Surging Idle problem! P0507 and P2279 - Drive Accord Honda Forums
Old 12-30-2012, 09:34 AM
sammy08515's Avatar
sammy08515 sammy08515 is offline
2nd Gear
Unhappy Surging Idle problem! P0507 and P2279
The Car has been sitting for 2 weeks not being started. i go out this afternoon and she idles up as expected with the cold temp. i go back out and the thing is reving to 2000 - 1500 rpms!
the car threw 2 codes at me. a P0507 and a P2279. Ive had absolutely zero problems out of the car and this is a first. i did a small amount of searching off google and it seems to me that the problem may lie within the coolant temp sensor? Can anyone confirm this? any help is appreciated.
video inclueded!
- 2004 Accord EX Coupe 5MT -
NightHawk Black Pearl
HFP Front Lip
Taylor Heliux Throttle Body Spacer
TSX IM
RSB
TB Bypass
P2R Thermal Gaskets
Ralco Underdrives
Stock Headunit
4% tint on doors with 15% whole front windshield
Black Housed headlights
12000k HID Lows and Highs
Black Chrome fogs with 12000K hids
Backup Camera
Full interrior L.E.D with Plate light
SwitchBack Turns
Fujita Cold Air Intake -
Old 12-30-2012, 08:48 PM
sammy08515's Avatar
2nd Gear
Little update: when I originally encountered this problem it was 30 degreese out. 6 hours later I come back start it up like normal and it"cold idles" near perfect. No surge at all. Can anything justify this at all?
Thanks!
HFP Front Lip
TSX IM
RSB
TB Bypass
P2R Thermal Gaskets
Ralco Underdrives
Stock Headunit
Backup Camera
SwitchBack Turns
Old 12-30-2012, 08:53 PM
2006accord4 2006accord4 is offline
2006 I4 MT
P0507
Check for vacuum leaks at these parts:
PCV valve
PCV hose
EVAP canister purge valve
Throttle body
Intake manifold
Brake booster hose
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 76k miles
Old 12-31-2012, 06:40 AM
honda4ever honda4ever is offline
4th Gear
Make sure your throttle body and idle air controller are clean.
Old 01-02-2013, 06:48 PM
sammy08515's Avatar
2nd Gear
im about 90% sure it is the idle air control. i took apart the throttle body and cleaned it real well along with the IACV and it seemed to fix the problem. also cleared its own trouble codes. the new IAC is on its way! and i was a little low on coolant so im going to go ahead and flush it this weekend and put the blue type 2 stuff in it. Hope that fixes it lol
HFP Front Lip
TSX IM
RSB
TB Bypass
P2R Thermal Gaskets
Ralco Underdrives
Stock Headunit
Backup Camera
SwitchBack Turns
Title goes here
close
video goes here
