Tapping into Map Lights - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > the 9th Generation
Old 01-13-2013, 03:15 PM
Lance's Avatar
Lance Lance is offline
Research Before You Post
I am interested in augmenting my blue illumination kit with a stick-on LED strip that would light in coordination with the map lights. Has anyone figured out an efficient way to tap into the wiring. I was thinking about hooking into the puddle lights; however, they go on and off with the opening and closing of the door (not what I want). The attached thread from a previous generation speaks about hooking into the ignition light. http://www.driveaccord.net/forums/sh...ad.php?t=12921
The ignition button on the 9th gen illuminates; however, it is on a different timing sequence then the map lights (I'm not sure that this would be optimal; however, I'm open to suggestions.)
Any help will be appreciated.
Lance
2013 Honda Accord EX-L V6 w/ Navi
Basque Red Pearl II, rear deck lid, blue LED illumination kit, door sills, stainless door piillers, LED interior lights, mud flaps, OEM all weather mats, tinted windows
In works: rear window spoiler, LED backup, LED rear turn, side molding, front foot well blue LED strip
Maybe: Nokya H8 Hyper Yellow fog, low beam upgrade, LED front marker/turn, burl dash trim
1999 Honda Civic LX
1998 Acure RL
1991 Honda Accord LE
Old 01-13-2013, 04:01 PM
WSport13 WSport13 is offline
3rd Gear
Lance
if you do have the original kit around, can you post a picture of it, mainly its connectors. I'm looking at the pdf instruction from CHH but still a bit confused. Thanks.
For those already had it installed, does it stay on as long as your headlight is on ? (I've read that, to some, it is not bright enough)
Old 01-14-2013, 05:41 AM
Lance's Avatar
I have the illumination kit already installed. It does link to the headlights. It is not very bright. It doesn't have a manual on/off switch. It serves it's intended purpose OK, but I would like additional lighting for the same duration as the map lights. Not a must have. I'm just considering it. I guess that it depends on the level of effort and amount of risk that I am willing to accept.
Lance
1999 Honda Civic LX
1998 Acure RL
Old 01-14-2013, 06:02 AM
on2's Avatar
on2 on2 is offline
I Love My Honda
Take out your map light. Look at the color of the wiring. There may or may not be a ground wire. The screws holding the map light assembly is possibly the ground.
You can test this out with a multimeter.
Take note of the color of the wiring.
The wires for the map and dome light run down the driver side A-pillar.
Trace it down to the footwell area and tap into the lights down there.
Old 01-14-2013, 07:03 AM
Lance's Avatar
Thank You.
Lance
1999 Honda Civic LX
1998 Acure RL
Old 01-15-2013, 11:40 AM
Lance's Avatar
Originally Posted by II Kings 9:20 View Post
There are specific fuse taps that make it clean, neat and easy. Our fuse is a mini but has short prongs. I'll try to find a pic and post.
Ebay item # 120999186553
This is a great idea. I have a question that I think doesn't have an answer; however, I'll ask you guys anyway. Why would the fuse for the interior lights be in the engine compartment fuse box? Given that I want the foot well lights to go on and off with the map lights, can someone tell me how to tap the wires through the engine firewall?
Thanks again,
Lance
1999 Honda Civic LX
1998 Acure RL
Old 01-15-2013, 11:55 AM
II Kings 9:20's Avatar
II Kings 9:20 II Kings 9:20 is offline
6th Gear
Thanks again,
Lance
I have not done it on this car. I think Platinum and possibly glen e have when sorting out the Strip light to DRL conversion.
You follow an existing wire through the firewall grommet and voila. Easier said than done. There should be some fuse in the box bove the hood release you can tap.
I will tell you that some of the fuse taps will be tight because of space issues and wire looms blocking some of the fuses. Take a look, there is a fuse diagram above the kick panel that might be useful. I would not tap into the fuel injection or something important like that
Under hood is very easy access but requires a firewall pass through. Our fuse is called a low profile mini.
Ex-L White Pearl/Ivory
Honda factory LED Touring Headlight, 3M Di-NOC Bubinga wood vinyl dash trim, Horn Upgrade, LED interior, trunk, license, Splash Guards
Old 01-15-2013, 02:58 PM
sodaks2k sodaks2k is offline
Moderator
They're not.
Trace it down to the footwell area and tap into the lights(fuses) down there.
I would use this thread as a guide.
http://www.driveaccord.net/forums/sh...ad.php?t=78856
Filling a need-2006 Accord EX manual 5spd sedan
Old 01-15-2013, 03:42 PM
on2's Avatar
on2 on2 is offline
I Love My Honda
Tapping into the fuse is a sure way to get to the right source for the dome light however it looks to be a pain as there is little room to work with where the wires go through the firewall.
Tapping into the right wire in the footwell area will be much easier if we can figure out exactly which wire the dome light is.
Old 01-15-2013, 05:49 PM
6th Gear
The fuses down by the left foot would be a PITA depending on which fuse is the correct one to use. Tapping a map wire woud be great but as I looked under the dash near the fuses, lots of wires are running bundled in looms and finding the map wire seems arduous at best. Not saying it can't be done.
Old 01-16-2013, 09:40 AM
Lance's Avatar
Originally Posted by sodaks2k View Post
They're not.
I would use this thread as a guide. http://www.driveaccord.net/forums/sh...ad.php?t=78856
2) I used that thread as a guide (#3 of that thread is quoted in #6 above.)
1) Page 564 of the Owner’s Manual identifies fuse #20 of the engine compartment fuse box for 'Interior Lights'. I questioned the rationale so I tested it. When I opened the car door the interior lights went on. I closed the door and unplugged fuse #20 in the engine compartment. When I opened the car door again the interior lights didn’t come on. I closed the door and reinserted fuse # 20. When I reopened the car door the interior lights came on…. Number 20 in the engine compartment sure seems like the right fuse to me.
What god left of my mechanically-inclined skills he added to my analytically-inclined skills. Where a carpenter will measure twice and cut once. I analyze four times and publish results once.
Lance
1999 Honda Civic LX
1998 Acure RL
Old 01-16-2013, 11:43 AM
Moderator
Lance
And that's what I get for misunderstanding what 0n2 wrote. Either way I would use the fuses in the foot well. That's what I used for my fog lights, the ACC fuse.
Old 01-16-2013, 02:11 PM
Lance's Avatar
Given that I am not mechanically inclined, I'll probably wait for a YouTube idiot's guide to foot well lighting before I try anything. I'm sure that somebody out there will try it and suceed.
Lance
1999 Honda Civic LX
1998 Acure RL
Old 01-17-2013, 10:23 AM
Lance's Avatar
I'm now thinking that neither tapping into the interior light wires, nor splitting the fuse will accomplish what I'm trying to do. I'm pretty sure that the wires are always hot. The puddle lights are controlled by a pressure switch in the door. Both the map lights and dome light are controlled by switches in the light fixtures.
I'm now thinking that the only way to take advantage of dimming foot well LED strips with the map lights will be to tap into the actual positive connector of the map light bulb socket.
Thoughts?
Lance
1999 Honda Civic LX
1998 Acure RL
