Need new battery
I need a new battery on my Accord but I can't decide on Duralast Gold (AutoZone), Bosch Premium Battery (Pep Boys) or the OEM battery from the dealership. Any suggestions? Thanks!
2006 Honda Accord EX 2009 Honda Civic DX |
| Sponsored Links | ||
Advertisement | ||
Interstate batteries I would recommend if you can get them. If not just go for the duralast
http://www.driveaccord.net/forums/sh...hlight=battery http://www.driveaccord.net/forums/sh...ad.php?t=67310 http://www.driveaccord.net/forums/sh...hlight=battery http://www.driveaccord.net/forums/sh...hlight=battery http://www.driveaccord.net/forums/sh...hlight=battery
Filling a need-2006 Accord EX manual 5spd sedan |
Which battery costs less? Do you put special demands on your battery (really cold weather, big stereo, etc.)? I get them from walmart for my 2004 accord I4/5AT EX-L and they last well and work fine. The OEM battery lasted 4-1/2 years, and the first walmart battery lasted almost 5 years. I'm now on my second walmart battery. car has 217,000 miles and starts/runs just fine with the small I4 battery. Bigger batteries are fine but I don't like to spend money unless it's really needed. Good luck...
Same with me the smaller one works fine on my Accord also....
I have two Duralast Gold batteries right now, and they are working just fine. The last replacement, from Sam's club (Energizer) didn't last very long, but it was cheap.
92 EX Sedan auto - sold after 12 years 03 EX V6 Sedan auto - present car |
fixed
07 Sedan 94 N/A H22, ported head, s2p1 cams, s2vt, flat valves, blacktrax intake mani, euro R tb ported 70-65mm taper, hyptech rep header, Enkei Evo 5, Ground control, tokico struts. |
Is your Accord a V6 or I4 model? If it's an I4 model you can go to a little bit bigger battery (the same size the V6 would have). I bought an interstate that would be for the V6 and put in my 2005 4 cylinder. I had to remove the plastic shrouding to make room for the bigger battery. If I remember right, the battery I bought was actually a few bucks cheaper then was was suppose to go in the car. I'm guessing it was a more common size?
Interstate Batteries FTW !
2007 Nighthawk Black Pearl EX-L (Suzie) MODS: -Foglights -Smoked Tails -20% Tint -Group 24F Battery Upgrade |
ez....
2005 Accord EX V-6 Coupe 6M Taff. White;cargo net;7-24-05 '13 VW JETTA SPTWGN TDI 6M Build date:03/12/2013 NO NAV ZERO SUNROOF:CANDY WHITE 1982 VW Rab. Diesel Pickup 5M Mojave Beige/ac/bedliner/alloys (sold to restoration outfit) |
I would recommend Optima.
2010 Accord Sedan EX-L v6 w/ Navi
HFP suspension Takeda SRI Magnaflow 14832 TSX RSB G37s rims |
battery
next one i'll have to pay for so not going back to honda given the history
2006 Accord V6 AT ~ 80k Miles |
Almost all your batteries are made by one of 3 major battery manufacturers and are private labeled. I believe the Honda battery is made by Johnson Controls as is the Energizer battery. Same product, different label. If you want a battery to last, buy an AGM type flat plate battery. They typically last 2 to 3 times longer than your average wet cell battery. The Sears Platinum is an example of an AGM flat plate battery. Otherwise wet cell batteries are pretty much all the same and thinking one is better than another is usually a state of mind.
+1 OEM size batt works fine in the I4.. Less weight too..
here and now: 2007 Accord EX-L I4 1999 BMW M3 coupe previously owned: 2004 Accord EX V6 auto 2003 Accord EX V6 auto |
looking at the duralast for v6 vs. I4 it saves around 10 lbs.
03 Accord LX I4 5spd, 216k miles. with 19 HFP Wheels and Eibach pro spring kit (second set as the first set of rear springs rusted apart). Previous car: 98 Civic EX 5sp. with 155K, RIP |
| Sponsored Links | |
Advertisement | |
