03-07 Spool Valve (VTEC Solenoid) Replacement *Help Needed* - Drive Accord Honda Forums
Old 10-13-2012, 08:57 PM
MikeyThumbs MikeyThumbs is offline
4th Gear
Was wondering if anybody had any info on replacing the Spool Valve Assembly which houses the VTEC Solenoid on an 03-07 Accord.. I have the part already but I'm not sure if I am going to run into any issues when I jump into this. Can't seem to find any info or videos on a newer accord, only a youtube video for a 95 Accord. Any info would be greatly appreciated..
Old 10-16-2012, 08:25 AM
4th Gear
Well I changed the valve this weekend, was a piece of cake!!
I removed the hood to make things easier for myself... had to put the new hood that I had on anyway so it worked out nicely.
The Spool Valve assembly replacement took me all of 25 minutes to complete start to finish.
Turns out there was a sliver of rubber gasket material in the strainer which I think was causing my problem and possibly why it only happened intermittently but time will tell..
I've only put about 35 miles on the new assembly so far, will let you know if I have any further issues
Old 10-16-2012, 08:31 AM
sodaks2k sodaks2k is offline
Moderator
Basically plug and play then? Good to hear it went well.
2014 MSM Accord Sport Sedan 6M
Old 10-16-2012, 08:34 AM
4th Gear
Yup, had a harder time getting the clips that hold the wires onto the valve assembly off then I did removing the actual part You cant really see whats going on back there, gotta kind of just feel for the bolt, get the socket on and loosen/tighten it blind. I used a regular 10MM deep socket and 3/8 ratchet with ease.. So much room back there compared to the video I saw on the 95 accord!!
Old 10-16-2012, 10:23 AM
Coley909's Avatar
Coley909 Coley909 is offline
5th Gear
What kind of problems where you having to need to replace this part?
07 Accord SE i4
kenwood 6.5 front
Sound ordinance 6x9 rear deck
Blitzsafe AUX input
18 inch wheels 245x45x18
Tint 20% rear 35% front
Parrot MKI9200
Old 10-16-2012, 10:40 AM
4th Gear
CEL was throwing code P2647: Rocker Arm Oil Pressure Switch (VTEC Oil Pressure Switch) Circuit High Voltage
The car would get to 2500-3000 RPM and under ANY type of gas applied would bog and shake violently almost like a rev limiter being hit at 3K rpm..
Did some research and since my oil was at a normal level, next step was replacing the vtec solenoid. Seemed easier and a little more sensible to replace the entire spool valve assembly which houses the solenoid. I could have just replaced the gasket, but the guy at the dealership told me that the VTEC solenoid was $80+ and the new entire spool valve assembly was $111. I wanted to see what the screen inside the old assembly looked like anyway so I just went for it.. Lucky for me that I did decide to replace the entire assembly though as I mentioned I found a big piece of gasket in there which I think was causing my issue.
Old 10-16-2012, 11:36 AM
Coley909's Avatar
5th Gear
Ahh good to know incase it ever happens
07 Accord SE i4
kenwood 6.5 front
Blitzsafe AUX input
Parrot MKI9200
Old 10-19-2012, 08:53 AM
4th Gear
So far have about 100 miles on the new Spool Valve assembly with no issues ::knocks on wood.:: Next week is a heavy driving week for me, will put about 350+ on her.. I'll let you know how it goes.
Title goes here
close
video goes here
