Three months back we replaced a timing belt. Last week it was real cold outside and it wouldnt start. It acts like the timing is off, but we checked timing marks on the belt today and everything lines up the way it should. The distributor pointed to #1, and we put a timing light on it and it cranks and was right on the mark. Loosened fuel fitting and turned the key on and it sprayed, so we are getting fuel. When its cranking, it hits like it wants to fire and its about outrunning the starter but it just wont start. Installed new spark plugs today as well, just in the case that was the problem. On the new plugs, the spark was blue with a little bit of orange. The valve cover was off and the cam is working good. All the rocker arms were moving correctly. The car is so close to starting but it just wont do it. Timing was the initial concern but everything seems to be in order. The Accord just turned over 200,000 miles. Any ideas on what could be going on with this?
| Sponsored Links | ||
Advertisement | ||
Maybe some bad fuel? Try some starting fluid.
Otherwise check the compression as you may have some valves not sealing with the high mileage.
2000 Accord SE I4 F23A1 Auto @159k miles - My Daily Driver 1998 Accord LX I4 F23A1 5 speed - sons car 1987 Accord LX 5 spd Owned for 17 years sold @155k 1986 Accord LX Auto Totaled @125k miles 1983 Accord LX 5 spd My Second Accord 1978 Accord LX 5 spd My First Accord |
The fuel is fresh, tried starter fluid but it just wont start. It tries to start, really cranking its ass off, but dies as soon as you let go of the key.
Throw me some ideas guys, I am fresh out. |
Will the vehicle start and stay running if you're slightly pressing down on the gas pedal as you're cranking, and stall/run rough again after it starts and gas pedal is released?
are the wires on in the correct order on the cap? i have had this happen to me before. its a simple diagnosis and fix if so
99' Ex-l coupe v6 *black current pearl. R.I.P. 00' ex coupe 5spd. *san marino red (daily) 86' hatchback lx-i 5spd *silver metallic (toy) "when i fill my tank i go to stop and shop,to the rice aisle, pour in that uncle bens white rice. SON! the stuffs better than 110k" |
could also be a bad ground on the coil, or battery terminal. sometimes the engine will get spark, but not enough to fire, is the mil/cel on at all? try cleaning the tb and check your airbox you may not be getting sufficent airflow. try taking the tube off right at the tb and see if it starts then. next i would say check compression ifg all those fail.
Got back at it, and it ended up being build up inside the fuel relay switch. Cleaned it out with a brush and put a little grease inside, plugged it back in, and it fired right up.
very niiiiceee
| Sponsored Links | |
Advertisement | |
