Valve lash setting for '06 I4? - Drive Accord Honda Forums
Old 01-05-2013, 09:59 AM
SS350 SS350 is offline
Does anyone have the valve lash specifications for a 2006 Accord EX 4 cylinder?
There is not a sticker under my hood showing the valve lash spec so when I set the lash last week I used .009" for the intake and .011" for the exhaust. Since setting the lash the valve seating sounds louder, the engine seems down on power, and the fuel consumption may have increased. In my experience, all of these symptoms are indicative of too much lash (late valve opening and early valve closing; valve events not on the opening and closing ramps on the cam lobes).
Thanks in advance for your help.
Old 01-05-2013, 01:01 PM
Aviography's Avatar
Intake (0.008-0.010")
Exhaust (0.011-0.013")
From page 6-10 of the Honda Service Manual.
Seems you are pretty much on the money on the seetings.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 01-05-2013, 01:58 PM
Carnutz Carnutz is offline
4th Gear
Did you set the lash on a cold engine? The valve lash specs are based on cold..
here and now:
2007 Accord EX-L I4
1999 BMW M3 coupe
previously owned:
2004 Accord EX V6 auto
2003 Accord EX V6 auto
Old 01-05-2013, 07:54 PM
cjy3 cjy3 is offline
3rd Gear
How many valves did you adjust. You should set them to the middle of the spec. It has already been said, but the adjustments are with a cold engine.I have a 2006 EX-L i4 with 203,000 miles, and when I did my valve adjustment only one was out of spec. I also did another 2006 EX-L i4 with 190,000 miles, and only had 2 valves out of spec. Make sure your timing marks are lined up,timing chain and pulleys. Take your time doing this,I would rather take my time then have to do it twice.
Old 01-06-2013, 05:17 AM
I set all of the valves on a cold engine. It seemed like they were all very tight to begin with.
Old 01-06-2013, 06:33 AM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
If you increased the clearance on all the "tight" valves it will make them louder because of the extra space. Generally the intake valves will get looser with age (mileage) while the exhaust valves get tighter. I really doubt the increased clearance to factory spec will reduce your mileage or power tho.
The cold engine requirement means sitting overnight cold not just cold on the temp gage.
Did you try to measure the original valve clearance?
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 01-06-2013, 06:50 AM
4th Gear
On the older accords I used to own, there were many... I used to adjust the valves
Every 15k miles.. that's what they recommended.. very rarely did I actually have to adjust them.. it takes a certain feel to get the lash clearance correct.. make sure you have a good feeler gauge that's not bending and causing you to get an incorrect reading..
here and now:
2007 Accord EX-L I4
1999 BMW M3 coupe
previously owned:
Old 01-06-2013, 07:37 AM
Thanks for the spec and the thoughts on whether or not I should expect to need to adjust the lash. I think I'll just check the lash next weekend to see if I missed anything.
Old 01-06-2013, 07:39 AM
Keystone Keystone is offline
2nd Gear
I just did mine a couple of weeks ago. At 98K miles, what I found was about half of the intake valves slight loose (at the edge of the spec.) and all of the exhaust valves tight (out of spec.).
After adjustment I noticed a definite impovement in responsiveness at part throttle, especially at the lower rpms.
As far as the noise goes, it didn't help one bit. I guess it really is piston slap.
'05 Accord Coupe - 2.4, 5MT (Daily Driver)
'03 Dodge Ram 1500 - 4.7, 5AT (Work Truck)
'12 KTM 500EXC; '04 Ducati Multistrada 1000
Old 01-06-2013, 06:06 PM
3rd Gear
Take a pair of micrometers and set them to the spec you want.Next take the feeler gauge and put it through the mic.You are trying to get the feel of what it should feel like on the engine.
Tags
clearance, lash, noise, valve, valve adjustment
