Phone Contacts Not Syncing Correctly With Car - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The 9th Generation
Old 12-06-2012, 03:47 PM
toddpedersen toddpedersen is offline
I have a 2013 EX-L Sedan. Does anyone know what the contact or phone number limit is for the car?
I pair my HTC EVO 4G LTE phone to the car and let it do the auto address book syncing but only some of my contacts move to the car. I have roughly 384 total contacts on my phone and maybe 30% show on the phone.
2013
EX-L Sedan
No Navigation
Old 12-06-2012, 06:27 PM
fw_fw's Avatar
fw_fw fw_fw is offline
Continuously Varying
Had this issue with my iPhone 4S. Had to go into the settings of the phone and verify which group of contacts to sync with bluetooth. Once I selected the appropriate group (All) everything synced as it should . Your phone probably has a similar setting/option.
2013 Honda Accord EX-L I4 CVT MSM/Grey
Old 12-06-2012, 08:45 PM
gdrd gdrd is offline
I have a similar problem with my '13 coupe and my Galaxy Nexus. Only 3 contacts appear after the syncing procedure. I haven't looked any further but I get the same problem when trying to connect to a '12 TL. Anyone have a new accord and using a Galaxy Nexus?
Old 12-07-2012, 03:19 AM
Thanks for the tip. I found that under my contacts I had an MSN,Gmail Group that was missing 300 contacts, so I easily added all my contacts to it and that fixed the issue.
2013
EX-L Sedan
No Navigation
Old 12-07-2012, 04:20 AM
JoeK's Avatar
JoeK JoeK is offline
4th Gear
OK, sounds like both of you have brand new cars. Typlically if you look in your glovebox you will find a book or two referred to as the owners manual. I highly suggest referring to this reference. Don't be scared, may god be with you...
Good luck!
09 V6 6MT Coupe
Old 12-07-2012, 04:23 AM
Thanks for stating the obvious, and being of no help whatsoever.
The owners manual does not state specifically what groups sync to the vehicle.
Happy trolling!
Good luck!
2013
EX-L Sedan
No Navigation
Old 12-07-2012, 06:51 AM
JoeK's Avatar
4th Gear
Happy trolling!
Lets see...
...Your origional question was
Page 19 of the "Accessory HandsFreeLink User's Information Manual" it is stated:
Accessory HFL can store up to 32 names and 128
phone numbers. Each name has four locations
(Home, Work, Mobile, and Pager) associated with it.
Please keep in mind these instructions are in reference to the 2007 model year. Your results may vary.
Accessory HandsFreeLinkTM Userís Information Manual
09 V6 6MT Coupe
Old 12-07-2012, 07:01 AM
Sorry, I stand corrected. I am not sure why I even asked that question other than thinking I had surpassed a limit, because of my missing contacts, so in reality the second part of my post was the true issue I needed addressed, which it was.
According to the update Honda Link Guide http://automobiles.honda.com/handsfr...-features.aspx
1000 names and 10,000 numbers. That is huge!
Lets see...
Accessory HandsFreeLinkTM User’s Information Manual
2013
EX-L Sedan
No Navigation
Old 12-07-2012, 09:07 AM
Husker's Avatar
Husker Husker is offline
6th Gear
Exclamation
Old 12-11-2012, 04:34 AM
Looks like I spoke too soon. Changing my contacts to a different group did not work either. I am curious what setting you changed to allow bluetooth to sync all your contacts?
2013
EX-L Sedan
No Navigation
Old 12-11-2012, 05:20 AM
fw_fw's Avatar
On my iPhone with the latest OS it is under
Settings>Bluetooth>Device:HandsFreeLink>Groups
Under this Groups setting was a list of Groups that shows the grouping of my Contacts. In this list I selected "All Contacts"
Old 03-27-2013, 07:12 AM
bourbongoat bourbongoat is offline
My First Post
Galaxy Nexus issues
I've got a Galaxy Nexus and have a similar problem, phonebook and call lists only work on the initial pairing. I've been trying to dig around and it seems like there may be some Android bugs with Bluetooth sync.
https://code.google.com/p/android/is...sort=&id=39753
Old 03-27-2013, 07:35 AM
Ciggy Ciggy is offline
4th Gear
What version of Android? I have never had any problems with my Gnex and aftermarket bluetooth sync. Picking up my Accord this week. It should work correctly.
Old 04-09-2013, 06:55 AM
TMan TMan is offline
I also have the HTC Evo 4G LTE. I got my Accord yesterday, and let it pull in the phone book.
I went to assign a few speed dials, but two of the names I intended to assign were not present in the car's phone book for me to choose for the speed dial slot, despite clearly being in the phone's phone book. All my contacts in the phone are Google contacts, not local phone-only contacts, and I can manage them when logged into Gmail at a computer.
I also did not see some means to specify that the car import only a certain group of contacts. I guess I'll try to dump the car phone book and reimport or something.
Title goes here
close
video goes here
