front grill LED installed !! pictures !!!! - Drive Accord Honda Forums
Old 01-17-2013, 10:28 AM
renzovc16's Avatar
renzovc16 renzovc16 is offline
2009 accord ex 4 cylinder
Wink front grill LED installed !! pictures !!!!
Whats up brothers !!!!!
I just finished setting up my front grill leds and i need your sugestion please read carefully:
I plugged in the add a circuit mini fuse in the fan fuse (7.5 ) number 21 which is the "A/C condenser fan relay" , which was the only fuse that has acc power .acc means accessories like your radio and stuff so it should be on only when the key is in acc position (make sure not to run your battery down)
After testing with a battery tester each fuse i found this one that had power only when the key is in acc position and happents to be the fan fuse as you can see
Then i removed the grill top cover , has 8 pins becarefull since i broke one lol
Place the strips with double sided tape and wire them find a negative ground
Turn on the car... and greatness lol
But the lights stay on for like a minute after the car is off once you remove the key then they will go off completely
So what should i do guys ? Is it gonna be a problem because it might drained my battery?
Should i add another fuse on the empty slots ? I need some help or should i leave it like that PLEASe let me know what can i do ?
IF YOU HAVE ANY QUESTION LET ME KNOW IM HERE TO SHARE MY MOD !!!
Old 01-17-2013, 10:37 AM
Silverstreak Silverstreak is offline
Autobot Gunner
I shouldn't like this, but I do. Do they scan like KITT?
The boards will hate it, they only seem to like LEDs in the license plate, DRL, and dome housings.
35% tint -- Autobot insignias -- Oddysey Lower Grille -- Plasti-dipped all chrome -- Blacked Out Lower Bumper -- Crystal Vision Ultra 4300K heads/fogs
Coming Soon:
Light Smoke Tail Tints -- Painted Exhaust Tips -- Painted Door Handles -- Backup Camera
Old 01-17-2013, 10:45 AM
MannuDKAD's Avatar
MannuDKAD MannuDKAD is offline
Spirited Cruiser
It may help searching on the web to know if the connections are right. Sorry, can't help you there.
I must say, I've been thinking of doing something like this, but need to know a bit more before I take the plunge.
They look nice though
I would like them a little lower - just my opinion.
Honda Accord 2009 V6 EX-L Sedan
Mods:
K&N Drop-in Filter
StopTech Drilled/Slotted Rotors
Posi-Quiet Ceramic Brake Pads
Stop-Tech Stainless Steel Brake Lines
Castrol SRF Brake Fluid
Progress Rear Sway Bar (22 mm)
Eibach Pro-Kit Lowering Springs
Koni FSD Shocks
H&R Wheel Spacers (10 mm)
SPC 1-arm Rear Camber Kit
J-Power 3-arm Rear Camber Kit
Goodyear Eagle F1 Asymmetric2 235/45 R17 Tires
Magnaflow Cat-back Exhaust
UR OE Diameter Pulley
P2R Ported Intake Runners + TBS
Old 01-17-2013, 10:53 AM
Tom 6-6's Avatar
Tom 6-6 Tom 6-6 is offline
"Old School" Shifter
Which fan is it,cooling or the fan inside? If it doesn't drain the battery too much which I doubt, I would leave it alone. The only way to find out is leave it plugged in . I would be more comcerned if the double sided tape will hold up.
Old 01-17-2013, 11:06 AM
2010accordv6 2010accordv6 is offline
5th Gear
I like the mod, what do you mean the lights stay on for a minute once the car is off? Before you take the key out or they stay on after you take the key out? Not a big problem but it would bug me.
Old 01-17-2013, 11:25 AM
DOOM's Avatar
DOOM DOOM is offline
Send a message via AIM to DOOM
not a bad idea... it is my understanding that we should avoid tapping into engine bay fuses though since you don't want to introduce any interference to the critical components. granted these low power leds are probably fine, i'd run the fuse lead from the driver or passenger kick panel fuse boxes instead (and grommet the firewall to keep the leads from being damaged by vibration). a small capacitor might serve the purpose of keeping the leds on after power is cut, but the bar would likely slowly dim out.
my only criticism is that the led bar is a different color than the rest of your front lights so it definitely looks added.
2011 CBP Sedan EX-L V6 | http://inspiredaccord.blogspot.com
Vossen CV3 | Nitto 555 | BC Coilovers/SPC Arms | Mugen/Modulo Kit | Sarona Roof Spoiler | Quad Morimoto/xBa2 Halo/WIFI RGB Demon Eyes Retrofit | Fog Light Retrofit | Inspire OEM Mirrors/Garnish | Eagle Eyes Trunk/Tails | Full LED Exterior/Interior | UltraGauge | Takeda SRI | JET MAF | Magnaflow/Vibrant | SprintBooster | UR/Progress Bars | EBC Brakes | Duralast Gold | Next: RV6 J-Pipe
Old 01-17-2013, 11:52 AM
renzovc16's Avatar
Thank you brothers
They work fine except that when i turn off the car and the key off the lights will stay on only for a minute or less....
I might take your advice and run the wire through the firewall into my driver fuse box and connect them , lets see what happens lol
Old 01-17-2013, 11:54 AM
glen e glen e is online now
Retired from Car Biz....
it is the fan TIMER circuit....perfectly ok to tap into per a couple honda techs I trust, It just closes the circuit for the fan to run if the car is hot..it stays on for 3 minutes after shutting off. Again, it is the fan timer, not the fan itself...
'13 EX-L I4 COUPE
STEEL/BLK
Click here for pics
New Accord? Click here for a good PDF detail procedure
Other car: `13 Camaro 2SS
Old 01-17-2013, 12:27 PM
renzovc16's Avatar
Thank you so much you have no idea how of a peace of mind you are giving mel, how can i know which fan is it ?
Old 01-17-2013, 12:34 PM
renzovc16's Avatar
Sorry, as you can see in the picture it says FAN RLY which is 7.5a so im assuming is the timer fan since yyou look up there is another slot that says main fan motor 30a
Old 01-17-2013, 06:39 PM
renzovc16's Avatar
hi i found it , i tap the A/C CONDENSER FAN RELAY
is it ok ?
Old 01-17-2013, 06:46 PM
dunno - I have a 13 and was told the fan timer circuit was fine - this is the engine fan...
'13 EX-L I4 COUPE
STEEL/BLK
Click here for pics
Old 01-17-2013, 06:51 PM
renzovc16's Avatar
oh ok , thanks brother anyway
Old 01-18-2013, 03:35 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
What purpose does this mod do?
Does it increase your front light output?
Will it blind other drivers?
All I see it doing is yelling "Look at me".
Don't see the point in it.
That is just me.
- It is just a car -
2005 Accord Sedan EX-L AT
2009 Accord Coupe 6/6 Black
Old 01-18-2013, 04:19 AM
renzovc16's Avatar
i just kinda wanted to do it to feel proud of my self i guess lol
