What is wrong with my car - Drive Accord Honda Forums
Old 01-16-2013, 09:08 AM
JayBBJr101's Avatar
JayBBJr101 JayBBJr101 is offline
2nd Gear
PLEASE HELP me!!!!!! Hey guys i need some help if anyone has experienced this with there 8th gen accord coupes. But I have a 2010 Honda Accord EX-L V6 coupe w/Navi and I'm hearing knocking sounds when i turn left and accelerating at the same time. It does it when i turn right as well but not so bad as the left side. and while im accelerating on the highway i feel vibrations. what could possibly be the issue. Im nervous because this is a leased car and i give it back in a couple of weeks and i have no warranty on the car to cover this issue. I don't want to get hit with excessive wear and tear charges because im planning to get a 2013 Accord Accord V6 same trim. Again PLEASE HELP!!!!!
Old 01-16-2013, 09:19 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
CV Joints?
- It is just a car -
2005 Accord Sedan EX-L AT
2009 Accord Coupe 6/6 Black
Old 01-16-2013, 09:24 AM
Aelayyat Aelayyat is offline
4th Gear
CV joints would be my guess
Honda I own:
2010 Accord Sedan, EX V6
Black on Black
Other rides:
3 big body Cadillacs
85 Fleetwood Brougham d'elegance
90 Brougham d'elegance
05 Deville DTS
Old 01-16-2013, 09:45 AM
redhat's Avatar
redhat redhat is offline
And the cradle will rock.
Yes sounds a lot like CV Joints. Are you sure there isn't a few months or anything left of your warranty?
Unless you burned through 36k miles or you got it late '09, you're covered for 3yr/36k. I would think CV Joints would be covered. Also thinking you're probably not at 36k as you have a lease unless you have a huge allotment.
If all else fails and you have no warranty, drive 'er easy.
'09 Accord LX 5MT - ASM/BLK, 40k
TGMO 0W-20, A01
Link to my HOBO build thread
JayBBJr101's Avatar
2nd Gear
ok if it is CV joints would that be my fault that they went bad. or do they normally go out?? And if so how much is it to fix roughly
Old 01-16-2013, 09:48 AM
JayBBJr101's Avatar
2nd Gear
yea @redhat im at 70k but i just dont want to be held responsible for the CV joints when i turn the car in. will they check for that stuff when you bring the car in???
Old 01-16-2013, 09:54 AM
glen e glen e is online now
Retired from Car Biz....
they will do a walk around and a drive..if you can feel it on a drive, then yes, they will know...
'13 EX-L I4 COUPE
STEEL/BLK
tint/19"HFP's/F15-R20 spacers/caliper covers/M3 spoiler
HID's/Interior CF/HID Projector fogs/exLED strip DRL's
Takeda/Magnaflows
Click here for pics
New Accord? Click here for a good PDF detail procedure
Old 01-16-2013, 11:46 AM
JayBBJr101's Avatar
2nd Gear
are CV joints expensive and if so how much are we talking about
Old 01-16-2013, 12:02 PM
ReZ's Avatar
ReZ ReZ is offline
4 door Coupe
its the labor that always kills..
2011 EXL-V6 NAV
Old 01-17-2013, 04:57 AM
66FTW 66FTW is offline
2nd Gear
If you're at 70,000 miles on a lease you have bigger things to worry about than your CV joint... unless you paid out the nose for an unlimited mileage lease.
It could be a CV joint, but it could also be a wheel bearing. I've had the same problem with three different cars in the past and two times it was a bearing. One other possibility (which was my third time), and the chance is slim, would be a loose bolt connecting your tie rod or control arm. With my STi I had similar symptoms, noise when turning left, vibration while under load beyond 40mph... The mechanics couldn't find the problem, even replaced the front left axle. Well, we figured it out when I was driving through an intersection at 20mph and the bolt sheared, disconnecting my tie rod and axle from the tire and dropping the front corner of my car into the road. Good times...
Old 01-17-2013, 12:30 PM
JayBBJr101's Avatar
2nd Gear
So what happened would that my fault if I brought it back like that
Old 01-17-2013, 01:02 PM
4th Gear
The dealer will more than likely deem it your fault.
They look at t like this, you drove the car, you broke it.
Sent from my iPhone using AutoGuide.com Free App
Honda I own:
Black on Black
Other rides:
05 Deville DTS
Old 01-17-2013, 01:03 PM
2nd Gear
It would be on you... While 70,000 is a little early for things like CV joints or wheel bearings to go (depending on the roads in your areas... lots of pot holes drop their life expectancy drastically) it's still considered wear and tear.
Old 01-18-2013, 09:34 AM
JayBBJr101's Avatar
2nd Gear
Ok so I took the car to pep boys and the mechanic said that there is nothing broken or loose underneath the chassis. He said the car seemed fine. The only reason why I didn't take it to Honda was because they told me it would cost 105 dollars just to look at it and tell me what's wrong which I believe is crazy.
Old 01-18-2013, 10:04 AM
redhat's Avatar
People are still working and being paid by their employer to look at your car. It isn't crazy, can't have something for nothing.
TGMO 0W-20, A01
