2013 Accord Sport oil changes - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Fluid Dynamics
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 12-13-2012, 05:09 AM
Sportsman63 Sportsman63 is offline
I am deciding(for my first oil change) between a dealership oil change using Honda synthetic blend ow20 with honda oil filter. Price $40.00
Versus
Buying from Walmart a 5 quart Mobil 1 fully synthetic ow20 ($26.00) Honda oil filter with crush washer ($7.00) and my long time mechanic doing the labor for $12.00-- Total $45.00
The real decision is whether or not to go with Mobil 1 Fully synthetic versus the blend.
Any thoughts?
Thanks
Old 12-13-2012, 05:40 AM
glen e glen e is offline
Retired from Car Biz....
if you are not on the F1 circuit, a hendrick racing engine or a NYC taxi doing extreme duty and going 20K between changes, it won't make a damn bit of difference. Search here for hundreds of oil threads debating this...For our engines, changing with something good and changing at a reasonable interval is all that matters....
New Accord? Click here for a good PDF detail procedure
My DD:'14 Vette
Old 12-13-2012, 06:03 AM
SatinSilver's Avatar
Moderator
Take out an old penny and submerse it in ketchup for 10 minutes. This will make the penny look new again after wiping it clean with a rag. Flip coin way up in the air. Heads = option A and tails = option B.
Old 12-13-2012, 06:33 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
It doesn't make a damn either way, do whatever makes you feel good. Honda also has a full synthetic 0W20 so throw that in the mix too.
Old 12-13-2012, 07:34 AM
redhat redhat is offline
No lifetime fluids!
What a frequent question
I used to be the "OMG I can only use the top synthetic and it has to cost a lot so I then know that I'm getting something super good for a lot of money, it has to be good..." DIY'er.
Then I realized that I can have a drink and get my oil changed all for less than half of what I was spending.
Use the blend with confidence. I run MCSB 5W-20 in my '09, yes different from the 0W-20, but a blend never the less and I never worry about it.
'09 LX 5MT Sedan - ASM/BLK
V1, OEM splash guards, leather wheel, trendgear fogs custom install
Old 12-13-2012, 03:59 PM
RTexasF's Avatar
In short.......use a good oil and filter, use it as often as required, and don't sweat it. It's a non issue.
Old 06-29-2013, 06:20 PM
Dum_Plings's Avatar
Dum_Plings Dum_Plings is offline
Wanda Honda
So I finally did my first oil change today but I am a little bit unsure of something. After I put the oil into the car, I tried to use the dipstick to check the oil level to see if I am under filling or overfilling. However, I can't tell with the dipstick where the oil level ends.
I bought the 5.1 Qt Mobil1 jug and I used the indicators on the side of the jug and poured approximately 4.2 Qt. I know the engine requires 4.3 Qt as stated in the manual but I was afraid of overfilling it. I'm afraid I didn't put enough oil in, but at the same time I don't want to overfill it. Should I have poured more in?
Please help a newbie out!
2013 Honda Accord Sport MSM
Mods Performed:
VLED's V3's 5K Switchbacks LED Front Turn Signals
VLED's V3's Amber LED Rear Signals
VLED's V3's Red LED Brake Lights
VLED's 5K Reverse LEDs
DDM Tuning 5000K 35W HID
CREE 5K LED for light strip
Interior/License Plate LED
LED Strip Trunk Lights
LEDGLOW accent lights in foot well
Polk 6.5" Component Speakers
exLED Rear Bumper Reflectors
Mods in Future:
Window Tint
Old 02-01-2014, 09:14 AM
cat5patsch cat5patsch is offline
hey there, been doing oil changes since i could drive.. u don't need to see the color line on the dip stick, simply wipe the end dry, dip it in, count 10 secs, and pull the stick out. then look for the 'wet' shiny part of the stick and that is where ur level is at.
Old 02-01-2014, 11:31 AM
RTexasF's Avatar
Do you really think being short .1 oz. will starve your engine of oil? Get real man!
Old 02-15-2014, 06:09 PM
desertrat's Avatar
desertrat desertrat is offline
4th Gear
You didn't mention the filter, did you change it also? If you didn't you should have. The owner's manual says I4 engine takes 4.4 quarts, that's with a Honda filter. Some after market filters may be a little larger.
As mentioned above a couple of tenths of a quart low isn't going to hurt a thing, better to have it a little low than overfill it. I haven't done this Honda yet but on my other vehicles I usually fill to an 1/8 inch or so below the full mark.
Edit: Some of the guys who posted on this thread say the I4 oil capacity with filter is actually 5 quarts. http://www.driveaccord.net/forums/sh...d.php?t=175962
Tom
Accord Sport 6MT
Title goes here
close
video goes here
