3rd Gen RX-7 rims on 2006 value package - Drive Accord Honda Forums
Old 10-21-2012, 05:40 PM
klui klui is offline
Question 3rd Gen RX-7 rims on 2006 value package
Hi:
I saw a post here from an individual who mounted 3rd-gen RX-7 rims on his Accord EX. Are the suspension parts the same between EXes and VPs so I can do the same using the Mazda rims? My concern is the wider RX-7 rims having clearance problems from suspension parts or the wheel wells. Looks isn't a concern as indicated in that thread.
REF: http://www.driveaccord.net/forums/sh...ad.php?t=14715
Thanks
Old 10-21-2012, 06:21 PM
Toshbar's Avatar
Toshbar Toshbar is offline
<= Jeep differential LOL.
Yes, all structural stuff is identical throughout the trim levels.
The welfare of humanity is always the alibi of tyrants.
Save the Manuals!
1 3 5
2 4 R
Old 10-21-2012, 08:56 PM
Thanks for your speedy reply. I will install 225/50R16s instead of what the original posted was going to do since the 50 series is closer to the VP's stock 195/65R15.
Is there some adjustment that's made for VPs over EXes (4-cylinder, 6 cylinder, and 6-cylinder 6 speeds) since they all have different OEM tire sizes? Would this adjustment be difficult to do or should I dispense with it and get the closest size based on the VP's OEM size?
Thanks again.
Old 10-22-2012, 04:40 AM
ikethegreat's Avatar
ikethegreat ikethegreat is offline
Carpe Diem
The tires will fit fine. You can fit pretty fat tires in our wheel wells on 16" rims at stock height.
Old 10-22-2012, 01:23 PM
Toshbar's Avatar
225/60/16 would look better. The ones in the post you linked to are 50 aspect ratio and look tiny.
Save the Manuals!
1 3 5
2 4 R
Old 10-22-2012, 10:18 PM
Thanks everyone for your input. I am concerned about using 225/60s because it will be over 6% difference in diameter whereas the 50-series is only 0.5%.
Tags
clearance, rx-7, value-package, wheel
