SPC 1-arm with J-power 3-arm Rear Camber Kit
Greetings!
I recently lowered my car with Eibach Pro-kit springs and Koni FSD combo. I installed a one-arm SPC camber kit, but it wasn't able to bring the camber back in spec. Not wanting to destroy my Goodyear stickies, I went ahead and purchased a J-power 3-arm kit. My decision was based mainly on the low-cost (I've run out of money modding) and on the mostly positive opinions I've read about the J-power arms on many forums. Since it's too late to get the other two SPC arms, I just wanted to know if it would be possible to keep my SPC arm and install the other two arms from J-power? Has anyone tried this? In one of the forums I read that the rubber bushings on the J-power arms are susceptible to failure. I just checked the bushings on the J-Power arms. The rubber is super-soft. Makes me wonder how so many people have not faced any problems. I don't know what SPC uses in their arms. High density Polyurethane? Your feedback would be much appreciated. In the meanwhile, I will be testing the set-up and let you know how it goes. Cheers!
Honda Accord 2009 V6 EX-L Sedan Mods: K&N Drop-in Filter StopTech Drilled/Slotted Rotors Posi-Quiet Ceramic Brake Pads Stop-Tech Stainless Steel Brake Lines Castrol SRF Brake Fluid Progress Rear Sway Bar (22 mm) Eibach Pro-Kit Lowering Springs Koni FSD Shocks H&R Wheel Spacers (10 mm) SPC 1-arm Rear Camber Kit J-Power 3-arm Rear Camber Kit Goodyear Eagle F1 Asymmetric2 235/45 R17 Tires Magnaflow Cat-back Exhaust UR OE Diameter Pulley P2R Ported Intake Runners + TBS |
| Sponsored Links | ||
Advertisement | ||
I have never read any failures here in 4 years of J-power or SPC....
'13 EX-L I4 COUPE STEEL/BLK tint/19"HFP's/F15-R20 spacers/caliper covers/M3 spoiler HID's/Interior CF/HID Projector fogs/exLED strip DRL's Takeda/Magnaflows Click here for pics New Accord? Click here for a good PDF detail procedure |
i have seenmany j power softrubber bushings fail in track or gp conditions. hence, why its unheard of on DA.
that is correct, DA is not a "track or competition " oriented forum....hence why they seem to hold up for general vehicle use...
| Sponsored Links | |
Advertisement | |
