Possible break issue?
All right so I have a big issue with the Accord that is driving me ****ing crazy. Ever since I hit a dog last week my drivability of the car has been a nightmare.
When I hit the dog, or just before, I slammed on my breaks and slid for a little, after continuing on my way I noticed the steering wheel jerks back and forth and makes the whole car vibrate and rattle, some roads worse than others. At a slow speed of about 5 MPH I can see that with every half rotation of the tires it jerks just a little bit to the left then a little to the right. Today I got new brake pads and resurfaced the rotors and that changed nothing, if anything its worse than before. Any ideas?
06' 68k miles i4 5-Spd Many many OEM goodies + | Unorthodox Racing Pulleys | Megan Racing Suspension | HPS Cold Air Intake | Magnaflow CatBack | TL-S Sway Bar| TSX IM Swap | Mugen!| Leather Interior | |
| Sponsored Links | ||
Advertisement | ||
break
breɪkShow Spelled [breyk] Show IPA verb, broke or ( Archaic ) brake; bro•ken or ( Archaic ) broke; break•ing; noun. verb (used with object) 1. to smash, split, or divide into parts violently; reduce to pieces or fragments: He broke a vase. 2. to infringe, ignore, or act contrary to (a law, rule, promise, etc.): She broke her promise. 3. to dissolve or annul (often followed by off ): to break off friendly relations with another country. 4. to fracture a bone of (some part of the body): He broke his leg. 5. to lacerate; wound: to break the skin. brake 1 breɪkShow Spelled [breyk] Show IPA noun, verb, braked, brak•ing. noun 1. a device for slowing or stopping a vehicle or other moving mechanism by the absorption or transfer of the energy of momentum, usually by means of friction. 2. brakes, the drums, shoes, tubes, levers, etc., making up such a device on a vehicle. 3. anything that has a slowing or stopping effect. 4. Also called brakeman. a member of a bobsled team who operates the brake. 5. Also called breaker. a tool or machine for breaking up flax or hemp, to separate the fiber.
09 V6 6MT Coupe |
Its 5 in the ****ing morning,
*edited by mod* And name calling is not allowed.
Have your alignment checked. Or maybe you flat spotted your tires, doubtful unless you have REALLY soft tires.
Filling a need-2006 Accord EX manual 5spd sedan |
The tread on my tires is... embarrassing to say the least.
....way to go, Joe. (Well Done)
.....ez sends on this crisp (37F) morning in Reno, NV
2005 Accord EX V-6 Coupe 6M Taff. White;cargo net;7-24-05 '13 VW JETTA SPTWGN TDI 6M Build date:03/12/2013 NO NAV ZERO SUNROOF:CANDY WHITE 1982 VW Rab. Diesel Pickup 5M Mojave Beige/ac/bedliner/alloys (sold to restoration outfit) |
That could be part of your problem.
What time does the shop open that put your brakes on?
Part of it being 5 AM I forget that "today," was in fact, yesterday.
![]() Had to drive the Fiance to work since her tranny blew up(mazda, go figure) and its suking the sleep out of me.
is the dog okey? =( im sorry lmao
The dog was fine, I barely grazed him with my front lip.
But it cracked my front lip. (previous damage)
I was going to suggest a bent wheel, but if the dog is OK doesn't sound like you hit it that hard.
Did you check if you knocked a wheel weight off or something like that? You can tell joek you said "break issue" because you broke your lip. that would certainly be a break issue, now you gotta fix or replace it.
F1snob '06 6-speed Sedan with NAV and iSimple Graphite Pearl Tinted Windows 20% rear 32% sides TL Rear Sway Bar 60wX4 RMS amp, upgraded speakers Backup Camera Breyton 17X8 45 offset wheels |
I would guess this is a steering, or suspension issue most likely. Slight chance it's an axle, engine mount, or tire problem. Ball joints or control arms would be the first things I would check. I might even raise the intire front end, and run through the gears, to try and find the problem.
92 EX Sedan auto - sold after 12 years 03 EX V6 Sedan auto - present car |
Are you sure you didn't break a belt in one of the tires when you slammed on the brake for the dog?Run you hands along the tire tread and see.Sorry
i think soda got it exactly right +1
v6 130,000 miles goal 350k |
I checked the wheels today, as far as I can see all weights are on there. Raised the car and checked to see if the wheel was wobbly, nada.
I work the next 4 days till 6pm so there goes taking it to a mechanic. God, driving this car is a NIGHTMARE now. The whole front of the car is swaying left and right slightly.
| Sponsored Links | |
Advertisement | |
