Line output converters
hey guys i have an 04 accord and im looking to add subs with keeping my stock hu. my question is i was looking at a couple different loc's and my question is if anyone has used the scorsche one found at wal mart, if so did you have to run the remote wire. I went into visions and they showed me another loc manufactured by energy audio products and he told me i wouldnt need to run a separate remote wire and that it integrates the remote signal into the rca's. so my main question would be if the scorsche one requires the remote run. its a difference of $60, although he did say the energy one had a high power output.
http://www.crutchfield.ca/Scosche_SL..._p/142slc4.htm http://www.gentec-intl.com/product/e...iver--enclcn2/ thanks for any input you give. |
| Sponsored Links | ||
Advertisement | ||
2009 Honda Accord EX Sedan -Crystal Black Pearl -20" MSR Style 093 Super Black Finish on Nexen 245/35-20 -Megan EZ Coilover -SPC Rear Camber Kit -3M Color Stable Tint 35% -6000k LED License Plate -5900 Xenon Halogen Headlight -Rockford Fosgate Amp with 12" Solobaric L5 Subwoofer -Mugen Replica lips -Clazzio Peforated Leather seats |
How's the set up on that one. In just trying to avoid splicing into my power via remote wire. With the one you mentioned is it required?
Sent from my LG Connect 4G on AutoGuide.Com
Where can I find your DIY diagram?
Also I'm looking at that lc2i and it says 12v output. Does that mean it needs a power run from the battery?
Check out my thread or go to the diy section. There is a diy i made about installing aftermarket amp in factory headunit
So would I be able to split off the one 4ga wire and run it to Both my amp and the loc.
You can run a 16awg wire from the amp's 12v terminal to the LC2i for power then ground,AC recommends using a 1A fuse but I did not install one and had no problems what so ever.
Ok thank you very much for ur input. I found ur thread. Awesome work bro.
Thnx and good luck!
Good luck. Let me know if you have any other questions.
| Sponsored Links | |
Advertisement | |
