Big Maintenance day tomorrow - Drive Accord Honda Forums
Old 01-20-2013, 08:06 PM
PurdueSilver's Avatar
PurdueSilver PurdueSilver is online now
4th Gear
So since I bought my car at an odd mileage, I made sure the big things were done before I drove off. Well two years and 45,000 miles later, Its time for some work on my 2005 LX I4 with 143000 miles.
Tomorrows plan
Serpentine (starting to get a squeak. Doesn't look too bad, but I hate the sound and It would be good to do it now.
Plugs I have a question here a shop has NGK IZFR6K11 but the FAQ suggests NGK 1ZFR6K13. Can I use what the shop has?
Trains. Drain and fill will most likely do the 3x3. ATF-Z1 unless there is another fluid which would work?
And coolant. 7.1 qts. I have some now as it has gone down a small amount since purchase. But just to be clear, when I bought the first one the guy asked me what color. What color should it be?
Lastly, if there is money left over, the red top cell battery, the old one is weak when it gets to 15 degrees or lower here.
Insight and recommendations are welcomed. I did the searches and looked at DIY. I am having a friend help as I don't have tools or a garage. But he is more than capable. So just notes from experiences or fluid recommendations are welcomed.
Thanks
2005 SSM Sedan LX
Matte Black Grille with stock Emblem
15% Tint all around
12" Kenwood Subwoofer
6000k HID Kits
White LED Lights all around
Custom 2.5" Cat Back Exhaust
Fujita Cold Air Intake
TSX Intake Manifold
P2R Gaskets
Old 01-20-2013, 08:22 PM
redhat redhat is offline
No lifetime fluids!
Serpentine -- if you can get a gatorback, very good belts IMO
Plugs - I looked up on NGK website and it lists IZFR6K11. Perhaps a newer part number replaced the old one.
Trans - good
Battery - By red top you mean Optima? Have never had one but others on here have said that their most recent incarnations are not too great. Perhaps look for something like an Interstate or some AGM style.
-Jaimy
'09 LX 5MT - ASM/BLK, 42.5k
TGMO 0W-20, A01
Link to my HOBO build thread
Old 01-20-2013, 08:28 PM
DreaminAccord's Avatar
DreaminAccord DreaminAccord is offline
I <3 My Honda
The new OEM Honda ATF fluid is the DW-1 - the Z1 is the old stuff.
Ben
'07 EX-L V6 Coupe w/ Navi
Graphite Pearl / Black Leather
TL Bi-Xenon Retro | TSX LED Mirrors | Spec-D Fog Lamps | 30% Tint | Alpine Sub System | BlitzSafe AUX | USA Spec BlueTooth
OEM HFP Kit | OEM Visors | Trunk Spoiler | CCD Back-up Cam | Tein Coilovers | Ingalls Camber Kit | H&R TRAK+
Winter: Honda 18" 10-Spokes / Continental DWS
Summer: Hyundai 19" Dual 5-Spokes / Hankook V12 Evo
Old 01-20-2013, 09:50 PM
2006accord4 2006accord4 is offline
2006 I4 MT
Where do you live? That might be the reason about the coolant color.
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 57k miles
Old 01-21-2013, 06:43 AM
mobiless2's Avatar
mobiless2 mobiless2 is offline
mobiless2
What about changing your tranny filter. And cabin filter.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 251K
2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K
Old 01-21-2013, 07:23 AM
bigballer bigballer is offline
3rd Gear
These are all oddball jobs that you can do yourself as a weekend job. Very easy engine to work on, lights of room to really get your hands dirty. This same engine in a a smaller engine bay (i.e. cr-v) it's hell.
Just make sure you flush your brakes while you're there, lubricate your brakes, and change all filters.
Old 01-21-2013, 08:36 AM
2006 I4 MT
Make sure you do the work and have your friend show you. Hands on experience is better than standing there watching.
Old 01-21-2013, 08:40 AM
Aviography's Avatar
Proper Honda coolant color is blue, you can only buy this from Honda dealership or other places supplying genuine Honda parts/supplies. DO NOT buy other brands as you risk undesirable chemical reactions.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 01-21-2013, 08:43 AM
cascivic cascivic is offline
4th Gear
All good points
The coolant should be flushed. Honda coolant is blue and most people recommend the oem fluid. They do make some aftermarket fluid that says compatible with Japanese vehicles I personally would use the honda brand.
The new trans fluid is dw1 it supersedes the z1 like the previous poster mentioned.
Brake fluid should be changed and flushed every 3 years no mileage restrictions.
Sent from my iPhone using AutoGuide.com Free App
Old 01-21-2013, 05:33 PM
cjy3 cjy3 is offline
3rd Gear
I have asked at two Honda dealerships were I get parts, why did my 2006 EX-L i4 come from the factory with the NGKIZFR6K13? They both have said the 13's are for California cars and the 11's are for everybody else. You can use both.
Old 01-21-2013, 05:57 PM
BLCKFLSH's Avatar
BLCKFLSH BLCKFLSH is online now
Make that BluFlsh
I would not flush the coolant. Drain and fill, like the service manual says. If the coolant in the engine is really bad, or if it's the wrong type, buy another gallon of coolant, and flush it with that.
92 EX Sedan auto - sold after 12 years
03 EX V6 Sedan auto - present car
