08 Accord I4 idle miss over 4800 RPM, also stalls sometimes - Drive Accord Honda Forums
Old 10-30-2012, 10:55 AM
Checkered24 Checkered24 is offline
Strange and sudden problem with my 08 Accord.
Since getting an oil change done, the car now sometimes stalls from idle. Also, it has an occasional jerk to the power delivery and I noticed when not in gear, it will miss at RPM's over 4800, as if the fuel limiter kicked in. No lights on the dash to indicate codes or areas of trouble.
Any suggestions here to troubleshoot this?
Old 10-30-2012, 11:33 AM
drowned12's Avatar
drowned12 drowned12 is offline
Bugs fear my Bumper
4800 rpm is the vtec kick on point for the i4. Don't know if that's the problem but that number rings bells. If it was after an oil change then I'd be under my car redoing it.
2012 Accord LX AT Sdn Taffeta White - - Giant Service Manual Archive
Ported Intake,Pulley,TB bypass, RV6 DP+TP, 3" Catback, Custom CAIv2
91 Octane Tune - KTuner
9G HFP Wheels on Michelin PSS
Koni FSD Coilovers
UR Full Chassis Kit + 22mm Sway Bar
EX Calipers, Hawk HP Plus Pads, Drilled Rotors, SS Brake Lines
Mechman 180A Alternator, Big 3 Upgrade
Valentine One, HP-905 Laser Jammer, Nexus 7, Scantool MX, Garmin 2555LMT, Galaxy S5, Sleek 4G booster || Dash Cam
Old 10-30-2012, 11:58 AM
On the high idle thing... I am probably hitting the fuel cutoff to prevent cam changeover in neutral. Accelerates ok past that.
A bit more on acceleration..
The car seems to idle fine on its own in neutral. In gear, under acceleration, it sounds labored and the engine feels rough compared to normal. The car still accelerates ok, maybe not as well as normal however.
Old 10-30-2012, 05:47 PM
sodaks2k sodaks2k is offline
Moderator
Have you checked your oil level since the oil change?
If you're revving you're car in neutral, stop. And yes, the car is preventing you from reaching vtec in neutral for a reason.
2014 MSM Accord Sport Sedan 6M
Title goes here
close
video goes here
