Painting BReak Calipers with Dupli-Color - Drive Accord Honda Forums
Old 12-31-2012, 04:52 PM
mo5751's Avatar
mo5751 mo5751 is offline
4th Gear
I plan on painting my calipers red and was wondering if i needed to have all four wheels off at the same time or can i work wheel by wheel i dont have anywhere i can take off all four wheels or the equipment only one at a time.
Thanks
Old 12-31-2012, 04:59 PM
Pete240z Pete240z is offline
4th Gear
Never work just under a jack. Jack stands are mandatory.
2011 Accord Sedan LX 5-spd Alabaster Silver
Acura rear sway bar 17mm upgrade
Aftermarket window visors
Old 12-31-2012, 05:10 PM
glen e glen e is offline
Retired from Car Biz....
Do yourself a favor...I have painted and sprayed calipers....much cleaner to paint them....no taping up and look good ...see mine here...
http://www.driveaccord.net/forums/sh...ad.php?t=77013
'13 EX-L I4 COUPE
STEEL/BLK
tint/19"HFP's/F15-R20 spacers/caliper covers/M3 spoiler
HID's/Interior CF/HID Projector fogs/exLED strip DRL's
Takeda/Dual Magnaflows
Click here for pics
New Accord? Click here for a good PDF detail procedure
Old 12-31-2012, 05:13 PM
mo5751's Avatar
4th Gear
OK cool if i get jack stands i can sit the car on four of them?
And Glen, did you use the can or the paint with brush which is my guess.
Old 12-31-2012, 05:21 PM
4th Gear
Loosen the front lug nuts - don't take them all the way off. Jack the front up and rest on 2 jack stands. Follow the Honda manual on where/how/wheel blocks.
Then remove the front wheels and paint per Glen. Put back together. Torque lug nuts if possible.
Then do the rear 2 wheels. Then you only need 2 jack stands. For a beginner it might be more stable this way.
Old 12-31-2012, 06:08 PM
MM49's Avatar
MM49 MM49 is offline
Honda Racing Evolution
Thanks
It depends on how you want to do it. As for me, I painted it by side(left and right). I used two jacks. One for the front and one for the back. I put the wheels (back side facing up) underneath the car.
As for the paint buy dupli-colour paint caliper kit (brush method). Make sure you clean the calipers really good before you paint em. It does come with brake cleaner and instructions. I did 3 coats 15mins apart. So by the time I was done painting the rear caliper the front one was good to go.
"I live my life in the fast lane"
"Put your two cents in, and get a dollar back"
Old 12-31-2012, 06:56 PM
DOOM's Avatar
DOOM DOOM is offline
Send a message via AIM to DOOM
I can't say enough good things about G2 self leveling brush on paint.
2011 CBP Sedan EX-L V6 | http://inspiredaccord.blogspot.com
Vossen CV3 | Nitto 555 | BC Coilovers/SPC Arms | Mugen/Modulo Kit | Sarona Roof Spoiler | Quad Morimoto/xB Retrofit | Fog Light Retrofit* | Inspire OEM Mirrors/Garnish | Eagle Eyes Trunk/Tails | Full LED Exterior/Interior | UltraGauge | Takeda SRI | JET MAF | Magnaflow/Vibrant | RV6 J-Pipe* | SprintBooster | UR/Progress Bars | EBC Brakes | Duralast Gold
Old 12-31-2012, 08:02 PM
mo5751's Avatar
4th Gear
With the g2 I can do twobwheels at a time and thgke paint wont dry?
Old 12-31-2012, 08:40 PM
DOOM's Avatar
I raised up on 4 stands but you have plenty of paint and time. I did three coats and had extra.
Old 12-31-2012, 08:49 PM
h2pvnus h2pvnus is online now
5th Gear
Guys I have an 09 sedan. Is it safe to raise the rear and place the jack stands on the two frame bars where the fuel tank between them.
Sent from my SAMSUNG-SGH-T989 using AutoGuide.Com Free App
Old 12-31-2012, 10:14 PM
milan.mastracci's Avatar
milan.mastracci milan.mastracci is offline
09 Coupe i4 EX-L 5MT
I have painted my brake calipers on my cars multiple times. On my Altima, i've done it twice, i went from stock to blue and then blue to gold. And then on my Accord coupe, i've gone from stock to gold, and then from gold to red. For each car, i've jacked it up on all 4's, and then taken the wheels of, sanded the calipers with 400 grit sand paper, then steamed them until they were bare metal. After that I put 3-5 coats of the Heat treated VHT caliper paint on with 20 minutes between each coat until they had the colour I wanted. I have used the VHT caliper prep but have not noticed a difference in the final result. I let them dry overnight before I drove the car so the paint would cure. On a side note as prep, I masked off all of the side panels and everything that had to potential to get overspray. I will post some pictures soon of them.
Calipers were heat treated painted blue on my nissan, and the rotors were painted black to prevent the centres to rust along with heat treated VHT caliper paint.
And here on my accord, i went from the stock unpainted, to gold, to red when i decided to change the colour scheme that I'm currently going for.
2009 Accord Coupe i4 EX-L 5MT Nighthawk Black- "Leanne"
Type R Conversion | Greddy Racing Ti-C Exhaust | Takeda SRI | Momo Shift Knob | 22mm Rear Sway Bar
Viper 5704 Security System with Remote Start | Interior LED Kit | NVX Sound Dampening - Full car | 4000K H11's
Black Nappa Leather w/ Red Stitching Shift Boot, eBrake Boot, Arm Rest | Hella Supertones | Blizzak WS70 Snows | 3M 15% Tint
Need to Install
JL AUDIO Dual 8W7 Subs
JL AUDIO HD1200/1 Amp
Old 01-01-2013, 05:46 AM
Joeggernaut Joeggernaut is offline
4th Gear
Cool job and all but not my cup of tea. I prefer a clean black look.
Btw why did you paint your brake pad backing? Makes the calipers look a little off
2003 Honda Sedan Lx K24 5-speed 152k DD
Old 01-01-2013, 08:28 AM
Hittman's Avatar
Hittman Hittman is offline
5th Gear
I agree - G2 is hands down the best way to paint your calipers. I used it on my ride 3 years ago and it still looks brand new.
'09 EX-L V6 Coupe 6MT ASM
Pictorial history of my coupe
My DIY Videos
Old 01-01-2013, 04:57 PM
5th Gear
what about the jack stand location guys help
Old 01-01-2013, 05:08 PM
this is what the manual recommends...nothing else...
'13 EX-L I4 COUPE
STEEL/BLK
Click here for pics
