Accord Earth Dreams Specs - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > the 9th Generation
Old 02-04-2013, 03:00 PM
paticumbia's Avatar
paticumbia paticumbia is offline
4th Gear
Found This on Wikipedia for those that want to know. Also explains why the
Sport has more HP.
K24W1(Earth Dreams)
Found in:
2013 Honda Accord Sedan and Coupe (US)
Displacement: 2,356 cc (143.8 cu in)
Bore and Stroke: 87 mm x 99.1 mm
Compression: 11.1:1
Power: 185 HP @ 6400 rpm (189 HP SPORT MODEL)
Torque: 181 lbs·ft @ 3900 rpm (182 LBFT SPORT MODEL)
Redline: 6,800 rpm
K24W2(Earth Dreams)
Found in:
2013 Honda Accord
Compression: 11.1:1
Torque: 181 lbft @ 3900 rpm
Redline: 6,900 rpm
Fuel Cut: 7,200 rpm (Auto/CVT- 7,500 for manual)
Head Type: DOHC VTEC
VTC Type: i-VTEC
Displacement: 2,354 cc (143.6 cu in)
Power: 188 PS (138 kW; 185 hp) @ 6700 rpm
Torque: 245 N·m (181 lb·ft) @ 3900 rpm (181 lbft @ 3900 rpm U.S.)
Bore: 87 mm
Stroke: 99.1 mm
Compression: 11.1:1
Redline: 6,900rpm
Fuel cut off 7,200rpm (Auto/CVT)
Fuel Type: Direct Side Port Fuel Injection/ DEFI ULVe-2
Ignition type: ECU Advanced/Controlled - Coil on Plug
Automatic 7,000 rpm
Manual 7,500 rpm (7,500 rpm U.S.)
Note: The Honda K24W2 is based on the K24Y and K24Z engines.
Adding: Direct Port Injection, Less Friction, Less Weight, Higher Compression, Revised VTEC and i-VTEC along with all new integrated exhaust manifolds. The 2013 Honda Accord Sport gets 190hp/185lb-ft thanks to a slight ECU tune and larger exhaust piping and higher flow Cat. Also, the K24W series are mounted differently from the previous K series engines. They are mounted like traditional Honda engines, with the integrated exhaust manifold in the front and intake manifold in the back.
K24W3(Earth Dreams)
Found in:
Compression: 11.1:1
Power: 190 HP @ 6700 rpm
Torque: 185 lbft @ 3900 rpm
Redline: 7,000 rpm
Fuel Cut: 7,300 rpm (Auto/CVT- 7,600 for manual)
VTC Type: i-VTEC
Power: 190 PS (140 kW; 190 hp) @ 6700 rpm
Torque: 251 N·m (185 lb·ft) @ 3900 rpm (185 lbft @ 3900 rpm U.S.)
Bore: 87 mm
Stroke: 99.1 mm
Compression: 11.1:1
Redline: 7,000rpm
Fuel Cut: 7,300rpm (Auto/CVT- 7,500 for manual)
Fuel Type: Direct Side Port Fuel Injection/ DEFI ULVe-2|
Automatic 7,000 rpm
Note: The Honda K24W2 and K24W3 are based on the K24Y and K24Z engines.
Adding: Direct Port Injection, Less Friction, Less Weight, Higher Compression, Revised VTEC and i-VTEC along with all new integrated exhaust manifolds. The 2013 Honda Accord Sport gets 190hp/185lb-ft thanks to a slight ECU tune and larger exhaust piping and higher flow Cat. Also, the K24W series are mounted differently from the previous K's. They are mounted like traditional Honda engines, with the integrated exhaust manifold in the front and intake manifold in the back.
Found in:
2013 Honda Accord Sedan Sport (US)
Bore and Stroke: 87 mm x 99.1 mm (3.43 x 3.90 inches)
Compression: 11.1:1
Torque: 185 lbs·ft @ 3900 rpm
Redline: 7,000 rpm
Alabaster Silver
Old 02-04-2013, 04:40 PM
rdeal317's Avatar
rdeal317 rdeal317 is offline
2nd Gear
Gotta love wikipedia. The K24W1 is what my 6MT Sport has under the hood. You can delete the rest and all of its contradictory info.
Old 02-04-2013, 04:56 PM
paticumbia's Avatar
4th Gear
Re: Accord Earth Dreams Specs
What I still haven't found out is if our accords are vtec only on intake valves or also on exhaust
Sent from my HTC Sensation 4G using AutoGuide.Com Free App
Alabaster Silver
Old 02-04-2013, 05:30 PM
rdeal317's Avatar
2nd Gear
This K has a pretty fat midrange compared to other K24s with similar specs but on premium gas. I doubt Honda accomplished this with less valve control.
Old 02-05-2013, 02:52 AM
on2's Avatar
on2 on2 is online now
I Love My Honda
Keep in mind people that this is Wikipedia. Prone to inaccurate information.
The exhaust pipe is not larger on the Sport model and the catalytic converter is not a higher flowing piece.
2013 Accord Sport CVT
Best tank to date (15% CTY/85% HWY)
640 miles on 16.1 gallons
39.8 MPG combined average
Old 02-05-2013, 03:36 AM
JoeK's Avatar
JoeK JoeK is offline
4th Gear
Personally I prefer the V6-6MT Nightmare.
09 V6 6MT Coupe
Old 02-05-2013, 05:41 AM
SHINCHU's Avatar
SHINCHU SHINCHU is offline
2013 Sedan Sport
ummmm... i looked RIGHT AT my engine block and it clearly says
K24W7
2013 sedan sport CVT (california)
Old 02-05-2013, 07:20 AM
rdeal317's Avatar
2nd Gear
7? Earth Dreams just came out and they're on #7?!?!?
Here's my "1"
Name:  ImageUploadedByAG Free1360081197.726758.jpg
Old 02-05-2013, 09:35 AM
jshaw jshaw is offline
4th Gear
Yeah, some of that wiki info is bunk, starting with the HP/TQ ratings for some of the engines.
As for VTEC, it's only on the intake. The only intake/exhaust VTEC engine Honda currently makes, anymore, is the J37 (and not all J37 engines - just the one in the TL sedan, iirc), which is, neatly, a SOHC engine.
Old 02-05-2013, 12:10 PM
rdeal317's Avatar
2nd Gear
I think you're talking about the I-VTEC upgrade, intake cam-only advance/retard adjustment. They still switch to a big lobe on both cams with a big jump in lift and duration.
Old 02-05-2013, 03:44 PM
tatsu tatsu is offline
are both intake/exhaust 3 lobe??
Old 02-05-2013, 04:25 PM
4th Gear
All is still on just one camshaft
However, on most SOHC setups, there isn't enough space for multiple lobes for both the intake, exhaust, and spark plugs! The J37 V6 uses Y-shaped rockers to get around that, however, there are some disadvantages with this (even with a 3-lobe setup, it is impossible to do the partial intake valve deactivation Honda implements on several of their VTEC systems, which helps with low end torque [think Buick pinhead V8], fuel economy, and emissions [intake vortex]).
Actually, on the low end torque loss with the intake/exhaust SOHC VTEC setup, that's probably why the MDX J37 only has intake VTEC - so the intake camshaft can deactivate half of the intake valves, for better low-RPM torque, as is expected for a big engine powering a big car.
Old 02-05-2013, 05:11 PM
rdeal317's Avatar
2nd Gear
I'm saying the J isn't the only Honda with I/E triple lobe action. Civic Si/ILX/TSX K24s all have two cams full of vtec - they just retard or advance the intake cam (I-VTEC bonus).
Old 02-05-2013, 05:36 PM
4th Gear
Oh, I see. I didn't quote post #3, which I was supposed to
I'm sorry.
However, there are no current dual VTEC implementations outside of the TL J37. Name any car, I'll find the documents from Honda supporting this claim.
EDIT: or you could go to the source, too!
hondanews.com <--it's where Honda puts all of their more detailed press releases and technical info (short of say, a SAE publication).
Last edited by jshaw; 02-05-2013 at 08:26 PM. Reason: I don't know why I uppercased a word :(
Old 02-05-2013, 06:53 PM
rdeal317's Avatar
2nd Gear
I stand corrected, VTEC as it originated is gone. Glad I kept my H22 Accord so I can be crotchety.
And when I looked at that Hondanews site it stated that the Sport has a higher flowing exhaust (52%) and that is the reason for the 4hp. So that was helpful.
