New guy here with 06 Accord EX-L V6!!
Hey guys! My name is Tony. I just bought a 06 Accord EX-L V6 a week ago. I must say i am a proud owner. I have many many plans for this car! I will be looking forward to meeting everyone of you guys on the forum! Thank You!
![]() My 97 Civic EX with 99-00 Conversion
| Sponsored Links | ||
Advertisement | ||
Welcome to DA, Hope to see the progress.
"None are more hopelessly enslaved then those who falsely believe they are free" - Goethe Current Car: 2007 Accord V6 3.0L EX AT (W/O Navi) |
Congrats on purchase, & Welcome to DA!
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 245K 2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 99K |
Great choice, Tony - you'll love the upgrade of the Accord compared to the Civic. Oh, and welcome
Ben '07 EX-L V6 Coupe w/ Navi Graphite Pearl / Black Leather TSX Retro | TSX LED Mirrors | Spec-D Fog Lamps | 30% Tint | Alpine Sub System | BlitzSafe AUX | USA Spec BlueTooth OEM HFP Kit | Trunk Spoiler | CCD Back-up Cam | Tein Coilovers | Ingalls Camber Kit | H&R TRAK+ Winter: Honda 18" 10-Spokes / Continental DWS Summer: Hyundai 19" Dual 5-Spokes / Hankook V12 Evo |
driving the accord is a dream! I can't compare. I'll be selling the civic soon and start on the accord build!
Love that color
'06 Sapphire Coupe. |
Yea I think that color matches the 8G 19" HFP wheels the best
Don't I know lol. Wish I could afford them. Congrats on the car OP. Change that ATF ASAP.
2006 EX V6 6MT Sedan Carbon Bronze Pearl / Ivory 2005 EX I-4 5AT Sedan Redondo Red Pearl / Black 1996 Harley-Davidson FXD |
wow..I'm assuming its a common thing to change the ATF? That was going to be the first thing on my to do list. The car does some hard shifting. Good thing after looking at this forum I know that it isn't normal. Thanks guys!
Well the V6 5AT automatics have had their fair share of failures over the years, it is better to pay a couple bucks now to do a 3x drain & fill then pay $2000 for a new transmission later on. I bought my car at 21k miles and did a 3x D&F at 25k - plan on doing 1 every 25k miles. I just ordered a case (12) of OEM Honda DW-1 (new ATF - supersedes the old Z1 formula), new drain plug washer and new fill plug washer from Majestic Honda (2006-2007 Honda Accord Maintenance Items)
The great thing about our V6 engines is that we actually have a fill plug (17mm bolt that is torqued down very tight - use an extension and breaker bar and prepare for your shoulder to feel like it's about to pop out of the socket the first time it's loosened lol You don't need to tighten it back down that tight afterwards) instead of using a dipstick to refill the 3-3.5 qts you'll be draining out. Always remember to use a catch pan that has measurements on it so you can put in exact how much you took out The drain plug is located behind the driver front tire, at the bottom right side of the transmission (if you are looking towards the front of the car). It takes a 3/8" ratchet w/o a socket. I would remove your fill plug before draining, though, as you'll get a better drain. #1. Remove fill plug and replace washer ($3.14 but peace of mind) #2. Remove drain plug and replace washer ($1.49) #3. Assess the drain plug magnet for how many metal shavings are attached to determine how well your transmission is doing. A little bit a shavings is completely normal. A huge amount, or big clump, start praying to the transmission Gods lol #4. Allow the transmission fluid to fully stop draining into the catch pan #5. Re-torque down the transmission drain bolt to OEM spec w/ new washer #6. Grab a transmission funnel with a long tube and insert into the fill plug #7. Replace the ATF fluid in the exact amount that you measure in your catch pan #8. Re-torque down the fill plug #9. Restart the car and with your foot on the brake, continue to shift through each gear [P] [N] [D] etc. leaving it in each setting for about 30-60 seconds to allow the fluid to generously coat each gear. #10. Safely discard of the old ATF #11. Take the car for a 15-20 minute drive, that allows for every kind of driving, and hitting every gear (1-5) #12. Repeat the process two more times to ensure that all of the fluid has been replaced and is nice and pink. You don't have to do all 3 D&F's in one day. Some people like to do 1 D&F at every oil change. Hope this helps!
I was thinking of starting my first D&F this Sunday. Can I repeat it for the next 2 weekends on Sunday?
Sure can, you can do em however close or spaced out you'd like to - you'll feel a major difference in smoothness too, I did and mine only had 25k miles
Awesome! Cus I hate how it shifts hard!
Welcome to DA!
I was just thinking today how doing the rear sway bar on my 05 coupe was a great upgrade. It's a fairly simple upgrade if you can get the screws off the end links - which was the tough part for me being a novice.
2005 V6 EX Coupe - Nighthawk black |
| Sponsored Links | |
Advertisement | |
