K&N Intake Quesiton - Drive Accord Honda Forums
Old 10-14-2012, 07:27 PM
tlambrop tlambrop is offline
K&N Intake Quesiton
Recently purchased a 2012 EXL v6 coupe. I am looking to get a new cold air intake and I see a K&N intake from College Hills Honda for about $260. I have two questions:
1) Has anybody ever had any bad experiences with the K&N Typhoon intake?
2) How do I go about getting this installed in my vehicle? I do not feel comfortable installing this myself just yet.
Old 10-14-2012, 07:46 PM
drowned12's Avatar
drowned12 drowned12 is online now
5th Gear
a) Get it from amazon.
b) Not sure on the Typhoon but my SRI was pretty easy to install (looks the same as CAI). Basic tool kit and ability to follow directions is all that's needed...I take that back...you might want some extra long ratchet extension bars to remove the stock airbox. Have some rags handy to catch the coolant that will dribble a bit from the throttle body->engine block lines.
2012 Accord LX AT Sdn Taffeta White - "The Sleeper Speeder" - Stock Appearance - DYNO RESULTS && 127 MPH TOP SPEED RUN
Takeda SRI
Ported Intake Runner
RV6 PCD
Underdrive Pulley Set
Weapon-r i-Throttle
UR Full Chassis Kit + 22mm Sway Bar (7 pieces)
Akebono Performance Pads
Group 24F (V6) Battery Upgrade
RX65 Radar Detector || Blinder HP-905 Laser Jammer || Nexus 7 tablet + Scantool MX|| Dash Cam || License Plate Flipper || LED Brake Lights || Weathertech mats
Old 10-14-2012, 09:26 PM
4G63attack 4G63attack is offline
4th Gear
K&N made the direction pretty much stupid proofed. Simple tool kit is more then enough.
Car history:
1990 Toyota Corolla 1.6 (4AFE)--> 1990 Mitsubishi Eclipse GSX 2.0T (4G63T)--> 2000 Toyota Camry 2.2(5SFE)--> 1995 Nissan Altima 2.4 (KA24DE)--> 2012 Honda Accord EX 2.4 (K24Z3)
Dream Cars:
Aston Martin DBS, Maserati GT, Caterham 7 (aka Louts Super 7)
http://www.mitsubishi-forums.com/ind...w_item&CID=179
Old 10-14-2012, 09:40 PM
Shockwave's Avatar
Shockwave Shockwave is offline
3rd Gear
the CAI's are illlllleeeeegal in California thought arnt they? and why if so are they still illegal, its been three years?
And while we're on the subject whats the deal with the honda brake fiasco, its been 2 years but I havnt come across a single solid solution to the problem
THIRDLY
Does anyone know if the KnN cobra Kais CAI's heheheh, perform worse then CARB code or better then whats required for Carb code?
Old 10-15-2012, 11:11 AM
But lets just say I did not want to do it myself... would the dealership I bought it at install it for me?
Old 10-15-2012, 11:14 AM
drowned12's Avatar
5th Gear
Skeptical but if they sold it they would probably install it..guarantee Amazon is far cheaper. Do what I did for my intake runner and pulley...take it to an independent honda mechanic that gets good reviews. You have to ask straigth up if they'll install customer supplied parts....some won't because they're worried about the part being low quality, failing, and then you bitching them out. A mechanic could probably do it in < 15 minutes and would charge $70 for an hour of labor.
I can't emphasize enough how easy the install is. Remove airbox, remove stock intake. Unscrew MAF sensor. Disconnect fat hose, disconnect smaller hose...coolant will leak a bit. Install mounting hardware. Install new intake. Reconnect new fat hose and new little hose. Done. Socket set, pliers, and a screwdriver and that's it. If you're doing mods you should have tools anyways in case something needs adjusting down the road.
K&N also has a youtube video of the install process that you could follow along. It's something like "K&N Accord 2008" search term...here you go:
Takeda SRI
RV6 PCD
Weapon-r i-Throttle
Old 10-15-2012, 12:22 PM
Thank you. Very much appreciated!
Old 10-15-2012, 05:31 PM
One more question guys!
Are these pretty solid intakes to get? I have asked around and K&N seems to be the name popping up the most. Is the performance increase between intakes relatively the same between different brands?
Old 10-15-2012, 05:34 PM
drowned12's Avatar
5th Gear
It's just a metal tube. Buying K&N is like buying a Rolex...most expensive because of the name.
Takeda SRI
RV6 PCD
Weapon-r i-Throttle
Old 10-15-2012, 05:43 PM
G26's Avatar
G26 G26 is offline
3rd Gear
It's a good intake. Becareful when tightening down the clamps on the metal tube though, mine started to collapse inwards. Had to bang the end back into shape. Never seen that weak of an intake tube.
Sent from my iPhone using AG Free
Previous - 2011 Mazdaspeed 3 - fully bolted/tuned 300whp 320wtrq
Current - 2010 Accord EX-L V6 Coupe - K&N SRI / 4300k Volt HIDs
Old 10-15-2012, 06:11 PM
murcielago_786 murcielago_786 is offline
I have a 08 V6 accord with the K&N Typhoon intake and it was the best investment I made in the car. Not only does the car sound mean as hell, its definitely far more responsive than the stock setup in regards to acceleration.
As mentioned, the instructions from KN are fool proof. I installed mine in an hour with no problems whatsoever. It’s a very simple install. No different than filling up your tank.
Old 10-15-2012, 06:18 PM
Shockwave's Avatar
3rd Gear
Has anyone had a problem with emissions testing smog test, when it comes to the KnN filter, or do you guys usually swap it out for the oem before testing?
Old 10-15-2012, 08:57 PM
4th Gear
Most smog check guys don't care, but it don't hurt to ask/check around first. Or know a friend of a friend that knows a smog check guy.
Car history:
Dream Cars:
Old 10-16-2012, 04:15 AM
G26's Avatar
G26 G26 is offline
3rd Gear
One more thing, I've been monitoring fuel trims while driving with the k&n intake and it looks pretty good.
Old 10-16-2012, 03:59 PM
jdcortez2012 jdcortez2012 is offline
My First Post
talked to a guy and said that a tune is required to get the full performance of the CAI.. my question is will the tune void that warranty? i know there is some law out there that says a dealership has to prove that the part (CAI) is responsible if the car messes up, but will the tune up automatically void it?
