Wires exposed badly on both front tires - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Wheels & Tires
Old 11-18-2012, 12:27 PM
free_money's Avatar
free_money free_money is offline
Both of my front tires on the inside are badly worn and have wires showing around the whole inner side. I noticed this problem start to show approximately 6 months ago and had the front tires replaced with decent used tires and I had a front end alignment at a reputable mechanics shop. Today I was doing my 6k mile tire rotation and noticed the front tires were horribly worn and wires were exposed on both of them all the way around on the inner side. I also checked the front tires for any play while one was jacked up and didn't notice any. Any ideas on what to check? I don't want to get a set of new tires and the insides are worn in a year.
02' Honda Accord SE 2.3L 4cyl - Just bought a Honda, throw some hubs on it!!
Old 11-18-2012, 01:34 PM
Flyertalker's Avatar
Flyertalker Flyertalker is offline
2nd Gear
I don't know what's wrong with your car, but if you had a "reputable mechanic" do the alignment and he didn't see any glaring problems then I'd question the decent tires. What some people think are decent, I would never put on my car.
If you tires are truly showing the belts, you run the risk of seriously hurting or killing yourself driving on them.
Old 11-18-2012, 01:53 PM
CYANiDE CYANiDE is offline
VTAKKKK
Send a message via AIM to CYANiDE
Get your alignment checked and ask for the printout. That's the easiest way to start.
If you live near a Goodyear service center they do free alignment checks.
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles]
FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI
Old 11-18-2012, 02:59 PM
thegrouch thegrouch is offline
5th Gear
How did the mechanic align it? Does he have the laser alignment set-up?
1991 Honda Accord EX
Old 11-18-2012, 03:14 PM
free_money's Avatar
I work nightshift and had to get my wife to take it there so I didn't get a print out and I'm not sure what type of tools they use for the alignment. I've used them several times in the past and the head guy is very honest and will tell me what's wrong and the price before beginning work. I guess next time I'll ask for a printout with it too. Just didn't think about that.
Old 11-18-2012, 03:19 PM
sodaks2k sodaks2k is offline
Moderator
Call the shop and see if they have notes in the computer on the alignment.
2014 MSM Accord Sport Sedan 6M
Old 11-18-2012, 06:27 PM
Aviography's Avatar
Given the year of your car, I'd have to wonder if your front shocks are going/gone and causes uneven tire wear even if the alignment is good.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 11-18-2012, 11:18 PM
free_money's Avatar
I'll call them tomorrow and see if they have notes in their computer for my alignment. I've had the vehicle since 80k miles and the shocks/struts hadn't been replaced prior to then and still have yet to be replaced and I'm at 190k miles now. I can tell when I go over speed bumps it doesn't sound so pleasant. Are there ways I can check the upper and lower control arms to make sure they are still ok. Also, I noticed today (possibly the tie rods?) the rods coming from the steering have grease leaking out of the boots. Not sure if this problem is related or is just something else that needs fixing.
Old 11-19-2012, 07:13 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
At 190K it positively needs front end work since nothing has been done to it. Either plan to cough up a wad of money for repairs or keep buying used tires every six months. It could also be unsafe.....have it gone over with a fine toothed comb. Normally if there are problems most places refuse to align it. It's been more than ten years since I've had an alignment and NOT gotten a printout, something fishy there.
Old 11-19-2012, 08:36 AM
BD06LXSE BD06LXSE is offline
Wife's Personal Mechanic
Agreed with front end suspension replacement, starting with struts and/or springs for sure! Plus, a thorough inspection of every other joint up there.
Old 11-19-2012, 09:19 AM
Moderator
I would inspect/test the struts before just blindly replacing them. Although I would guess they need to be replaced.
Old 11-19-2012, 10:32 AM
free_money's Avatar
What all would you guys recommend replacing? I think if I replaced the struts and shocks I would just buy a strut/shock assembly already assembled and ready to install. Should I just check the ball joints before just replacing them? What about wheel bearings and such?
Old 11-19-2012, 10:37 AM
Moderator
There's no need to replace the springs unless they are cracked. Swapping the struts/springs is pretty simple with a spring compressor.
Wheel bearings will make noise at speed above 25mph, so if you don't hear a whiring/humming sound, they should be good.
Yes, check the ball joints before replacing. Some can be a bit time consuming to replace, namely the lower ball jont.
Old 11-19-2012, 10:50 AM
nochamars's Avatar
nochamars nochamars is offline
4th Gear
Do some wheel alignment, rotation, and balancing. You're risking your life over a few hundred bucks never buy used tires!
*2009 Honda Accord Ex - Sedan
*Taffeta White
*8000k HID
*PUTCO LED lightning
*Infinity Kappa 692.9i Speakers/4 Channel Amp
*Audio Control LC7i
*JL Audio W6 on the way soon.......
More mods to come when life gets back on track....
Old 11-19-2012, 11:02 AM
free_money's Avatar
What exactly do I need to look at on the ball joints, just make sure there isn't play? I want to say mine didn't have any cracks or grease coming out of the boots, only the tie rods had grease coming out of the boots.
Title goes here
close
video goes here
