Burning oil - Drive Accord Honda Forums
Old 10-20-2012, 05:11 PM
larrym64 larrym64 is offline
Burning oil
I have a 2009 EX V6. I have less than thirty thousand miles and I am the original owner. I have started to burn oil at the rate of 1/2 quart every 800 miles. What I needed to know was how do I confirm what the service guy said that honda says 2 qts per 1000 is allowable. Does anyone have any idea where I can find that information for my self?
2009 Coupe EX-L V-6
Old 10-20-2012, 05:19 PM
namegoeshere's Avatar
. . . . ლ(ಠ益ಠ)ლ . . . .
If I remember correctly, I think Honda says 1 qt every 1,000 mile is allowable. Even at that, I still think that's a bit excessive.
If you change oil every 5,000 miles... that about 8.5 qts you'll need to put in before next oil change.
Oil consumption seems to be a pretty common issue with the 8th generation Accord.
Old 10-20-2012, 06:20 PM
2010accordv6 2010accordv6 is offline
5th Gear
You say your the original owner with less than 30k and have started to burn a half quart every 800 miles? Did you burn oil always when the car was new and the problem is getting gradually worse or did you just notice the oil consumption? I had a similar problem in my first 10 thousand kilometres that stopped after my first oil change. There is an oil additive in new cars so just wondering if you remember when you did your first oil change or how hard you drove it from day one?
Old 10-21-2012, 09:21 PM
I didn't notice it until this last spring I was getting an error code which apparently for the ECO not working properly. They knew that this was because of low oil. now that I have been aware I check it every 1000 miles which led me to put 3/4 quart Saturday. I was planning to go back and ask a different advisor about what is the acceptable limit?
Thanks for the links to the potential lawsuit they were very informative.
2009 Coupe EX-L V-6
Old 10-21-2012, 10:41 PM
drowned12's Avatar
drowned12 drowned12 is offline
5th Gear
If I were having the problem I'd just do the ye-olde small claims court. Sue for $5k for an engine rebuild...Honda would probably settle just to avoid the publicity of it. No judge would take "1 qt / 1000 mi = normal" argument seriously.
2012 Accord LX AT Sdn Taffeta White - "The Sleeper Speeder" - Stock Appearance - DYNO RESULTS && 127 MPH TOP SPEED RUN
Takeda SRI
Ported Intake Runner
RV6 PCD
Underdrive Pulley Set
Weapon-r i-Throttle
UR Full Chassis Kit + 22mm Sway Bar (7 pieces)
Akebono Performance Pads
Group 24F (V6) Battery Upgrade
RX65 Radar Detector || Blinder HP-905 Laser Jammer || Nexus 7 tablet + Scantool MX|| Dash Cam || License Plate Flipper || LED Brake Lights || Weathertech mats
Old 10-22-2012, 12:11 AM
5th Gear
Didn't you check your oil at all from new? If not you could have been driving on low oil and done some damage.
Old 10-22-2012, 03:42 AM
Crashmaster's Avatar
Crashmaster Crashmaster is offline
2012 Crosstour
I'm very curious what oil you have been using in the car? I've seen way too many people using Mobil 1 or some other synthetic from day 1, and then after a while, the engine would start using oil? What oil and weight have you been using? How often do you change your oil?
NOTE: I'm not blaming or pointing fault at you, I'm just compiling information.
2012 Crosstour w/NAV
ASE Master Tech
CSI Vehicle Forensics
Old 10-22-2012, 04:28 AM
Pete240z Pete240z is offline
4th Gear
Since the old days; I always check the oil level on all my cars - new, old, classic......always checking the oil on all my cars......did I mention ths that I always check.....
2011 Accord Sedan LX 5-spd Alabaster Silver
Acura rear sway bar 17mm upgrade
Aftermarket window visors
Old 10-22-2012, 05:24 AM
coupe7 coupe7 is offline
2010 coupe'
Once you have completed you're lawsuit,
May i suggest lucas oil additive to help alleviate that oil consumption, although used on older hondas it will stop that slow burn off of oil.
Only a suggestion.
Hids
Fog light
Mud guards
10 inch sub
Weather Tech
Snow tires
Led interiors
K N drop in filter
Old 10-22-2012, 05:53 AM
justice37 justice37 is offline
Did you ask them to update PGM-FI software? It is on TSB 11-033.
Old 10-22-2012, 07:09 AM
kevin512 kevin512 is offline
+1. I had a similar problem on my '09 EX-L V6. The oil consumption problem was greatly improved after TSB 11-033 was done; it also mostly fixed the ECO surge/hesitation issues.
See the thread below for details.
http://www.driveaccord.net/forums/sh...ad.php?t=69871
2009 Accord EX-L V6
Minnesota, USA
Old 10-22-2012, 07:43 AM
drowned12's Avatar
5th Gear
^^ How did they do the ECU update? Via the OBDII port?
Takeda SRI
RV6 PCD
Weapon-r i-Throttle
Old 10-22-2012, 11:39 AM
I don't know, I didn't observe the update being performed.
2009 Accord EX-L V6
Minnesota, USA
Old 10-22-2012, 01:50 PM
poorboyaccord's Avatar
poorboyaccord poorboyaccord is offline
2008 Accord Coupe EX
if ur car is still warrantied take it in now,if they tell u its normal trust me its NOT.there have been several cases of this, this is the first case iv heard with of a v6 having oil consumption problems.i for one got a brand new short block from oil consumption almost a year ago. my car was drinking 1/2 qt every 1k miles, i have not had to add one drop since my new engine. i also had the ecu update b4 the new engine, it didnt work
Old 10-22-2012, 01:53 PM
yeah me too
