Compass zone number and calibration - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Shopper > Accessories
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 09-17-2006, 02:17 PM
Endymion Endymion is offline
Smile Compass zone number and calibration
Hello all,
I have just installed Day/night rear view mirror on 05 V6 Accord but the compass isn't working right. I didn't get the owner's manual with it so I was wondering someone can help me out. How do you calibrate the compass and know what zone number to put in? All your inputs are greatly appreciated.
Old 09-17-2006, 03:57 PM
ItsaHonda's Avatar
ItsaHonda ItsaHonda is offline
6th Gear
Mine calibrated itself after several days of driving around. Perhaps yours will do the same...
1990 Honda Accord LX coupe
130,XXX miles
1989 Honda Accord LX sedan
186,XXX miles
1998 Lexus GS400
170,XXX miles
1992 Cadillac Allante
70,XXX miles
2013 Kia Optima LX
8,xxx miles
Old 09-17-2006, 07:45 PM
Thanks. I will try the same.
Old 09-17-2006, 08:29 PM
odk's Avatar
odk odk is offline
3rd Gear
From the manual...." the compass function calibrates itself under normal driving and turning conditions." Good luck!
Old 09-18-2006, 05:32 AM
MJL's Avatar
MJL MJL is offline
6th Gear
Send a message via AIM to MJL
Use this set of instructions. You need to set your correct zone number and that the easiest thing to do to calibrate the compass is find a parking lot or cul de sac and drive in a few circles until the CAL light goes away
http://www.drivesubaru.com/SubaruDri.../DimInstr2.pdf
2013 Accord Ex 4cyl 6spd MT Coupe - 20mm RSB - Short shift adapter.
Old- 2005 Accord EX-L 4cyl 5-Spd - MP3 player adapter - 17mm TL Rear Sway Bar - V6 6spd Tower Strut Bar - Infinity Kappa 6x9s - Polk DB6500 front components door and tweets - Infinity BassLink II w/4sc - Neuspeed Short Shifter - Blue Gauges and Ambient Light
Old 09-18-2006, 07:22 AM
Trip's Avatar
Trip Trip is offline
MJL is correct. The accessory auto dim mirror needs manual intervention to operate properly. The instructions provided should work since it's the same aftermarket mirror that Subaru uses. The compass needs to be set to the correct ["electro-magnetic"] zone first ( a number from 1 - 10 for the continental use - see the map in the instructions). It's not a time zone BTW like my sister thought. Then it needs to be calibrated. Thats the part where you drive in circles . . . much like life in gneral except you only need to do it for a minute or so. Find a big open parking lot and watch out for lamp posts.
Current: 2009 Mazda 6 iGT 6MT, 1989 Prelude Si 5MT
Come & Gone: 84 Accord HB, 91 CRX Si, 89 Accord LXi, 90 Accord LX Cpe, 94 Accord EX, 95 Accord EX Cpe, 98 Accord EX, 99 A4, 03 Accord EX-L, 91 Civic RT4WD Wagon, 06 Accord EX-L NAVI
From The Dark Period: 01.5 Passat, 08 Accord 6-6
DA MOD TEAM
Old 09-18-2006, 02:12 PM
Thumbs up
MJL, you are the man. It's exactly what I was looking for. I will try it today after work. This forum rocks!!!
Old 05-05-2011, 07:33 PM
savlisoz09coupe savlisoz09coupe is offline
Hello Everyone!
Was wondering if anyone out there can help me out. My compass works fine for about
5-7 turns then it starts blinking and won't change. I have tried following the owners manual but when I get to the part where you select claibration and push enter I don't know if I am supposed to start the car or not? The manual doesnt mention that part. It goes fron select calibration by pushing the selector knob to drive the car around in circles slowly. Can someone giv e me a play by play on this? Do you think that having changed the rear factory speakers might have something to do with it?
Any advice is greatly appreciated.
Thank you!
