Avatar
You will ALREADY have known if you've actually caused damages, just smile and keep on driving.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 10-12-2012, 05:19 PM
fastball fastball is offline
Honda Nation
One feature GM makes standard on their cars now and I would like Honda to have is starter protection. When you turn the key on any GM car made in the last couple of years, it's completely computer controlled. It only turns the starter for the absolute minimum amount of time it takes for the engine to fire up. If you hold the key long, you will do absolutely no damage as the starter stops turning the second the engine is running, no matter if you're still holding the key or not.
And if you turn the key while the engine is running nothing happens!
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver
Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten
Old 10-12-2012, 07:29 PM
2010accordv6 2010accordv6 is offline
5th Gear
Being a gm you turn the key when its not running and nothing happens?
Old 10-12-2012, 08:40 PM
ZeroTX ZeroTX is offline
4th Gear
Yep, my 2004 Chevy Colorado was like that. You just basically bump the key and it will start the truck, whether it takes 3 cranks or 10, it figures that part out. Also makes for flawless remote start.
2011 Accord EX-L (A5, Polished Metal Metallic) - Daily Driver
2001 Mustang GT (A4, Mineral Grey, factory Bullitt wheels, Flowmasters, CAI) - Weekend Cruiser
Old 10-13-2012, 12:55 AM
bc626's Avatar
bc626 bc626 is offline
6th Gear
I do that myself once in a while. You won't damage your engine unless you do it everytime you start the car.
Old 10-13-2012, 06:32 AM
glen e glen e is online now
Retired from Car Biz....
I think we can agree if you do it more than once, you are an idiot. If so, then practice looking at your tach before turning the key.
'13 EX-L I4 COUPE
STEEL/BLK
Click here for pics
New Accord? Click here for a good PDF detail procedure
Other car: `13 Camaro 6.2L 2SS
Old 10-13-2012, 07:04 AM
4th Gear
I have to admit that it's a little disappointing that the Honda electronics don't automatically prevent you from doing this.
Old 10-13-2012, 08:07 AM
Bandigo's Avatar
Bandigo Bandigo is offline
The Scratcher
shit happens :]
-2010 V6 Coupe-
-Focal 165VRS speakers/Focal 33v2 Subwoofer/Alpine CDA 9887 headunit/Lrx 2.4 Audison Amp/Lots of deadening-
Old 10-13-2012, 08:14 AM
Originally Posted by Bandigo View Post
shit happens :]
Correct... Happens to idiots....
The key here is "more than once"....
'13 EX-L I4 COUPE
STEEL/BLK
Click here for pics
Old 10-13-2012, 08:23 AM
MacLeod's Avatar
MacLeod MacLeod is offline
Car Audio Junkie
That is weird that in this day and age you can still grind the starter like this. I did this a time or two on my old Ford Edge and if you turn the key with the engine running, nothing happens. I need a safety feature like that cause I have the attention span of a 4 year old and if anything distracts me after Ive cranked the engine, Ill likely try to crank it again.
2012 Accord EX Sedan • 190 HP 2.4 I4 • 5 speed auto
Old 10-13-2012, 10:43 AM
Bandigo's Avatar
The Scratcher
subtle.
-2010 V6 Coupe-
Old 10-13-2012, 02:19 PM
It is not like that we do that on purpose. Over about three years of owning my car, I could remember I have done it twice partly because the car engine is quite quiet at idle and partly we could at times get distracted. Say for example, we start our car twice a day on average for 300 days per year on average. The percentage of that happening a couple of times over three years is about 0.1%. With that said, however, having it happen once is already one time too many and is bothersome especially for people who take good care of their cars. Certainly, it is always good that Honda can incorporate electronics in future models to prevent such an accidental ignition turning.
Own 2 accords
