Driver door wont open! Help! - Drive Accord Honda Forums
Old 10-26-2012, 02:52 PM
Honda99Heathen Honda99Heathen is offline
A couple days ago when I went to get into my car, the door wouldnt open (and yes I made sure it was unlocked). It had opened fine ten minutes prior to that. What happened? How do I get the panel off anyway??
Old 10-26-2012, 03:21 PM
nochamars's Avatar
nochamars nochamars is offline
4th Gear
Search how to take off door panel reconnect the wire on the knob your good to go not a big issue.
*2009 Honda Accord Ex - Sedan
*Taffeta White
*8000k HID
*PUTCO LED lightning
*Infinity Kappa 692.9i Speakers/4 Channel Amp
*Audio Control LC7i
*JL Audio W6 on the way soon.......
More mods to come when life gets back on track....
Old 10-27-2012, 12:19 PM
Shockwave's Avatar
Shockwave Shockwave is offline
3rd Gear
Bos hog says
Weld the door shut & jump through the window Duke's of Hazzard style!
Old 10-27-2012, 01:18 PM
m0nty55 m0nty55 is offline
the lock mechanism probably stopped working, i had to replace mine.
Old 10-28-2012, 01:06 PM
SiLV6R SuRFer's Avatar
SiLV6R SuRFer SiLV6R SuRFer is offline
SS workin progress
This happened to me. With my situation my mechanic had to work within. He removed the door panel and had what worked as a hammer drill, pretty much a rotary drill with a flathead bit and a mechanical hammering action. He just broke the door lock assembly to pieces. Once that was done, the door just opened.
I have a 2000 6th gen coupe so if this is same as yours, here's the link for the piece or just the link for OEM parts.
http://www.hondapartscheap.com/parts...ning/door-lock
2ooo Accord V6 coupe
Old 10-28-2012, 05:11 PM
BMBaccord's Avatar
BMBaccord BMBaccord is offline
5th Gear
If it opens from the outside, then it is the door handle piece. Either broke or is disengaged. They are a pain to replace, and just a plastic green piece. Should be obvious if you remove the door panel.
2006 Accord EX i4
- Fog Lights
- iPod Integration
- JL Audio JX360/4
- Infinity Kappa & Reference Speakers
- Painted Engine Valve Cover Red
- Painted Black Calipers w/ Honda Decal
- Window Tints (50 Front 40 Rear)
Tags
door, stuck
